Re: Fuel Tanks
> Thanks for all the input from the group.Jeff,
> Jeff
Check with the EAA - Experimental Aircraft Assoc. - www.eaa.org
Fiberglass/foam/epoxy tanks are rather common in homebuilt and
kit built aircraft. There is a lot of experience there in composite
construction.
Charles
fuel tank manufacturers (I cannot remember which, but it was a very
well known name) would not guarantee the integrity of their tanks.
The poster had a crack in one of the seams and, although brand new,
the mfg would not replace it.
It doesn't sound believable, but check before buying
> Adapt a diesel o/b to run on Rust Check and corroding tanks will beI have read, a while ago, a post that said that one of the plastic
> the least of your problems.
You know they make flux core welding wire for stainless?
(takes a bunch of amps, unless you cheat...)
Sent: Tuesday, April 22, 2003 4:13 PM
Subject: Re: [bolger] Re: Fuel Tanks
> Would mild steel work okay for fuel? Salt air?
> I certainly can weld it up but did not think it would work. I've heard so
> much about rusting tanks.
> Anyone know any different?
> Jeff
> From: "Richard Spelling" <richard@...>
> Sent: Tuesday, April 22, 2003 2:41 PM
> > So, Jeff, you have a welder. You weld your own trailers up.
> > Why don't you make your tank out of sheet metal?
> > From: "jeff" <boatbuilding@...>
> > Sent: Tuesday, April 22, 2003 1:58 PM
> > > Funny thing is that they didn't show up on any of my searches. I assume
> > > because their front page doesn't mention fuel tanks.
> > > Anyway, thanks for the link, I'll print out their catalog.
> > > Jeff
> > > From: <welshman@...>
> > > Sent: Tuesday, April 22, 2003 12:43 PM
> > > > Jeff
> > > > I know your pretty good at research on line. Have you done a complete
> > > > search for ready mades that would fit your measurements?
> > > > Its hard to believe that Ronco Plastics with 400 tanks doesn't have
> one
> > > > that is close.
> > > > HJ
> > > > I was thinking Coast Guard rules and regs but after looking of the
> link
> > > that
> > > > was sent, there is very little to worry about other than common sense.
> I
> > > > had not thought of making them removable. That would solve a lot of
> the
> > > > degradation issues if they where to come up. Also, there are some
> > > products
> > > > out there that will allow your to coat the interior of the tanks to
> help
> > > in
> > > > the protection from Methanol / Alcohol problems.
> > > > I like the idea of simple rectangular tanks that I could lift out
> should I
> > > > have problems. Coast Guard regs simply have more to do with
> ventilation
> > > and
> > > > the tank connections. Not the tank itself.
> > > > Jeff
> > > > mail2web - Check your email from the web at
> > > >http://mail2web.com/.
> > > > Bolger rules!!!
> > > > - no cursing, flaming, trolling, spamming, or flogging dead horses
> > > > - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred'
> posts
> > > > - add your comments at the TOP and SIGN your posts and <snip>
> away
> > > > - To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA,
> > > 01930, Fax: (978) 282-1349
> > > > - Unsubscribe:bolger-unsubscribe@yahoogroups.com
> > > > - Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.com
> > > > Your use of Yahoo! Groups is subject to
> > > Bolger rules!!!
> > > - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts
> > > - add your comments at the TOP and SIGN your posts and <snip> away
> > Your use of Yahoo! Groups is subject tohttp://docs.yahoo.com/info/terms/
> > Jeff
> > > Jeff
one
> > > that is close.
> > > HJ
link
> > that
I
> > products
help
> > in
should I
ventilation
> > and
> > > Jeff
> > > Bolger rules!!!
posts
away
>aluminum, plus flexible bladder tanks too. I got a nice 50 gal. oneI knew it! That whole anti rust thing is a front you're really a
>for my houseboat that should increase the rand nicely (it had a 16
>gal). Even more in the hard copy catalogue.
speculator in S.African currency!
C.E.P.
415 W.46th Street
New York, New York 10036
Mobile (646) 325-8325
Office (212) 247-0296
>I recently sent an email to Progressive Epoxy Polymers, Inc. and got theBeulher (is that how he spells his name?) of "Backyard Boat Building"
>following reply. Larry at Raka said about the same thing so looks like it a
>non-issue building fuel tanks. I won't risk it.
fame seems to think that it ain't nothing to knock together a plywood
pattern and then take it to a fabricator to have a stainless tank
built that will custom fit your space. He's not known for suggesting
expensive options.
HTH,
C.E.P.
415 W.46th Street
> Jeff
> > Jeff
> > Its hard to believe that Ronco Plastics with 400 tanks doesn't have one
> > that is close.
> > HJ
> > I was thinking Coast Guard rules and regs but after looking of the link
> that
> > was sent, there is very little to worry about other than common sense. I
> > had not thought of making them removable. That would solve a lot of the
> products
> > out there that will allow your to coat the interior of the tanks to help
> in
> > I like the idea of simple rectangular tanks that I could lift out should I
> > have problems. Coast Guard regs simply have more to do with ventilation
> and
> > Jeff
http://www.westmarine.com
and search on the word "tanks" for over 70 sizes in plastic and
Bruce Hector
Bruce Hector
Hi Jeff:
In the past self made epoxy lined fuel tanks were common, but we've started
seeing stories on the web about the new additives in gasoline that turn the
epoxy (at least some epoxies) into mush. - the new thinking is not to use
epoxy with 'modern' gasolines.
