[bolger] Re: Weighing In on the issue of small square boats
richard <richar-@...> wrote:
second boat goes easier than the first.
>.. toying with making a square canoe...
> Basicaly a rectangular box, 2 ft wide, 1 ft high. About 18 inches
from the > ends, I curve the sides and bottom together with the same
curve. Center 5
> feet of the boat will be dead flat...
> Comments welcome.
Richard, let us know how it works -- I am interested.
Phil Lea
Russellville, Arkansas
That projected canoe sounds pretty tender to me. Do you plan to sit on the
bottom and use a double paddle like a kayak?
Bill, who built a stripper that is just too tender by sooooo small an amount.
Teakdeck@...wrote:
> 1. The second boat goes easier than the first.
yep. and the third and forth go even faster...
> 2. Tried some 5200 glue? I didn't like it. Went back to Weldwood.
tried weldwood. don't like it, will stick to epoxy. (with gloves)
may experiment with construction adhesive ... toying with making a square canoe...
Basicaly a rectangular box, 2 ft wide, 1 ft high. About 18 inches from the ends, I
curve the sides and bottom together with the same curve. Center 5 feet of the boat
Comments welcome.
> 3. Building as light as I can because I want to cartop this time (I trailer
> my Windsprint).
build light to pickup truck too. also, lead in rudder and center/lee/sideboard add
weight... for some reason
> 4. Plan to use outside chines. I like the outside chine and I think it makes
> clamping the bottom on much easier.
maybe a little easier. make nice rubrails too... <grin>
> 5. I have alot of clamps now. On my Windsprint I did not. More is better.
use drywall screws for clamps.
> 6. I put together a 2" square cedar mast. Haven't shaved it to size yet. Will
> let you know how it turns out. Masts have been my nemisis.
I've only broken one mast, and I tend to go sailing on windy days....
Knots in your mast are BAD...
> 7. I plan to deck over a litte more of the boat and not put seats at the ends.
> 8. I'm going to use plastic milk bottles for flotation (under the decks of
> course).
I prefer water-tite cambers, especialy on small boats. The storage space is very
handy.
> 9. Regarding lifting: If you are by yourself you should arrange to lift only
> half the boat at a time, right?
> 10. 1/4 inch Luan(sp) plywood is 19 bucks a sheet at Home Depot here in Oly,
> Wa.
bummer, it's less than $10 here in OK. How much is AC fir in Wa?
> 11. I hope to be able to use three rigs with this boat: the designed sprit
> rig, a lateen rig (one I made up for my Windsprint but still haven't tested)
> and third a design of my own experimenting with battens on a balanced lug
> sail.
> 12. I'm not using any epoxy. I'm allergic to it. I'm not fiberglassing
> anything, not even the chines. The hull is cheap. If it only lasts 10 years
> I'll build another one.
> 13. I think my next investments in tools will be a really nice, high powered,
> big table saw and an air powered staple gun like Greg uses.
Table saw is handy, as is a power hand planer.
Tried using my staple gun on Entropy... went back to drywall screws. They clamp
and hold at the same time, and you can get fine adjustments in the clamping
pressure, and if you put them in the wrong spot, you back them out and run them in
again.
The staples didn't pull the work together very well. Tried ring shank nails too...
I'll stick to screws. Bought SS deck screws so I could leave some of them in
permanently...
Bolgeramos,
What an interesting thread. Right now I'm building a version of June Bug on
my way to Oldshoe. Started this weekend. Here are a few thoughts:
my Windsprint).
course).
Wa.
sail.
More to come,
MIke Masten
