Re: [bolger] Re: Digest Number 1408
No. Do like I did on old truck corner windows. Put silicon on. Cover windows
with plastic wrap. Close windows and let cure. Open and pull of wrap.
Everybody thinks they are glued shut!
Sent: Tuesday, February 18, 2003 9:18 PM
Subject: Re: [bolger] Re: Digest Number 1408
> > I made a couple of hatch covers that are weather and spray proof. I
> > never bothered to add the rubber gaskets since they work so well
> > without, but with gaskets, they would be very close to waterproof, if
> > not 100%.
> One way to make a simple water proof hatch seal is to run a 1/4" bead or
so
> of silicone around the inside of the lid where it rest on top of the hatch
> frame. Let it setup up until almost firm and no longer tacky to the
touch.
> Gently lay the lid down on the hatch frame and LIGHTLY press in to place
> then immediately lift off and let it cure fully. Essentially you've just
> made a custom seal for your hatch that is water proof. I usually have a
> couple scraps of wood laying around to make beads on at the same time to
> test prior to fitting the lid. The key is to let the silcon set up enough
> so it doesn't stick to the hatch frame but still soft enough to mold.
> Depending on the type used it takes about 20 to 30 minutes to setup before
> molding and overnight to fully cure. I have the best success with pure
> silicone sealant for Aquariums. $4.00 will make a lot of hatch seals.
> Jeff
> I made a couple of hatch covers that are weather and spray proof. IOne way to make a simple water proof hatch seal is to run a 1/4" bead or so
> not 100%.
frame. Let it setup up until almost firm and no longer tacky to the touch.
not 100%.
I made about a one inch rim around the opening, with a box top type
lid that fits closely around and over the rim -- the lid has a one
inch rim that overlaps the first one. A couple of webbing straps
cross the top, fastened with delrin buckles. I looked over a number
of kayak hatch designs, and stole their ideas -- you could probably
find plenty on the web, you could start with CLC.
Jamie Orr
--- Inbolger@yahoogroups.com, William Feather
<williamfeather10@y...> wrote:
that has a plywood weather tight hatch system? i really don't want to
put a plastic hatch in my Diablo. Any feed back from my Brother Phil
Bolger's would be much appriaciated
__
__
__
__
__
__
__
__
not 100%.
Jamie Orr
>can't seem to find the hardware to make it work. anybody out there
> hello- I've been working on a water tight hatch in plywood and
>bolger@yahoogroups.comwrote:Bolger rules!!!posts
> - add your comments at the TOP and SIGN your posts and <snip> awayMA, 01930, Fax: (978) 282-1349
> - Unsubscribe:bolger-unsubscribe@yahoogroups.com----
>______________________________________________________________________
> There are 3 messages in this issue.
> Topics in this digest:
> 1. Re: Motor vs. Sail
> From: "timothyennuinet "
> 2. Re: Motor vs. Sail
> From: "proaconstrictor
> 3. It has been a long time...
> From: "Giuseppe Pippo Bianco
__
__
>it
> Message: 1
> Date: Tue, 18 Feb 2003 05:49:45 -0000
> Subject: Re: Motor vs. Sail
> --- Inbolger@yahoogroups.com, "robby plunkett"
> wrote:
> > i'd go for the motorsailer. it may not be the best of either but
> is morenot
> > versatile.
> Ok.. Ill toss two cents in, considering I am having problems getting
> to sleep :)
> I think the idea that a motorboat and a sailboat being opposite is
> entirely accurate. It is easy for us to put them on two sides ofsome
> sort of spectrum, and easy to talk about hull forms, stabilitycurves,
> etc. But really, I think there is room for a differentinterpretation.
>motorboat
> A Motorsailer could be built that performed almost as well as a
> sailboat of similiar configuration, and almost as well as a
> in the same vein. You just have to get over the normal way ofthinking
> about it. Once you get into slightly oversized, deck hinged mastsyou
> can reduce windage a great deal by dropping the masts if you needpure
> power into a blow. But, if you overcanvas a bit, you can get enoughup
> there to overcome the xtra weight of fuel and the larger motor. Willget a
> she point with a racer? Not on your life! But I'd bet that you won't
> mind motoring up into the wind with 80 horses under your feet.
> And sails really have the potential to help out a motorboat. You
> great deal of steadying, as well as xtra miles made good out of apowerboats?
