[bolger] Re: Gypsy as a sloop?
>I was thinking of adding angled shrouds that along with a bit heftier
>mast and some rake should handle the forestay tension...
>like I said.. working on caculations...
>have gotten as far as working out the center of effort on a
>40sq.ft./20sq.ft. main/jib with a fractional jib...(ie not to the
>masthead) havent figured where the mast will go.. and probably need
>to rework it all to figure in some mast rake... but crunching the
>numbers is a fun armchair sailing excersise if nothing else...
Do you have the hull already built? If not, are you dead set on a
Gypsy hull? If not dead set, maybe a Surf or a Zephyr would give you
an easier platform for experimentation?
Just a thought. What ever you end up doing, take pictures and good luck!
C.E.P.
415 W.46th Street
New York, New York 10036
Mobile (646) 325-8325
Office (212) 247-0296
--- Inbolger@yahoogroups.com, "Jack&Lois" <jalo@i...> wrote:
> I assume by sloop you mean with a jib (?). I've considered this as
well with
> both Gypsy and June Bug. What stops me is the need of a fore stay,
which in
> turns requires a back stay. Last summer I had some success with a
Tyvek 72
> sq. ft. sprit rig with sprit boom. I built too much camber into it,
so it
> looked like a big baggy advertisement for 3 M Corp. But the Gypsy
handled
> the extra sail with no trouble and we gave the Wind Sprints at the
Mahone
> Bay Wooden Boat Festival races a run for their money. The shorter,
stouter
> mast would probably take a fore stay without the need of counter
pull from
> aft. At any rate all the best with your experiments. Let us know
how it
> goes.
> jeb, seeing glimmers of light at the end of the tunnel with Micro
> restoration on the timidly spring time shores of Fundy
A Windsprint rig can drop right in place of the 59 sq. ft. leg o'mutton on
Gypsy without moving any of the elements of the rig. The centers of area of
both sails are in the same fore and aft plane. You'd need a heavier mast for
the 115 sq. ft. balanced lug, but it'd theoretically work. In practice it
may be too powerful for Gypsy's narrow hull.
JB
Sent: Wednesday, April 09, 2003 8:32 PM
Subject: [bolger] Re: Gypsy as a sloop?
| > What stops me is the need of a fore stay, which in
| Your mention of the Windsprints makes me wonder if going to a
| balanced lug on a Gypsy would be an easy way to gain sail area in
| equal measure fore and aft of the CLR without going to a stayed mast?
| Of course, that doesn't make a sloop. . . . but it sure would go fast.
| All best,
| Garth
| Bolger rules!!!
| - add your comments at the TOP and SIGN your posts and <snip> away
All best,
Garth
I assume by sloop you mean with a jib (?). I've considered this as well with
both Gypsy and June Bug. What stops me is the need of a fore stay, which in
turns requires a back stay. Last summer I had some success with a Tyvek 72
sq. ft. sprit rig with sprit boom. I built too much camber into it, so it
looked like a big baggy advertisement for 3 M Corp. But the Gypsy handled
the extra sail with no trouble and we gave the Wind Sprints at the Mahone
Bay Wooden Boat Festival races a run for their money. The shorter, stouter
mast would probably take a fore stay without the need of counter pull from
aft. At any rate all the best with your experiments. Let us know how it
goes.
