RE: [bolger] 7.5 horse Sears (Ted Williams) outboard
Howdy Claude
> -----Original Message-----
> From: Claude Conn [mailto:claude_the_sailor@...]
> What say you? Is this thing worth fooling with, or should I
> just give
> up now, before spending time and money on it?
Oh No it's Worthless. Way too much trouble to deal with. You should
get rid of it. To help you out of a jam, just pack it in a stout
container and ship it to me. I will dispose of it properly. :)
See Ya
Have Fun
Bruce
Claude I have a Sears Gamefisher 9.9 great little motor parts are
available from sears. You decide not to mess with it contact me
we'll see what we can do to acquire it from you.
--- Inbolger@yahoogroups.com, "Claude Conn" <claude_the_sailor@y...>
> Gentlemen (Gentlepersons),
> I have recently acquired, at no cost, a 7.5 horse sears outboard,
> fully equipped with no prop. After beating the mice out from under
> the cover and knocking most of the dirt off, I checked for
> compression. Either the compression is good, or there is only a
mild
> coat of rust on otherwise sloppy cylinder walls.
> This motor would be used on my Micro until I could afford to buy a
> decent 5 or 6 horse 4 stroke.
> What say you? Is this thing worth fooling with, or should I just
give
> up now, before spending time and money on it? I was told that this
> thing turns backwards from most motors and so it takes a prop that
> rotates opposite and so is harder to find except at Sears and at a
> high dollar.
> The only reason I got this thing is because it was free, so it's no
> loss if it's not worth fooling with. By the way, it has solid-
state
> ignition, so it can't be more than 25 years old (?.
> Any advice will be appreciated. I eagerly await your knowledgeable
> response.
> Claude Conn
> Awaiting Spring here near the Tip O' The Mitt. Atlanta, Michigan.
compression. Either the compression is good, or there is only a mild
What say you? Is this thing worth fooling with, or should I just give
high dollar.
loss if it's not worth fooling with. By the way, it has solid-state
response.
Claude Conn
