[bolger] Re: Sail/Rigging for Brick
>Thanks Craig...That gets me moving. As I look at the plans I can
>figure out most everything except the rigging at the fore section of
>the boom. Is this the portion you are referring to as a "snotter"?
>If so, then this all makes sense now. Please forgive my
>ignorance...this is my first project as a novice sailor. Again.
>Thanks.
>Barry
Yep, that's the snotter. It is a line that you pull on to flatten the
sail (windy conditions) or loosen slightly to let the sail be a
little fuller (baggier?) when the air is light. There is no hard and
fast rule saying you *have* to have an adjustable snotter, but it
works so well that it's silly not to include it.
Craig O'Donnell
Sinepuxent Ancestors & Boats
-- Macintosh kinda guy
Thanks.
Barry
--- Inbolger@yahoogroups.com, craig o'donnell <dadadata@f...> wrote:
> >Looking at the plans I can only figure out "part" of the
> >rigging.
> Well, what part can you figure out?
> 1. Sheet goes to the *end* of the sprit boom. You may find it
> convenient to lead the sheet through a block or large ring on a
> "traveler", or length of rope run from one corner of the transom to
> the other. (Make sure the tiller is under the traveler).
> 2. In the simplest case the sail is tied onto the mast and when you
> are done sailing you roll it up around the mast. No halyard to fool
> with.
> 3. The sprit boom is hauled tight with a "snotter". If you lead the
> snotter down to a block at the base of the mast, and aft a little
> a cleat, you can adjust the sail to mild or stiffer winds very
> easily. There are about a hundred ways to rig a snotter. I
personally
> think it's worth the few bits of hardware to have a 2:1 purchase on
> the snotter. Few people are actually strong enough to really haul
> effectively on a snotter with a 1:1 purchase.
> Craig O'Donnell
Junks,
>rigging.
with.
snotter down to a block at the base of the mast, and aft a little to
easily. There are about a hundred ways to rig a snotter. I personally
Craig O'Donnell
Greetings Everyone,
I have built a Bolger Brick and about to finish the spars and
sail. Looking at the plans I can only figure out "part" of the
rigging. Can anyone lend any guidance so I can finish this thing and
get in the water yet this summer?
Thanks
Barry
Indianapolis