PAUL OMAN ----- Progressive Epoxy Polymers, Inc.
Frog Pond Hollow - 48 Wildwood Dr - Pittsfield NH 03263
603-435-7199 FAX 603-435-7182 VISA/MC/Discover
info@...http://www.epoxyproducts.com
Boating site:http://www.epoxyproducts.com/marine.html
Hi Jeff:
> Jeff
> that is close.
> HJ
that
products
in
> Jeff
that is close.
I was thinking Coast Guard rules and regs but after looking of the link that
degradation issues if they where to come up. Also, there are some products
out there that will allow your to coat the interior of the tanks to help in
have problems. Coast Guard regs simply have more to do with ventilation and
that is close.
As I see it, the great advantage is that the tank can be designed to use that odd space and not waste those nooks and crannies. I'd certainly want the removable feature anyway to allow me to inspect and keep track of what might be --or, not be--going on. Peace of mind whilst in your floating cocoon is a definate advantage. Re; the pressure test---I havn't a clue.I plan to glass an old metal tank that was supplied as a specific shape to fit a classic old FG runabout. it is certainly removable so I will be watching it carefully.
Sent: Tuesday, April 22, 2003 11:50 AM
Sent: Tuesday, April 22, 2003 10:35 AM
> my read is that ply and epoxy is OK but must be removable if for gas. OK
to build-in for diesel. It must be assumed that sufficient strength will be
designed-in for whatever is done. Epoxyproducts has some material
specifically designed for fuel.
> From: proaconstrictor
> Sent: Tuesday, April 22, 2003 1:41 AM
> Subject: [bolger] Re: Fuel Tanks
> As was mentioned, there is stuff in the Gougeon Book. Reading
> between the lines, my guess is the regulatory and liability stuff
> overtook their ideas, not function. I seem to remember some follow-
> up questions in their free mag along these lines.
> There are scantlings in the book. They also mention that the epoxy
> is fine for gas and fuel oil.
> What CG problem are you concerned with? Your boat sounds like it
> will have a these tanks in the same position as the one's drawn in
> the plans, so boat CG should be relatively unchanged. The "Gougeon"
> tanks are removeable.
> Yahoo! Groups Sponsor
my read is that ply and epoxy is OK but must be removable if for gas. OK to build-in for diesel. It must be assumed that sufficient strength will be designed-in for whatever is done. Epoxyproducts has some material specifically designed for fuel.
there are a bunch tank mfgs. in the us. look into a few truck and auto retailer web sites. scott
Sent: Tuesday, April 22, 2003 6:58 PM
> Jeff
> that is close.
> HJ
that
products
in
> Jeff
--- "Jeff" <boatbuilding@g...> wrote:
he knows, if you can, how to
do it.
> Has anyone built in fuel tanksAsk Larry at Raka, I bet that
> using epoxy and fiberglass?
do it.
You need to read the Coast Guard Regulations concerning fuel tanks. They are
found here:
http://www.uscg.mil/d8/mso/louisville/WebStuff/comdtpubp16761_3b.pdf
Vince
found here:
Vince
I have a fuel tank that I built to fit into a specific space in
order to maximize fuel capacity. I would not use epoxy though since
it is susceptible to alcohol which can permeate through the epoxy. I
used isothalic polyester resin which is supposed to be resistant to
such problems. Three years old now and checked regularly with zero
problems. Make it strong with internal baffles and make sure that
the inside surfaces are resin rich. Pressure test the whole thing
before using. My tank is supported with a belt and suspenders kind
of arrangement of built in flanges screwed to ledgers and hung in
nylon webbing straps.
I used sheet fiberglass as a base material but would use plywood if
I did it again since it is far easier to work with. I am more
comfortable with this tank than I would be with an aluminum or steel
one in the marine environment.
Jeff,
Do a Google groups search on the subject. The rec.boats.building
newsgroup has had several discussions of this, and the consensus is not
to do it.
Ford Walton
to do it.
Ford Walton
Jeff wrote:
> Has anyone built in fuel tanks using epoxy and fiberglass?
> Does it work?
> Will the epoxy degrade in the tanks?
> Would there be any issues with the CG regarding these tanks?
> I have a pair of 50 gallon fuel tanks per Bolgers plans for the
> Wyoming but I'm thinking of doing my own so they can remain under
> the cockpit floor hidden completely from view. The problem is that
> the space is odd shaped and no fuel tanks will fit other than the
> large T50N models that Bolger shows.
> Thanks
> Jeff
> www.dreamwater.net/cosailor
Hi Jeff, No I havn't built in fuel tanks however there is a short
piece in the Gougeons book on epoxy construction (I have the older
edition). My reading tells me that at the time there was not a lot of
experience. They warn that wood/epoxy tanks can burn even with fire
retardant. On the other hand steel tanks can heat up and rupture. The
actual epoxy construction is highly resistant to the fuels themselves.
If I were contemplating building fuel tanks I would go to the epoxy
people for information whether it was West, System3 or MAS etc.
Bob Chamberland
Bob Chamberland
> Does it work?
> Thanks
> Jeff
Does it work?
Thanks
Does it work?
Thanks
