[bolger] Re: design list
Here
http://home.clara.net/gmatkin/design.htm
Hope this comes through.
djb
Lincoln Ross wrote:
> david beede <juliej-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=2893
> Peter,
> Here's Gav's site.
> snip
WHERE?
Thanks
SOME CLICKS THAT COUNT!!
Feed someone.
http://www.thehungersite.com/
Save a little rainforest.
Simplicity Boats
Here's my latest boat:
http://unicornstrings.com
> Peter,
> Here's Gav's site.
> snip
WHERE?
Thanks
Peter,
Here's Gav's site. His list is mentioned near the bottom. I think
you'll like it.
Peter Vanderwaart wrote:
> > You should join Gavin's boat design list. It's a gas.
Where does one find Gavin's boat design list?
Feed someone.
Simplicity Boats
Peter:
Go to:http://www.onelist.comand do a search for "boatdesign" that
should get you there. then subscribe. BTW, welcome aboard.
Chuck Leinweber
http://www.duckworksmagazine.com
To: <bolger@...>
Sent: Wednesday, February 16, 2000 9:36 AM
Subject: [bolger] Re: design list
> Peter
> Get what you deserve with NextCard Visa! Rates as low as 2.9%
> Intro or 9.9% Fixed APR, online balance transfers, Rewards Points,
> no hidden fees, and much more! Get NextCard today and get the
> credit you deserve! Apply now! Get your NextCard Visa at:
>http://click.egroups.com/1/930/5/_/3457/_/950715420/
Yeah Richard,
Your Box canoe Idea sounds workable..... maybe could call it a Shipping
Canoe? ;~)
sheers...
Richard wrote:
Teakdeck@...wrote:
> 1. The second boat goes easier than the first.
yep. and the third and forth go even faster...
> 2. Tried some 5200 glue? I didn't like it. Went back to Weldwood.
tried weldwood. don't like it, will stick to epoxy. (with gloves)
may experiment with construction adhesive ... toying with making a square canoe...
Basicaly a rectangular box, 2 ft wide, 1 ft high. About 18 inches from the ends, I
curve the sides and bottom together with the same curve. Center 5 feet of the boat
will be dead flat...
Comments welcome.
> 3. Building as light as I can because I want to cartop this time (I trailer
> my Windsprint).
build light to pickup truck too. also, lead in rudder and center/lee/sideboard add
weight... for some reason
> 4. Plan to use outside chines. I like the outside chine and I think it makes
> clamping the bottom on much easier.
maybe a little easier. make nice rubrails too... <grin>
> 5. I have alot of clamps now. On my Windsprint I did not. More is better.
use drywall screws for clamps.
> 6. I put together a 2" square cedar mast. Haven't shaved it to size yet. Will
> let you know how it turns out. Masts have been my nemisis.
I've only broken one mast, and I tend to go sailing on windy days....
Knots in your mast are BAD...
> 7. I plan to deck over a litte more of the boat and not put seats at the ends.
> 8. I'm going to use plastic milk bottles for flotation (under the decks of
> course).
I prefer water-tite cambers, especialy on small boats. The storage space is very
handy.
> 9. Regarding lifting: If you are by yourself you should arrange to lift only
> half the boat at a time, right?
> 10. 1/4 inch Luan(sp) plywood is 19 bucks a sheet at Home Depot here in Oly,
> Wa.
bummer, it's less than $10 here in OK. How much is AC fir in Wa?
> 11. I hope to be able to use three rigs with this boat: the designed sprit
> rig, a lateen rig (one I made up for my Windsprint but still haven't tested)
> and third a design of my own experimenting with battens on a balanced lug
> sail.
> 12. I'm not using any epoxy. I'm allergic to it. I'm not fiberglassing
> anything, not even the chines. The hull is cheap. If it only lasts 10 years
> I'll build another one.
> 13. I think my next investments in tools will be a really nice, high powered,
> big table saw and an air powered staple gun like Greg uses.
Table saw is handy, as is a power hand planer.
Tried using my staple gun on Entropy... went back to drywall screws. They clamp
and hold at the same time, and you can get fine adjustments in the clamping
pressure, and if you put them in the wrong spot, you back them out and run them in
again.
The staples didn't pull the work together very well. Tried ring shank nails too...
I'll stick to screws. Bought SS deck screws so I could leave some of them in
permanently...
Feed someone.
Simplicity Boats
