sail lacings
I scanned a page on lacing sails to spars from the catboat bulletin,
and added it at the bottom of the mast-stepping & tabernacle page:
http://www.geocities.com/pvanderwaart/cb_scans.html
You can judge for youself whether the Mrs. Robinson technique is
required for any of these. However, somewhere in the catboat
association lore there is a comment by sailmaker Ike Manchester to
the effect that since the catboat mast is so fat, there is really no
harm in having a couple of inches of open space between the mast and
the sail. So if you use the Bolger-figure-eight method (or the
somewhat similar method c in the scan), you don't need to make them
so tight that you have the binding problem. Of course, you do need
adequate luff tension to avoid scalloping.
