Re: SAW BLADES
I must be lucky because the blades I have are 36 teeth 1/16th kerf.
I even fired up the saw to make a test cut(in pain)through some very
knotty 2X4 and it went through like butter.
The Makita hypoid saw really works well also it has a rip fence
attachment to make long cuts almost as well as a table saw. I'm a
happy camper. I'm hoping I can get the doctor to fix me so I can
start building some Bolger boats soon. I wish I had some oak scrap
to test the blade on now. I know, I'll get my wife to build a brick
and get started so I can fulfill myself vicariously through her. It
will never work because she will chip a fingernail and that will be
the end.
John
the end.
John
> I went back to the Western web site and found that the Econ blade
has 24
> teeth.
> HJ
> > John
> > A quick scout of the Western Home page should the 7 1/4 MAT714
on sale for
> > $22.99. There is another blade called the MAT 714econ for $8.99.
I suspect
> > the $22.99 blade is the one that Dave sells, and the $8.99 is a
contractor
> > general use blade. It could also be that a clerk got confused and
put the
> > $8.99 price on blades where it shouldn't be. The blade that I
have that I
> > bought from Dave just says Matsushita, 7 1/4 1/16 kerf 5/8 arbor.
> > Curiousity has overwhelmed me and I am going to order one of each.
> > The blade I have from Dave has absoulutely no competitor in
cutting any
> > kind of laminate or plywood. I do find I get a better glue line
rip in real
> > wood with my Freud thin kerf ripping blade.
> > HJ
I went back to the Western web site and found that the Econ blade has 24
teeth.
teeth.
> John
> A quick scout of the Western Home page should the 7 1/4 MAT714 on sale for
> $22.99. There is another blade called the MAT 714econ for $8.99. I suspect
> the $22.99 blade is the one that Dave sells, and the $8.99 is a contractor
> general use blade. It could also be that a clerk got confused and put the
> $8.99 price on blades where it shouldn't be. The blade that I have that I
> The blade I have from Dave has absoulutely no competitor in cutting any
> kind of laminate or plywood. I do find I get a better glue line rip in real
> HJ
John
The blade I have from Dave has absoulutely no competitor in cutting any kind
of laminate or plywood. I do find I get a better glue line rip in real wood
On Friday 21 March 2003 06:23 pm, you wrote:
> If you don't have the dicount house available, you'll
> never regret buying these blades from Dave. I
> recently got one and used it for the first time last
> weekend, ripping two-by fir. My old table saw usually
> won't take much of that without overloading. With the
> Matsushita, it was like having a new saw. Just
> unbelievable. Sam.
> --- John Cupp <caj@...> wrote:
> > My wife recently bought a saw I have always wanted
> > as a present. It
> > is a Makita 7 1/4" hypoid drive circular saw. I
> > wanted to get a few
> > blades for it so I went to a local chain tool store
> > called Western
> > Tool Supply and to my surprise they had the
> > Matsushita 1/16th thin
> > kerf combination blades that Dave Carnell says are
> > the best blade for
> > woodworking. The best part is they are on sale for
> > $8.99! I bought
> > all I could afford but if you have a Western Tool
> > Supply in your area
> > get there and buy a few. The salesman told me he
> > uses one to cut
> > material to glue together and they have such a great
> > cut he just
> > applies glue because the surface is so smooth with
> > no need for
> > sanding or prep work.
> > It was a great find for a Bolger builder and I
> > don't mean to take
> > away customers from Dave Carnell but at $8.99 it was
> > to good a deal
> > to pass up.
> > John
unbelievable. Sam.
Do you Yahoo!?
Yahoo! Platinum - Watch CBS' NCAA March Madness, live on your desktop!
http://platinum.yahoo.com
unbelievable. Sam.
> My wife recently bought a saw I have always wanted__________________________________________________
> as a present. It
> wanted to get a few
> called Western
> the best blade for
> $8.99! I bought
> Supply in your area
> uses one to cut
> cut he just
> no need for
> don't mean to take
> to good a deal
> to pass up.
> John
Do you Yahoo!?
My wife recently bought a saw I have always wanted as a present. It
is a Makita 7 1/4" hypoid drive circular saw. I wanted to get a few
blades for it so I went to a local chain tool store called Western
Tool Supply and to my surprise they had the Matsushita 1/16th thin
kerf combination blades that Dave Carnell says are the best blade for
woodworking. The best part is they are on sale for $8.99! I bought
all I could afford but if you have a Western Tool Supply in your area
get there and buy a few. The salesman told me he uses one to cut
material to glue together and they have such a great cut he just
applies glue because the surface is so smooth with no need for
It was a great find for a Bolger builder and I don't mean to take
away customers from Dave Carnell but at $8.99 it was to good a deal
to pass up.
John
to pass up.
John
