[bolger] Re: Foam and watertight bulkheads?
I don't see why you need foam if you think you can get it well sealed. If
fact, sealing deck plates and foam seem at cross purposes (unless you want
to admire your foam from time to time!). I put all my junk in there.
Gregg
Gregg
>Gregg,
> If we make watertight bulkheads with deck plates as you suggest
>should we pile on the foam as well. In the Folding Schooner Plans the
>midship bulkhead forward of the forward hull transom has a big cutout
>but the under deck between this frame and the transom has two big foam
>blocks. We are going to put in a watertight hatch as per you advice and
>channels for the limber holes to make an airtight copartment. Think we
>should put some foam in there as well? Likewise the forepeak is filled
>with foam on the plans. If we make it watertight can we use it for
>storage or should we have some foam in it as well? The Folding Schooner
>doesn't have the side decks with foam under as on the Light Schooner.
>The original plans has foam under the midship decks and in the forepeak
>but nothing wateright.
>Thanks,
>Leander
>MyPoints-Free Rewards When You're Online.
>Start with up to 150 Points for joining!
>http://clickhere.egroups.com/click/805
>eGroups.com home:http://www.egroups.com/group/bolger
Gregg,
Leander
Leander
