Re: Ingenious Trailer
--- Inbolger@yahoogroups.com, "dbaldnz" <oink@p...> wrote:
very hard landings and breakage is very rare. They do bend sometimes
in a "crash".
> True, though in this case the spring was very strong in relation toknow
> the weight of boat. Anyway, it lasted for years and as far as I
> is still going.It sounds very similar to a small Cessna landing gear. They can take
in a "crash".
the weight of boat. Anyway, it lasted for years and as far as I know
is still going.
But more conventional trailer designs can break too. I had a boat
trailer with a tubular steel main spine, which folded in half at
reasonable speed on the highway, luckily without killing the boat.
It had rusted from the inside. The outside looked fine.
I would never have a closed steel tube again....only open channel or
angle sections.
DonB
--- Inbolger@yahoogroups.com, "Richard Spelling" <richard@c...>
is still going.
angle sections.
DonB
> Not a bad idea.the road
> However, if the weight changes on your trailer, your tires go down
> canted in or out, getting uneven wear.on the
> Also, with a regular trailer, if you bust a spring, the suspension
> trailer collapses, but the boat is ok. Been there, done that.Twice. If his
> spring brakes his boat hits the dirt.it's
> But, as you say, an interesting out of the box experience.
> From: "dbaldnz" <oink@p...>
> Sent: Friday, April 25, 2003 10:29 PM
> Subject: [bolger] Ingenious Trailer
> > I once used to race a Finn class, a 15ft reasonably heavy for
> > type racing dinghy. One of the stalwarts of the Finns here was anhis
> > engineer. He made a very elegant, light and simple trailer for
> > boat.leaf
> > Instead of an axel, he had a large, probably commercial vehicle
> > spring, curve upwards. On each end he welded the hubs, thussaving
> > the weight of a suspension system. The spine/drawbar was atapered
> > timber/ply box section tube, epoxied, with a hitch bolted on oneabout
> > end, two boat supports on top, and bolted to the spring. And
> > the only metal to corrode was the spring.horses
> > This worked very well, and was a brilliant example of lateral
> > thinking, to my mind.
> > DonB
> > - no cursing, flaming, trolling, spamming, or flogging dead
> > - stay on topic, stay on thread, punctuate, no 'Ed, thanks,Fred' posts
> > - add your comments at the TOP and SIGN your posts and<snip> away
> > - To order plans: Mr. Philip C. Bolger, P.O. Box 1209,Gloucester, MA,
> 01930, Fax: (978) 282-1349http://docs.yahoo.com/info/terms/
dry rotted or failed for some reason unrelated to wearing out? It
might run hotter if it is canted a lot though.
Also the trailer in question carried a racing dinghy. I imagine the
load could be pretty much the same every trip. Just carry any extras
in the tow vehicle.
On another issue I wonder about the wisdom of welding to a tempered
spring.
Pete
> However, if the weight changes on your trailer, your tires goTrue, but how often have you seen a trailer tire wear out before it
> down the road canted in or out, getting uneven wear.
in the tow vehicle.
spring.
Pete
On the subject of busted springs, a friend of mine in the boat and trailer
selling buisness for a number of years, had several springs bust on him.
Because of this he would only use torsion bar suspension.
> Not a bad idea.
> However, if the weight changes on your trailer, your tires go down the road
> Also, with a regular trailer, if you bust a spring, the suspension on the
> trailer collapses, but the boat is ok. Been there, done that. Twice. If his
Not a bad idea.
> I once used to race a Finn class, a 15ft reasonably heavy for it's
> engineer. He made a very elegant, light and simple trailer for his
> boat.
> Instead of an axel, he had a large, probably commercial vehicle leaf
> spring, curve upwards. On each end he welded the hubs, thus saving
> the weight of a suspension system. The spine/drawbar was a tapered
> end, two boat supports on top, and bolted to the spring. And about
> DonB
boat.
DonB
boat.
DonB
