Re: plywood diesel cruiser
In my opinion, talking about appearance, the Plywood Cruiser is a
fine functional looking craft. If you slide something up to the
waterline in Bolgers book, so you are not seeing all the underwater
clag, she looks good, and I'm sure in 3D too.
The Scoter is a pretty boat (nothing wrong with that), but to my
mind the Cruiser looks and is a craft with more authority.
DonB
DonB
> I am considering a 'boat of this size' as a replacement for our21'
> camping trailer that we tow with our Jeep Cherokee. My sweetie,our
> Westy (dog), and I. Camp on land in the boat. It would not be asgood
> a camper as our present camper, but it would be a much betterboat. I
> have to keep the cost down, but have some time, (retired), soDevlin
> building a boat seems a good idea.
> The Devlin Wind Scoter 22' is $41,000 (??) without power, but
> claims that you can build it for 1/3 of that. Then there is costof
> trailer and cost of power. The Wind Scoter 25' would be more, butI
> like the looks of it and the extra size. But Devlin has designedit
> for a 135 I/O diesel drive. That is big bucks. Even home builtwould
> probaly be out of my range. Of course, one could power it with aam
> small engine.
> Just moveing along at displacement speed would be fine with me. I
> sort of relaxed and would like to stay that way.than
> The hull of the Bolger cruiser looks to me like something that I
> would like to build. The interior arrangement looks better to me
> the Scoter25. But I can't tell from the book if I would reallylike
> the looks of it compared to the Windscoter. Hmmmmmmmm.... And Iwould
> think that use use of exterior plywood instead of marine gradespacious
> (cost!) would matter less in Bolger vs. Devlin.
> Perhaps some 'composite' boat, .... the best of both????
> > It has an almost vertical, straight stem and a flat vertical
> transom. It could perhaps be called a sedan cruiser with a
> wheelhouse that has the usual wheel and engine controls, a smallthe
> galley and a dinette, as I recall.
> > There is a pair of settee-berths under a trunk cabin forward of
> house, with a toilet compartment in the bow, with a large hatchabove
> it. There is a reasonably spacious self-draining cockpit aft.27
> > The engine specified is a shaft-drive Yanmar diesel of, I think,
> h.p. Bolger indicates the speed that could be achieved, but Ican't
> remember the number. The speed-length ratio is something over two,so
> it could be considered as a planing boat.10
> He calls for an 18 hp Yanmar. Estimated max speed, if I recall, is
> or 12 knots, with cruising 8 knots.to
> > Devlin's designs all have a kind of shippy character-boat look
> them. PDC is conservative, even old-fashioned, but notparticularly
> stylish. I've always thought that the arrangement of the forehatchthink
> and foredeck on PDC look rather unattractive and would try to
> of some kind of alternative if I were building one -- maybe araised
> foredeck instead of the trunk cabin. Perhaps the boat as designedto
> would look a lot better in three dimensions than it does on paper.
> > I've never seen a photo of a finished boat.
> Yes. The proof of the pudding is in the eating. I can read plans
> some extent, but a photo of a finished boat is what 'I' reallyneed.
>seems
> BTW, I have a copy of Gerr's book on scantlings. Bolger's boat
> to fit Gerr's rules.It
> I also have a $15 set of 'study plans' for Devlins 25' Windscoter.
> is a double chine. The double chine seems to work out very well.
> Earl Gasner
> gasner@a...
> > Howard
--- Inbolger@yahoogroups.com, "aquatronclaus" <aquatronboat@h...>
picture to the computer. You can usually attach a digital picture to
an e-mail. You might want to get a digital camera and record the
stages of construction.
Earl
gasner@...
> --- Inbolger@yahoogroups.com, "earlgasner" <gasner@a...> wrote:snip from Fast Diesel Cruiser (bolger) to Surfscoter (devlin).
> > --- Inbolger@yahoogroups.com, stephensonhw@a... wrote:
> > > >I would like to know more about this design. Is there a
> >picture
> > of the actual boat anywhere?
> > > >Its design is shown in Bolger's BWAOM. The website lists it as
> > > >available for $200 from "PBand F". What is that???
> > > >It also lists a 'ref. no.' as BWAOM Ch#56.
> > is a double chine. The double chine seems to work out very well.Find a friend with a digital camera and a computer. Download the
> > Earl Gasner
> > gasner@a...
> > > Howard
> I have a Devlin Surfscoter25 under construction, I will be glad to
> attach a picture, but I don´t know how.