> decent set of working sails. And an absolutely foolproof 'get home'
> system. So why the heck do you rarely see sails on long range
>two
> Honestly, the only reason I can think of is fashion. I really don't
> like the Nordhaven style of thinking.. big fat boats that burn huge
> amounts of fuel. Add on active stabilizers for even more fuel burn.
> No, Ill take a slim profile, easy pushing hull shape and a sail or
> anyday I think. Heck, why not SAIL the thing once in awhile for some______________________________________________________________________
> peace and quiet? :)
> --T
__
__
>is
> Message: 2
> Date: Tue, 18 Feb 2003 06:14:58 -0000
> nota
> some
> curves,
> interpretation.
> I think multihulls actualy have this happening, though to get it
> happening so that you have something like a transformer is perhaps
> little more challenging. Low resistance makes it possible to use a______________________________________________________________________
> small motor, which isn't a drag during sailing. There are a number
> of tris that can be configured with just a change in floats to go
> right down to canal size, motor accross the pacific, or sail around
> the worlds at speed. You can get that in something other than a
> multihull, but you can't get it in 3-4000 pounds, with the building
> that implies.
__
__
>without
> Message: 3
> Date: Tue, 18 Feb 2003 09:53:33 -0000
> Subject: It has been a long time...
> Hiya everybody. How's everything?
> I've been nostalgically visiting this forum quite constantly,
> posting though. I've seen a whole bunch of new Micros in the waterthe
> (congratulations to all, and in particular to David Jost for his
> beautiful Firefly: you did it!). Ah, memories...
> I'm still building my non-Bolger boat (the CK17 by bateau.com) and
> I'm making good progress on it while it's not showing up on my web
> site which I haven't updated since one year...
> Anyway, I'm more and more intrigued with the sharpie concept and of
> course, while still working on my little boat which I WILL launch
> next summer, I'm dreaming about the next one which could well be a
> bigger sharpie.
> Dreams of grandeur apart (read: a NIS 31') I'm considering Reul
> Parker's Egret, which is so beautiful, as well as Bolger's Black
> Skimmer, which PCB himself considers able to sail circles around
> former.an
> Anybody here as an unused set of Black Skimmer plans to trade with
> unused set of Micro, Long Micro or Bobcat (I'll keep the Chebacco______________________________________________________________________
> plans)?
> Cheers everybody
> Pippo
__
__
> Do you Yahoo!?
> Yahoo! Shopping - Send Flowers for Valentine's Day
I wouldn't call it watertight, but you might like to see the fore
hatch I made on my Diablo out of plywood and a set of brass hinges.
Bruce Hector
http://www.brucesboats.com
Click on Diablo in the address bar.
Bruce Hector
hello- I've been working on a water tight hatch in plywood and can't seem to find the hardware to make it work. anybody out there that has a plywood weather tight hatch system? i really don't want to put a plastic hatch in my Diablo. Any feed back from my Brother Phil Bolger's would be much appriaciated
Message: 1
to sleep :)
I think the idea that a motorboat and a sailboat being opposite is not
entirely accurate. It is easy for us to put them on two sides of some
sort of spectrum, and easy to talk about hull forms, stability curves,
etc. But really, I think there is room for a different interpretation.
sailboat of similiar configuration, and almost as well as a motorboat
in the same vein. You just have to get over the normal way of thinking
about it. Once you get into slightly oversized, deck hinged masts you
can reduce windage a great deal by dropping the masts if you need pure
power into a blow. But, if you overcanvas a bit, you can get enough up
And sails really have the potential to help out a motorboat. You get a
system. So why the heck do you rarely see sails on long range powerboats?
No, Ill take a slim profile, easy pushing hull shape and a sail or two
peace and quiet? :)
--T
Message: 2
happening so that you have something like a transformer is perhaps a
that implies.
Message: 3
I've been nostalgically visiting this forum quite constantly, without
bigger sharpie.
Skimmer, which PCB himself considers able to sail circles around the
former.
Anybody here as an unused set of Black Skimmer plans to trade with an
plans)?
Cheers everybody
Pippo
Do you Yahoo!?
Message: 1
> i'd go for the motorsailer. it may not be the best of either but itis more
> versatile.Ok.. Ill toss two cents in, considering I am having problems getting
to sleep :)
peace and quiet? :)
--T
Message: 2
>not
that implies.
Message: 3
bigger sharpie.
former.
plans)?
Cheers everybody
Pippo
Do you Yahoo!?
