Re: Preperation for ReEpoxying
You should wash cured epoxy with water before trying to stick something
to it as it often has slimy "blush" that appears and keeps next thing
from getting a good grip. Some people like to use Scotchbrite plastic
scouring pads when they do this, tho in my experience the blush comes
right off with a sponge and water. Of course I think Scotchbrite will
dull up the surface, and you really want to scuff up the surface before
putting on more epoxy if the first epoxy has more than a couple of days
to cure (I use sandpaper). Before that, you get a chemical bond, or so
I've heard. Wash off the blush in any case unless the first epoxy is
still goopy.
Read the book!
still goopy.
Read the book!
>choochawaga wrote:
>Some one said something about Scotchbrite(?) and doing something to
>something and letting something something before I did something if I
>was going to over epoxy and I can't find that post...could someone
>please tell me again...
I think it goes like this:
Scotchbrite and rinse epoxy before you add more epoxy (/fiberglass).
You may sand for added tooth (some say), but dont omit the preliminary
Scotchbrite and rinse, or youll be spreading the amine blush around
with the sandpaper.
-Bill
Sent: Monday, May 19, 2003 7:13 AM
Subject: [bolger] Preperation for ReEpoxying
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=251812.3170658.4537139.1261774/D=egroupweb/S=1705
065791:HM/A=1564415/R=0/*http:/www.netflix.com/Default?mqso=60164784&par
tid=3170658>
<http://us.adserver.yahoo.com/l?M=251812.3170658.4537139.1261774/D=egrou
pmail/S=:HM/A=1564415/rand=599306338>
with the sandpaper.
-Bill
tid=3170658>
--- Inbolger@yahoogroups.com, "choochawaga" <soulinvictus@c...>
Some epoxies(most) leave a waxy film on their surface after
curing.This is called amine blush. This film must be removed before
proceeding with further epoxy or painting of that same surface.A
common Scotchbrite scouring pad and warm soapy water will remove this
film. If the film is not too thick and waxy, a thorough light sanding
will also remove and prepare the surface for further finishes.
Sorry to hear about your evil dog and ensuing problems. Someone
has a rifle to lend you,if it will help :-0
Then again, there is always the fun filled,sun drenched,manly
sport of golf...............
Good luck with your eye,
Peter Lenihan.
> Some one said something about Scotchbrite(?) and doing something toI
> was going to over epoxy and I can't find that post...could someoneDavid,
Peter Lenihan.
