Re: [bolger] Freezing epoxy
Sure, do it all the time when I get interupted. Never left it in for 10 days, though.
No ill effects, boats haven't started falling appart. At least, not from epoxy failure!
Sent: Tuesday, July 15, 2003 7:19 AM
Subject: [bolger] Freezing epoxy
> Perhaps everyone knew this but me, but it was news for me so I'll
> post it.
> Last week I was doing some epoxy glueing work and ended up with some
> leftover mixed filled resin. This often happens and is frustrating
> because epoxy is obcenely expensive here. So, lacking any better
> ideas, I put the yoghurt container with the epoxy, as well as a used
> applicator wrapped in plastic, in the freezer.
> About 10 days later I had need of some more glue. So I took out the
> frozen epoxy- rock hard- and put it in a bucket of warm water. It
> softened up rapidly and appeared OK, so I used it. It set normally
> and I can detect no difference in the hardened glue. Also, the
> applicator was useable after I warmed it up.
> Now I can't guarantee that the glue has not been damaged in some way
> by freezing, but it did not appear to be. I have never heard of
> anyone else doing this, but it opens up some possibilities for
> reducing waste. For example, instead of throwing out rollers,
> brushes etc, just put them in a bag and freeze them. Same with any
> leftover mixed glue.
> I know that unmixed resin goes cloudy if it gets too cold, but this
> did not appear to be the case for the mixed stuff.
> No guarantees, but worth trying on a small scale.
> Regards to all,
> Daniel Pike
> Tromso, Norway, 70 North.
post it.
Regards to all,
Daniel Pike
post it.
Regards to all,
Daniel Pike
