Re: #481 houseboat flip
--- Inbolger@yahoogroups.com, "Paul McLellan" <bysc@i...> wrote:
The bottom has one
> coat of epoxy, then I glued the fibre glass with epoxy, put an
extra
> coat of glass on the forward 8 feet, faired it all with thickened
> epoxy, then 2 light coats with a roller. I had planned to let it
cure
> for a week then use 3 or 4 coats acrilic latex paint. I had not
> thought about the expensive paint for the bottom as I thought it
was
> overkill but you got me thinking. How much would it take and cost,
> what brand in Canada etc, etc,? All suggestions considered.
Hi Paul,
If you are intending on trailering her around, then I would think
that your epoxy bottom schedule is more then adequate.However, if
you plan on trailering to a body of water for a full season of
immersion,then an epoxy barrier coat won't hurt. Mind you, this is
what I have done in the past to my boats( they sit in the water 6
months a year) and have yet to report any problems.There are many
different approaches for the same expected performance.Alot depends
on how well surfaces were prepared,material scantlings and even
whether you used"regular" epoxy or a "laminating" epoxy
when 'glassing etc....The houseboat looks like the kind of boat that
will have to take the odd hit from something,be it "un-charted"
rocks, inviting beach heads or even branches and twigs :-) If your
boating is seasonal(and it should be unless you're putting skis on
her) then you can join the masses each spring for the ritual
of "preparing the boat for another season",a manly sort of
expression thrown around at the office to terrify those accustomed
to hiring lawn mowers or to be left as a note on the fridge door
when one seeks release from cabin fever. There will be no shortage
of friends ready to assist in liberating quantities of goodies from
you,even if it means doing some grunt work on your houseboat.
For bottom paint, I've always used interlux BOTTOMKOTE, available
at most Canadian Tire stores. I can't recall the coverage,but would
think that a litre ought to cover your bottom,if you do not go crazy
with it.Check the can before buying to verify actual coverage
figures.
Farley Mowat has all sorts of interesting names floating through
his books,be they characters or places."Shanteuse" IS nice but
maybe "Chanteuse" more precise for the singing she'll do on a breezy
night? Maybe,if she is frequently trailered, "Chansonnette"( a short
happy tune)?
Anyway Paul, you'll have many occassions to be inspired.The name
may even come to you in a dream!!
Pierre"Peter" Lenihan.................
Paul McLellan wrote: "enjoying a cup of tea while awaiting the "cure"
and hopefull able to join the chat group tonight, Sunday may 25th."
To whit I ad: "Me too!" I'll be online sometime after 8 p.m. EST.
Chat wi' ye' then!
Bruce HEctor
Chat wi' ye' then!
Bruce HEctor
Peter wrote " I've gotta ask however,if you only have 7' headroom in
your"shop" how are you going to go about installing the cabin and roof
on the hull once the hull is righted and back inside?
Good Luck with the turnover!
Peter, I will get it into the big barn for the completion. No, too bad
the windermere won't fit in there also. Great suggestions from all
especially about the moving, flipping and finish. Should I go for
that extra coat of epoxy while it is upside down. The bottom has one
coat of epoxy, then I glued the fibre glass with epoxy, put an extra
epoxy, then 2 light coats with a roller. I had planned to let it cure
thought about the expensive paint for the bottom as I thought it was
what brand in Canada etc, etc,? All suggestions considered. I really
hear the suggestion that you only get one chance to really get the
bottom right as the next time it is upside down I don't want to be
there. The only real problem I have had so far is the name of the
boat. #481 Houseboat seems a bit dull and pedantic, My other boats
are called the "Happy Adventure" #1, #2, #3 and with Farley Moat's
blessing I could continue but the name I really like but has been
taken is "Shanteuse" because all I really want is a shanty boat that
will trailer and go into shallow water. So many boats, so little time.
Paul McLellan enjoying a cup of tea while awaiting the "cure" and
