Re: cheap rope, was Micro Navigator
The ebay seller is in Covington GA. I think he's the same guy that sells at the flea market up the road from us. This
fellow has all kinds of rope, prices are good and he seems like a decent sort. You may be able to buy directly from him.
Doug
2/12/2003 11:12:18 AM, "Bruce Hallman <brucehallman@...>" wrote:
>I bought a *whole bunch* of
>deeply discounted rope from
>the ebay seller "elduu"
>http://makeashorterlink.com/?J2DD21073
>...rope at prices about 10% of what
>my local store sells simlar.
I presume by around the aft deck, you mean lead under it, and
through the bulkhead? That is what I am doing. And making sure they
lead uphill so water does not run into the cabin.
Yes, the plan shows the mainsheet cutting right across the aft deck
at waist height, which would be dangerous. I am hoping to also lead
that under the deck.
DonB
--- Inbolger@yahoogroups.com, "Bruce Hallman <brucehallman@y...>"
<brucehallman@y...> wrote:
> --- <oink@p...> wrote:
> > I am rigging now, and gagging a
> > bit at the cost of it all!
> see for instance:
> Plus I bought some 'cheapo' plastic
> UHMW 7/8" diameter rod which I plan
> to turn into homemade sheaves, as
> described in the Duckworks article:
>http://makeashorterlink.com/?Z52E52073
> I will route the lines through the
> sheaves to the cabin ceiling, and stow
> them "wound up" on some homemade
> quick release cleats [like on my
> home vacuum cleaner]. {fingers crossed}
> ...this might work.
> > Have you thought about your control
> > lines from mast to cabin front?
> Yes, and it is just dawning on me that
> there are also 4 lines (sheets) coming from
> the aft, in addition to the 8 lines from
> the front (4 reef lines, 2 topping lift2,
> 2 halyards).
> The aft lines have to deal with fouling the
> afterdeck, [I took your advice and increased
> the size of the afterdeck] I plan to route the
> mizzen and main batten sheets down and around
> the afterdeck but the main sheet must simply
> be in the way.
see for instance:
...this might work.
2 halyards).
be in the way.
Good going with your construction Bruce.
I am rigging now, and gagging a bit at the cost of it all!
Have you thought about your control lines from mast to cabin front?
I wonder about all those ropes dangling and swaying right in front
of your line of vision...might pay to keep the 'sick bucket' handy!
I have decided to cleat those controls outside near the base of the
mast for now, because access there is so easy from the forehatch,
and reefing easily done from the big main hatch. And I don't intend
to be out in nasty weather.
What do you intend?
DonB
> --- "Todd <ktsrfer@m...>" wrote:
> > Are there any micro navigators
> > or conversion of finished and
> > sailing with the designed rig?
> I recall that PB&F have written
> that this sail rig has been
> successfully tested and proven
> in concept. But exactly where
> and how, I don't know. I plan
> to 'prototype' the sail once in
> white polytarp, and then (when
> happy with the shape) [and if
> un-happy with the poly-tarp] I
> will have the sail reproduced in
> sailcloth.
> > How much higher from the cuddy deck
> > of a micro does the cabin house
> > stand?
> I am not sure of your question.
> The cabin extends about 2'8" up
> from the afterdeck. And 1'9" up
> from the forward deck.
> Overall, the cabin roof is about 5'4"
> above the bottom of the boat. [not
> counting the fin].
> > Sure liking the looks of the navigator
> It has a kind of 'retro' look.
> A neighbor from up the street
> stopped in yesterday and asked
> me how old this boat was. He
> thought that I was restoring a
> 100 year old boat, as opposed to
> building a new boat.
> No doubt about it, the boat
> has a 'unique' look.
> Also, do I *have* to have an
> outboard motor?
sailcloth.
> stand?
counting the fin].
outboard motor?
Are there any micro navigators or conversion of finished and sailing
How much higher from the cuddy deck of a micro does the cabin house
stand?
Sure liking the looks of the navigator and or the micro trawler.
Todd
