[bolger] Re: 1st boat, a teal. Next, a scooner!
David - I'll want to hear about your scooner when you get it going! I
assume you've seen mine at www.carlsondesign.com...
Say, your message first came to me to moderate - wondering - did you sign
up for the group, or did you send your message before signing in?
Gregg Carlson
At 08:20 PM 7/19/99 -0700, you wrote:
figure one aft and one on each side (allowing two guns to be brought to
bear in any direction) should be sufficient I expect I'll have to make a
few modifications to the deck to take the stress of recoil. Any
suggestions, either for arrangement or bracing, would be welcome.
eGroups.com home:http://www.egroups.com/group/bolger
http://www.egroups.com- Simplifying group communications
Gregg Carlson
>Although the teal need a little more carpentery and paint, I've set mysites on the Light Scooner, and have even found a source for swivel guns. I
>TIA,
>David Ryan
>david@...
>Want the power to purchase wisely? Productopia has the answers.
>http://clickhere.egroups.com/click/553
First, thanks to Mr.Carlson for setting up this group.
Second, I've just glued on the last gunnel on my teal. A couple of thwarts and she'll be ready for painting. I have to admit I'm rather stunned by both the easy of construction, (I've only owned a skill saw for about 6 months,) and the grace of her lines.
Although the teal need a little more carpentery and paint, I've set my sites on the Light Scooner, and have even found a source for swivel guns. I figure one aft and one on each side (allowing two guns to be brought to bear in any direction) should be sufficient I expect I'll have to make a few modifications to the deck to take the stress of recoil. Any suggestions, either for arrangement or bracing, would be welcome.
TIA,
David Ryan
david@...
TIA,
David Ryan
david@...