> Claus
Earl
gasner@...
Claus
> --- Inbolger@yahoogroups.com, stephensonhw@a... wrote:know.
>picture
> > >What does anyone think of it as compared to Devlins Wind
>Scoter
> 22 or Wind Scoter 25?
> > >Earl Gasner
> > Earl,
> > I hope the following doesn't repeat a lot of what you already
> >plans,
> > "PB & F" is Phil Bolger and Friends. So if you want to order
> or make enquiries, you can write to the address shown at the footof
> the emails that are sent from the group i.e. Mr. Philip C. Bolger,register
> P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349, just in
> case you visit the group's website rather than have emails sent to
> you. >
> O.K. Thanks. (After much grief, I finally found out how to
> with Yahoo, so I can work with the website.)x7'5",
> > The Plywood Diesel Cruiser (PDC for the time being) is 23'6"
> with a designed displacement of 3,090 lb. As I'm separated from myto
> library by over 10,000 miles, the following is from memory. It's a
> single-chine hull with a moderate amount of flare in the topsides
> built of ply over frames and stringers. Some -- and I'm inclined
> agree with them, particularly when you are getting to a boat this21'
> size -- say that this means of construction is easier, or at least
> less time-consuming, than the stitch-and-glue technique used with
> Devlin designs.
> small engine.
>seems
> is a double chine. The double chine seems to work out very well.'
> Earl Gasner
> gasner@a...
> > Howard
Claus
Earl,
If I wanted to save money on building this boat, I would save on the
engine. A Yanmar with propellor shaft, bearings, exhaust and cooling
system, remote controls, rudder, complex installation etc. would not
be cheap. I would instead make a pod aft of the transom and mount a
30 h.p. or so outboard motor on it. I reckon even a 2-stroke outboard
the far side of the transom would be quieter than a diesel in the
middle of the boat, no matter how well insulated. You would still
need a skeg, but it would be smaller than the one on the plan. The
buoyancy of the pod would support the outboard. You could compensate
for the missing diesel engine by adding ballast if necessary, or
carrying more gear. I guess you'd have to carry more fuel somewhere
to get the same range as the diesel. You might even gain enough space
to fit the dinette I wrongly thought was on the original plan.
If you bought plans from PB & F, Mr Bolger would be able to advise on
the feasibility of this suggestion. It would be easy enough to build
the pod by extending the keelson, stringers and bottom ply past the
transom and building a new angled transom to mount the outboard. The
pod would be about half the width of the transom. Of course some
might not like the look of this arrangement...
Howard
Howard
> soundproofed very well (compared to outboard), and would be, Iseems
> assume, much cheaper than an I/O drive.
> > Engine is actually 18hp Yanmar giving an estimated 12 mph max.
> > Cruising speed expected to be 8 mph.
> Thanks. Yes, I have seen those sites. Neither have a boat that
> to be up to the Devlin Windscoter. The one has a listing for a less51gal
> expensive epoxy (system three ????)Devlin has expensive WEST in
> qty. plus very expensive hardner, and much more expensive WEST in4.5
> gal plus hardner qty.
> Earl
hose links are obsolete, or at least I can't reach them.
Aaron
Do you Yahoo!?
Yahoo! Tax Center - forms, calculators, tips, and more
Aaron
Do you Yahoo!?
expensive epoxy (system three ????)Devlin has expensive WEST in 51gal
qty. plus very expensive hardner, and much more expensive WEST in 4.5
Earl
> Having my own copy of BWAOM in hand, I make a couple notes:Outboard rudder seems O.K. to me. Lets you use an inboard that can be
> Outboard rudder. No dinette.
> Engine is actually 18hp Yanmar giving an estimated 12 mph max.here
> Me either.
> If you are interested in boats this size you might like to look
> (http://www.by-the-sea.com/archdavisdesign/)and there are some newThanks. Yes, I have seen those sites. Neither have a boat that seems
> designs about this size here (http://www.bateau.com/).
Earl
> Peter
you. >
O.K. Thanks. (After much grief, I finally found out how to register
built of ply over frames and stringers. Some -- and I'm inclined to
Devlin designs.
I am considering a 'boat of this size' as a replacement for our 21'
camping trailer that we tow with our Jeep Cherokee. My sweetie, our
Westy (dog), and I. Camp on land in the boat. It would not be as good
a camper as our present camper, but it would be a much better boat. I
The Devlin Wind Scoter 22' is $41,000 (??) without power, but Devlin
claims that you can build it for 1/3 of that. Then there is cost of
trailer and cost of power. The Wind Scoter 25' would be more, but I
like the looks of it and the extra size. But Devlin has designed it
for a 135 I/O diesel drive. That is big bucks. Even home built would
small engine.
