Re: [bolger]now Xynole
Make that Xynole not the Xenon that an overeager spell check put in.
Harry James wrote:
Harry James wrote:
>We are using Xenon on the bottom of the Gulls we are building. Our
>beaches are very rough, and the extra abrasion resistance is needed.
>Just have it on one so far, I laid it on dry and Squeegeed epoxy through
>with a spreader. I was worried about it floating, so I squeegeed it out
>well. Took LOTS of epoxy and took amazing bends without needing darts.
>Laid down very nicely. After it set up a bit I tried to put on a thick
>layer of epoxy using a roller to level it out. It came out very uneven,
>like the thick weave was releasing air bubbles. It can be sanded smooth
> but I hate doing that. One of the things God made gravity for was to
>level out epoxy on a flat surface so you don't have to sand it.
>Vince Chew (I think it was him) said something about using a 3rd of a
>roller (cut length ways) mounted on a handle to spread the epoxy rather
>than rolling it. I might give that a try, will listen to any other
>advice too.
>HJ
>Susan Davis wrote:
>>Rats, I just missed you. I just got in from the garage, after a very
>>pleasant experience with some Xynole. I think I see why Reuel Parker
>>is so fond of it....
>>Susan Davis <futabachan@...>
>- add your comments at the TOP and SIGN your posts and <snip> away
>- To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349
