Re: Time
--- Inbolger@yahoogroups.com, fountainb@s... wrote:
> Straight lines and right-angles seem easier at first glance, but
> I have learned that it is a lot easier to achieve a nice curve
> than to get a straight line to look straight. The human eye is
> pretty damn good at detecting almost-straight-lines and
> not-quite-right-angles.
> Bruce Fountain
> Senior Software Engineer
> Union Switch & Signal
> Perth, Western Australia
Bruce,
Excellent observations there Bruce.The so called square boats
with expanses of flat surfaces can be a devil to get just
right.Proper preparation is the cure.
And it takes a good designer to get the curves right on a square
boat.I had my eyes opened once while installing the shear trim on my
Micro.No matter how I looked at it on the plan,it appeared curved
(following the shear).When installing these pieces,my muscles and
eye told me to put some swing into the piece since it curved....Well
after a dry fit,it did not look right nor did it hit the marks drawn
from the plan.I thought that maybe,just maybe Bolger had goofed.
After much playing around with these pieces I finally got them
right.And you know what....they actually sit dead straight but you
would bet your front teeth the damned thing curves!!
"Un-square" boats are much more forgiving of slight
irregularities since the eye is drawn all over the place to all
sorts of curves......
sincerely,
Craig O'Donnell wrote:
> Bolger has never said you should make a cheap boat look like a
gold-plater.
> You could build, say, a Herreshoff H-28, even using plywood so it
> won't cost $40,000.
> In the meantime you could probably build 3 AS-29s in the same time
> period. The AS 29 is by no means an ugly boat though it is squared
> off.
I don't believe that a boat has to be boxy to be either cheap or
fast to build. As far as I can tell, the boxy look comes mostly
from trying to squeeze as much interior space out of the minimum
LOA and materials. Personally, I would rather build a slightly
longer boat, or live with a little less interior room, to have
a boat that makes my heart sing.
I know that there are lots of Micro fans on the list, and the design
does have a certain cute, puppy-like appeal, but I would rather
have a Chebacco any day.
Oh well, just my humble opinion. Now where did I leave my asbestos
underpants?
Bruce Fountain
Well, I didn't.
I agree with some of your points, but probably best to finish this
thread, because most of the Group will never see Australian Amateur
Boatbuilder.
Cheers
DonB
> He did, yes. But you certainly can't accuse him of ripping
> of Bolger's designs. >
> Bruce Fountain
>of Bolger's designs. His position was: if you are going
>to spend a huge amount of time building a boat then it
>might as well be beautiful as well as functional.
Bolger has never said you should make a cheap boat look like a gold-plater.
won't cost $40,000.
off.
If you look at old photos of actual fishing sharpies, flatties, etc.,
you will discover that there were a large number of very lumpy boats
which worked perfectly well for watermen. Kind of like a rusty and
dented pickup. Not every sailboat was a "beauty".
Craig O'Donnell
Sinepuxent Ancestors & Boats
-- Macintosh kinda guy
dbaldnz wrote:
> Yes, I know of the Scruffy man, he is the fellow who slagged off
> Bolger big-time in that same august magazine!
might as well be beautiful as well as functional. He certainly
puts his money where his mouth is. I tend to agree, quite
honestly, I don't like boxes. Bolger has plenty of designs
that have sweet lines as well as function.
However, I felt that the editor should have exercised more
control over the article. As far as I can tell there is no
editorial control over the magazine at all. The standard of
writing is not much better than you might find in a forum
like this. Duckworks is better edited, is more regular, and
has much better graphics.
Bruce Fountain
DonB
> Not sure about the pillaged Bolger accusation either - PCB is
hardly the
> only designer working with squarish plywood boats. And lots of the
boats
> featured in AAB are definitely not square - check out the Scruffy
boats
> for an example of how elegant a plywood hull can be.
> Bruce Fountain
dbaldnz wrote:
> I don't feel the same way you do about Australian Amateur
> Boatbuilder.
> The copies I have seen seem to be full of thinly disguised
> advertorial; pillaged Bolger plans, all printed on colored toilet
> paper, appearing on the shelves at odd intervals.
I think the advertorial charge is a bit harsh - the regular columns are
all
written by designers/plansellers/boatbuildingsuppliers, so I would replace
"thinly disguised" with "undisguised". I don't have a problem with
advertorial
as long as it is obvious, after all PCB submits regular advertorial to
MAIB, yes?
I don't buy the mag anymore because the quality is just too patchy. Lousy
images, and as far as I can see no editing at all. What finally put me off
was
a nasty sledging trend.
Not sure about the pillaged Bolger accusation either - PCB is hardly the
only designer working with squarish plywood boats. And lots of the boats
featured in AAB are definitely not square - check out the Scruffy boats
Bruce Fountain
