Re: Re-Epoxying
Amine blush is water soluble, and comes off with plain water. I've
used ammonia on occasion, but not every time -- I don't believe it's
necessary. Your water and Scotch-brite will do it. Rinse well.
Jamie Orr
Jamie Orr
--- Inbolger@yahoogroups.com, wmrpage@a... wrote:
> In a message dated 5/19/03 5:40:06 PM Central Daylight Time,
quohog@a...
> writes:
> > {you can add a few drops of
> > household Ammonia if you're really paranoid}.
> Any chemists out there? I've been using plain old tap water and a
> Scotch-Brite pad, but my efforts have yet to be exposed to the
environment, so this will
> be one more item to worry about late at night, absent more pressing
anxieties.
> I thought amines are "basic". In which case an acidic wash would
seem to be
> indicated, e. g. a dash of vinegar. Non?
> Ciao for Niao,
> Bill in MN
Don't use vinegar.
It may cause problems if you need to add more epoxy/glass
laminations. If you did not use the exact amount of vinegar, the
remaining would need to be neutralized.
Apparently the amines are water soluble. I have just used water and
a mild dishwashing soap to clean the blush off. I have used vinegar
to clean tools that I used with the epoxy...the vinegar turns the
uncured epoxy into a milky colored gelatinous mess.
> I thought amines are "basic". In which case an acidic wash wouldseem to be
> Ciao for Niao,
> Bill in MN
In a message dated 5/19/03 5:40:06 PM Central Daylight Time,quohog@...
writes:
Scotch-Brite pad, but my efforts have yet to be exposed to the environment, so this will
be one more item to worry about late at night, absent more pressing anxieties.
I thought amines are "basic". In which case an acidic wash would seem to be
Ciao for Niao,
Bill in MN
writes:
> {you can add a few drops ofAny chemists out there? I've been using plain old tap water and a
Ciao for Niao,
Bill in MN
OR if you use non-blushing epoxy, you DON'T have to go thru all that.
Sent: Monday, May 19, 2003 5:33 PM
Subject: [bolger] Re: Re-Epoxying
'choo' -
When epoxy 'cures' it sometimes has a 'film' called Amine Blush. You
NEED to remove it before applying ANY further coats of epoxy or
finishes.
Use a ScotchBrite pad {or other plastic 'steelwool' product}with some
warm water and a dash of liquid detergent {you can add a few drops of
household Ammonia if you're really paranoid}. Scrub well and rinse
thoroughly.
Typically, you can disregard this IF you schedule multiple applications
{of epoxy} about 8 to 12 hours apart. You also avoid sanding between
coats using this technique.
Regards & Good Luck,
Ron Magen
Backyard Boatshop
[This is what I'll be doing tomorrow to a new hatch. Then I'll be
applying several coats of varnish]
Message: 15
Date: Mon, 19 May 2003 11:13:27 -0000
Subject: Preperation for ReEpoxying
Some one said something about Scotchbrite(?) and doing something to
something and letting something something before I did something if I
was going to over epoxy and I can't find that post...could someone
please tell me again...
Yahoo! Groups Sponsor
'choo' -
finishes.
thoroughly.
Ron Magen
Backyard Boatshop
Message: 15
finishes.
thoroughly.
Ron Magen
Backyard Boatshop
Message: 15