Just moveing along at displacement speed would be fine with me. I am
would like to build. The interior arrangement looks better to me than
the Scoter25. But I can't tell from the book if I would really like
the looks of it compared to the Windscoter. Hmmmmmmmm.... And I would
remember the number. The speed-length ratio is something over two, so
He calls for an 18 hp Yanmar. Estimated max speed, if I recall, is 10
and foredeck on PDC look rather unattractive and would try to think
of some kind of alternative if I were building one -- maybe a raised
some extent, but a photo of a finished boat is what 'I' really need.
BTW, I have a copy of Gerr's book on scantlings. Bolger's boat seems
I also have a $15 set of 'study plans' for Devlins 25' Windscoter. It
Earl Gasner
gasner@...
> >I would like to know more about this design. Is there a >pictureof the actual boat anywhere?
> >Its design is shown in Bolger's BWAOM. The website lists it as22 or Wind Scoter 25?
> >What does anyone think of it as compared to Devlins Wind >Scoter
> >Earl Gasneror make enquiries, you can write to the address shown at the foot of
> Earl,
> I hope the following doesn't repeat a lot of what you already know.
> "PB & F" is Phil Bolger and Friends. So if you want to order plans,
you. >
> The Plywood Diesel Cruiser (PDC for the time being) is 23'6" x7'5",with a designed displacement of 3,090 lb. As I'm separated from my
Devlin designs.
small engine.
>transom. It could perhaps be called a sedan cruiser with a spacious
>house, with a toilet compartment in the bow, with a large hatch above
> There is a pair of settee-berths under a trunk cabin forward of the
>h.p. Bolger indicates the speed that could be achieved, but I can't
> The engine specified is a shaft-drive Yanmar diesel of, I think, 27
> Devlin's designs all have a kind of shippy character-boat look tothem. PDC is conservative, even old-fashioned, but not particularly
>Yes. The proof of the pudding is in the eating. I can read plans to
Earl Gasner
gasner@...
> Howard
If you are interested in boats this size you might like to look here
> I've never seen a photo of a finished boat.Me either.
>I would like to know more about this design. Is there a >picture of the actual boat anywhere?Earl,
>What does anyone think of it as compared to Devlins Wind >Scoter 22 or Wind Scoter 25?
>Earl Gasner
"PB & F" is Phil Bolger and Friends. So if you want to order plans, or make enquiries, you can write to the address shown at the foot of the emails that are sent from the group i.e. Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349, just in case you visit the group's website rather than have emails sent to you.
The Plywood Diesel Cruiser (PDC for the time being) is 23'6" x7'5", with a designed displacement of 3,090 lb. As I'm separated from my library by over 10,000 miles, the following is from memory. It's a single-chine hull with a moderate amount of flare in the topsides built of ply over frames and stringers. Some -- and I'm inclined to agree with them, particularly when you are getting to a boat this size -- say that this means of construction is easier, or at least less time-consuming, than the stitch-and-glue technique used with Devlin designs.
It has an almost vertical, straight stem and a flat vertical transom. It could perhaps be called a sedan cruiser with a spacious wheelhouse that has the usual wheel and engine controls, a small galley and a dinette, as I recall.
There is a pair of settee-berths under a trunk cabin forward of the house, with a toilet compartment in the bow, with a large hatch above it. There is a reasonably spacious self-draining cockpit aft.
The engine specified is a shaft-drive Yanmar diesel of, I think, 27 h.p. Bolger indicates the speed that could be achieved, but I can't remember the number. The speed-length ratio is something over two, so it could be considered as a planing boat.
Devlin's designs all have a kind of shippy character-boat look to them. PDC is conservative, even old-fashioned, but not particularly stylish. I've always thought that the arrangement of the forehatch and foredeck on PDC look rather unattractive and would try to think of some kind of alternative if I were building one -- maybe a raised foredeck instead of the trunk cabin. Perhaps the boat as designed would look a lot better in three dimensions than it does on paper.
Howard
I would like to know more about this design. Is there a picture of
What does anyone think of it as compared to Devlins Wind Scoter 22 or
Wind Scoter 25?
Earl Gasner
gasner@...
Wind Scoter 25?
Earl Gasner
gasner@...
