Re: Robb White's perfect dinghy
> Which Bolger boat fits this description?
From the database:
Yacht Tender design #499
Auray Punt design #599
Tahiti Tender design #655
Donovan's Tender design #647
...might fit.
Of these, I only know of the
Auray Punt. Which obviously
planes, and might row nice?
Can any body describe the
other three? What were
#655 and #647?
I can't help but observe that a stone skipped across a pond appears to
'plane'..... An airline pilot once observed to me that, given enough power,
one can fly a brick (non-Bolger type).
David Romasco
Sent: Friday, March 28, 2003 2:18 AM
Subject: Re: [bolger] Re: Robb White's perfect dinghy
of course a tortoise can plane, I have towed mine often. no problem
- I felt it would work better with the painter attached at a lower
position, but never tried.
hannes
On 27 Mar 2003, at 15:31, Bruce Hallman wrote:
> --- "welshman@p..." <welshman@p...> wrote:
> Though, if Nymph can plane,
> so could a Tortoise.
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=245314.3072841.4397732.2848452/D=egroupweb/S=17050657
91:HM/A=1495890/R=0/*http://www.netbizideas.com/yheb42>
<http://us.adserver.yahoo.com/l?M=245314.3072841.4397732.2848452/D=egroupmai
l/S=:HM/A=1495890/rand=642840610>
hannes
I remember someone's comment that an Elegant Punt made a better yacht
tender than a Nymph. Perhaps more stable with the flatter bottom ??
The Nymph probably look better.
Charles
I'm still not convinced.
The Nymph, a displacement dinghy shown "planing" behind Selkie has
her bow safely high in the air, because she has a curved keel in
profile. A proper planing dinghy with a straight keel line aft will
want to ride flat, and may well put her bow under at times, in waves
or wake. I had mind to building a Bolger Bee, which would give a
fast fun planing boat, and also a tender. I asked Bolger who said
Bee could make a tender, but a heavy weight would have to be set in
the stern for towing. Now this would be a pain in the backside, and
I would certainly not trust Bee's towing ability for my outboard to
be that substantial weight.
DonB
--- Inbolger@yahoogroups.com, "futabachan" <futabachan@y...> wrote:
> Don:
> > Surely he is only meaning a tender for a planing mother ship?
> > I can't see any merit in a planing tender for a displacement
boat.
> The mother ship is longer than the dinghy, so even if it is a
> displacement boat, its hull speed will be higher. So a towed
> dinghy moving at the longer vessel's hull speed will attempt to
> plane, and will act as a brake on the larger vessel if forced
> not to.
> Susan Davis <futabachan@y...>
--- Inbolger@yahoogroups.com, "Bruce Hallman"
I tow my Tortoise at about 5-6 knots behind my Tanzer sailboat. It
just settles back on the aft 2/3 of the hull and planes nicely with a
rythmnic slap on the flat bottom. You'd hardly know it's there until
you get into waves that make the sailboat slow and surge. At that
point, you would rather carry any dinghy on-board.
> Most tenders will plane empty,
> even if they are not planing hulls.
Nymph on plane <g>! The light weight
must be the key. So I suspect that
a SpurII must also plane, sized at
16 feet by 4'6" weighing 100 lbs.
Another Robb White 'perfect dinghy'
criteria which I didn't mention
before, was postive flotation.
SpurII doesn't have that, but
I think that blocks of foam
could easily be fitted under
the seats.
Another criteria for a yacht
tender [for me] would be:
good looks, which SpurII has.
Bolgeristas,
I started a related thread about dinghys over in Boatdesign under the
subject "Wake" that may be of interest to you all. I had thought of
copying and pasting them here, but there are too many of them.
Paul
Most tenders will plane empty, even if they are not planing hulls. For
maximum Bolger input on this check out the Nymph planing behind Mark
Zeiger's Martha Jane "Selkie" at the bottom of
http://www.alaska.net/~fritzf/Boats/MJ/Sailing.htm
Don:
> I can't see any merit in a planing tender for a displacement boat.
not to.
Susan Davis <futabachan@...>
mail2web - Check your email from the web at
http://mail2web.com/.
Don:
not to.
DonB
--- Inbolger@yahoogroups.com, "Bruce Hallman" <brucehallman@y...>
> I was just re-reading Robb White's
> article about the perfect dinghy,
> in the June 1, 2002 MAIB. Whew!
> Is that guy long winded? Four
> columns into it, he gets to his
> (really excellent) point, that
> dinghies used as yacht tenders
> need to be able to both row *and*
> plane well. He describes the
> ideal shape as similar to an
> aluminum canoe;
> [Robb White:]
> "I found out that a long
> (about 16 feet) narrow
> (five feet or so) very
> light (less than a hundred
> lbs) skiff with a planing
> boat configuration to the
> bottom will work just fine...".
> My question is:
> My initial reaction was SpurII, but it has
> a bit of rocker in the bottom plank, and
> probably would get squirelly if you towed
> it at planing speed.
aluminum canoe;
[Robb White:]
My question is:
