Re: [bolger] BobCat Restoration Project
On Wednesday, May 28, 2003, at 06:48 PM,fountainb@...
Some are quite stiff. 6061 T6 comes to mind. A stiff salt
water tolerant alloy should be doable, check your local
machine shop.
hal
> David Romasco wrote:Depends on the alloy or tempering, I am not sure which.
>> Why not 1/4" aluminium? No rust, cuts with ordinary tools, and hurts
> less
>> when you drop it on your foot....
> A bit soft, I would worry about it bending.
machine shop.
hal
I have to make an exception to my original thought: those Aussies are hard
as hell on centreplates (water in Oz must be pretty hard..). Still think
aluminium would be my choice, had it in rudders and centreplates and never
regretted it; I'm about to start another project where I fully expect to
fabricate a rudder out of it.
David Romasco
Sent: Thursday, May 29, 2003 12:29 AM
Subject: [bolger] Re: BobCat Restoration Project
Actually, aluminium should be fine. My Finn had an alloy plate,
similar to Bobcat, and the loading would be greater than Bobcat.
It never bent that you could see. Neither did it especially get
dinged, because it just slid back and up.
Stainless steel might produce dolphin steaks!
DonB
David Romasco
DonB
hurts
> less
> A bit soft, I would worry about it bending. Most of the old open
> dinghies in Sydney harbour used a solid steel centreboard, and
> yes it would definitely hurt if you dropped it on your foot. If
> you pull it out and rinse it after use I don't think rust would
> be a real problem, but you could probably get a stainless board
> fabricated for less than you would think. Take along a paper
> template to a company that does stainless fabrication (usually
> for commercial kitchens).
> Bruce Fountain
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=251812.3170658.4537139.1512248/D=egroupweb/S=17050657
91:HM/A=1564416/R=0/*http:/www.netflix.com/Default?mqso=60164797&partid=3170
658>
<http://us.adserver.yahoo.com/l?M=251812.3170658.4537139.1512248/D=egroupmai
l/S=:HM/A=1564416/rand=621745347>
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
DonB
DonB
hurts
> less
> Bruce Fountain
Bruce Fountain
> Why not 1/4" aluminium? No rust, cuts with ordinary tools, and hurtsless
> when you drop it on your foot....A bit soft, I would worry about it bending. Most of the old open
Bruce Fountain
Why not 1/4" aluminium? No rust, cuts with ordinary tools, and hurts less
David Romasco
Sent: Wednesday, May 28, 2003 8:55 AM
Subject: Re: [bolger] BobCat Restoration Project
steel would be cheap and simple. Rust wouldn't even matter much.
Craig O'Donnell
Sinepuxent Ancestors & Boats
-- Macintosh kinda guy
91:HM/A=1564415/R=0/*http://www.netflix.com/Default?mqso=60164784&partid=317
0658>
l/S=:HM/A=1564415/rand=522611221>
David Romasco
>1/4 reinforced with lots of carbon fiber might. As someone suggested,
>I would just as soon build a new board of smaller width and be done
>with it...but I don't know if a 1/4 board will cut it?
Craig O'Donnell
0658>
Dont know what the centerboard case looks like, but how about a hefty
hardwood horizontal stiffener on each side, narrower at the ends, wider
in the center, running across the bowed-in area. Drive wedges down into
the case to spread the sides to a flat condition. Put filled epoxy on
the mating stiffener edges, then drill and drive 3-4 screws through the
stiffener into the bowed area to keep it straight. Let cure, then pull
the case wedges.
-Bill
Sent: Wednesday, May 28, 2003 2:19 AM
Subject: [bolger] BobCat Restoration Project
Hello All,
I'm in the finishing stages of a BobCat Restoration project.
The boat sat without the centerboard in place and the Stack has bowed
inward causing the board to bind upon installation.
I have tried a few things in an attempt to solve this problem, but
the board still binds up in the stack.
This group has provided much advice in the past and I'm hoping to
here from my fellow Bolger enthusiasts.
I have a site that tracks the progress (or lack of) my project, it's
www.bezanis.com
Chris
065791:HM/A=1564415/R=0/*http:/www.netflix.com/Default?mqso=60164784&par
tid=3170658>
pmail/S=:HM/A=1564415/rand=903846468>
the case wedges.
-Bill
Hello All,
www.bezanis.com
Chris
tid=3170658>
Craig O'Donnell
> I would just as soon build a new board of smaller width and be doneSteel?
Bruce Fountain
Senior Software Engineer
Union Switch & Signal
Perth, Western Australia
Hello All,
www.bezanis.com
Chris
www.bezanis.com
Chris
