[bolger] Re: double ender breakdown?
David:
I found it on Databoat:
http://www.databoat.com/cgi-tame/tame.cgi/boatingbooks/boatplans/Strayer/Lon
gsplice.tam?cart=99I13uqp.feu&lpg=%2Fboatingbooks%2FDesigners%2FDesignersLin
ks%2Etam&lpt=937269546
This is their url...it's kinda long. If you can't get it to work, go to:
http://databoat.com/and look for "Longsplice" by Strayer.
To: <bolger@egroups.com>
Sent: Monday, September 13, 1999 4:28 AM
Subject: [bolger] double ender breakdown?
> Along the lines of the folding schooner... I thought I saw a musing by
> Bolger somewhere about a double ended break down sharpie? I fantasize
> one that each half would be sailable separate, as well as joined. It
> also has the attraction of building two 15 ft boats and get a 30 footer!
> Any leads on such a design appreciated.
> david
> Simplicity Boats (mirror sites - if one doesn't work...)
>http://members.tripod.com/simplicityboats/
>http://members.xoom.com/simpleboats/
> Here's my latest boat:
>http://members.tripod.com/simplicityboats/featherwind.html
> Quasi esoteric musical instruments
> unicornstrings.com
> MyPoints-Free Rewards When You're Online.
> Start with up to 150 Points for joining!
>http://clickhere.egroups.com/click/805
Davids:
The Tandem Bricks are shown on page 7 of Boats with an Open Mind. There is
a double skiff somewhere, I will find it, and post it here.
> David:issue
> I think the boat you are referring to is featured in this half-month's
> "Bolger on Design" in MAIB (Sept 15:Vol. 17, No. 9). I haven't got the
> with me (I'm at work--yuck!), but the design is about forty feet, with aend
> cold molded hull, center cockpit, designed for two couples. Only the aft
> can sail by itself, however. Before Wolfard's falling out with Bolger,three-piece,
> Common Sense Designs used to feature the Break Down Schooner, a
> 47'x7'8"x1'6" skiff/sharpie hull with a gaff schooner rig, also withberths
> for four. None of the pieces of this one could sail by itself, as Irecall.
> I guess you could scale up two Bricks, combined with an equally scaled-upyour
> Brick Connector, and have all your dreams fulfilled, not to mention all
> neighbors in the marina throwing things at you. Such a boat would be a
> really ugly spud, but might actually work...
> david
> >From: David Beede <juliejj@...>
> >Reply-To:bolger@egroups.com
> >To: "bolger@egroups.com" <bolger@egroups.com>
> >Date: Mon, 13 Sep 1999 05:28:38 -0400
> >david
> ______________________________________________________
David:
"Bolger on Design" in MAIB (Sept 15:Vol. 17, No. 9). I haven't got the issue
cold molded hull, center cockpit, designed for two couples. Only the aft end
Common Sense Designs used to feature the Break Down Schooner, a three-piece,
47'x7'8"x1'6" skiff/sharpie hull with a gaff schooner rig, also with berths
for four. None of the pieces of this one could sail by itself, as I recall.
Brick Connector, and have all your dreams fulfilled, not to mention all your
david
david
>From: David Beede <juliejj@...>______________________________________________________
>david
david
unicornstrings.com
david
unicornstrings.com
