Re: [bolger] winter cover solution!
Photos, David?
cheers
Derek
cheers
Derek
The uprights are attached by lines to nearby trees and when possible
to rebars driven into the frozen tundra. tent stakes work well prior
to the frost setting in. The eyebolts go through each upright 1 foot
up and serve a dual purpose. Staking to ground, and a purchase for
each tarp grommet.
the roof was made by bending the middle tube 45 degrees on each end
and 45 degrees in the middle. This made a peaked roof. Width is
determined by where I bend the ends. I chose 1 foot up making each
roof "truss" span a length of 7 feet. This works well for Micro
since she is only 6 feet maximum.
I will adapt this for the catboat I have coming soon!
each tarp grommet.
> David Jost
> Hi
> Could you post a few more details?
> Did you sink the uprights into the "frozen tundra"?
> How were the uprights spaced and held apart?
> Are the roof parts curved or do they come to a peak?
> What is the length and breadth?
> Thanks
--- Inbolger@yahoogroups.com, "dnjost <djost@m...>" <djost@m...>
Hi
Thanks
> After dealing with tarps sagging and ripping and fearing that theDavid Jost
> weight of our recent snow would do danger to the MICRO Firefly, I
> came up with what I think is a good solution for a winter frame.
> I purchased 10 ten foot lengths of electrical conduit and a bender
> from the Home Despot and 10 connectors.
Hi
Thanks
I cut five of these into 5 foot halves and then bent the remaining so
that they would form a roof. the couples hold the roof to the five
foot posts.
Next, I drilled 3/16th inch holes two feet off the bottom to receive
some eye bolts.
I linke them all together with rope from frame to frame and then
tossed a fresh tarp over the whole mess making it fast to the
eyebolts. Other lengths of line hold the thing to stakes in the
frozen tundra.
This survived the blizzard of 2003 in grand style. Sheds snow and
rain like a duck.
total cost = $56 including a fresh tarp and the tubing bender.
This must be in the why didn't I think of this before (I have used
electrical conduit to make frames for gardens in the past!)
Happy Boating
foot posts.
some eye bolts.
frozen tundra.
rain like a duck.
Happy Boating
