Re: Birch Ply
built my zephyr from very nice finnish birch ply - lots of thin veneers
- but it doesnt hold up at all. after *weeks* in the open the
painted+sun-exposed areas had checked and were covered with
little black fungus dots. acrylic paint came off quick. i dont paint
the bottom any more, its not worth it. the sides (less sun) are
holding up much better. polyester-soaked areas around the butt
joints are still looking o.k.
i am not very happy about it, but unfortunately it is the only
waterproof ply i can get around here (landlocked austria)
hannes
p.s. a boatbuilder friend of mine surveyed a russian cat from birch
ply, and it was really "rotten to the core" under the water line. he
commented on the low rot resistance of birch.
hannes
Or you could just seal it .
Click on my yahoo name see that picture in profile that board! Its 2
pieces of birch laminated with epoxy one coat of epoxy and 3 coats
of varnish. Not beating my chest to much but i have three other
boards built out of baltic birch that get punished none have
delaminated as of yet but there sealed. The birch at my lumber yard
says interior use so its a pretty good guess it doesn't have
exterior glue. I like it though its the most solid local ply I can
get at a great price. So I think for small application sealing it
with epoxy then painting it is still cost effective. But then again
I'd run out of food before I'd run out of epoxy if it wasn't for my
wife.
Todd
wife.
Todd
> I would recomend the dishwasher test if you have one. Cut a small
> 4"or 6" square peice and put it in the dish washer for a month.
That will
> soon reveal what it is going to do.
> HJ
> > There are 7 plys in this 3/4 inch plywood. No mushy stuff in
> > middle. It is really nice stuff to work with.
> > Steve
> > How main plys are in that 3/4''. Some of that
> > > birch I found at those H/D stores where just thin vaneers of
birch
> > > ontop of a mushy core material in center.
> > > Todd
4"or 6" square peice and put it in the dish washer for a month. That will
> Steve
> > birch I found at those H/D stores where just thin vaneers of birch
> > Todd
I'd seal it then paint it even still.
Todd
--- Inbolger@yahoogroups.com, "Steve Bosquette <sbosquette@c...>"
<sbosquette@c...> wrote:
Todd
> There are 7 plys in this 3/4 inch plywood. No mushy stuff inbirch
> Steve
> > Todd
Steve
Steve
> Todd
I'd seal it with two coats of epoxy. Then paint it. I have used
baltic birch 1/8''(3 ply) and 1/4''(5ply) in marine applications
glassed and nonglassed but all where coated in epoxy. No checking or
delams, as of yet. How main plys are in that 3/4''. Some of that
Todd
Todd
> I have purchased 3/4 inch birch ply at Home Depot for constructinga
> new windshield for my Sneakeasy! My question is; will it be
> necessary to glass the surface to avoid checks or will primer and
> paint be sufficient? All responses will be helpful!
> Steve Bosquette
All the birch ply I've ever found at HD did not have waterproof glue. Have you tested yours?
The good news is that it probably won't check if it doesn't delaminate. There's been a piece sitting out in my yard for about six or seven years, more or less covered but still exposed to the elements. It's proected only with paint. Water has caused quite a bit of delamination around the edges, but there isn't any checking.
JB
-------Original Message-------
From: "Steve Bosquette <sbosquette@...>" <sbosquette@...>
Sent: 02/21/03 08:55 AM
Subject: [bolger] Birch Ply
Steve Bosquette
JB
> I have purchased 3/4 inch birch ply at Home Depot for constructing a
Steve Bosquette
Steve Bosquette
Steve Bosquette
