[bolger] Re: Lauan vs. AC vs. BC
Lauan appears to be the material of choice for a number of builders in NS.
Its main advantage over AC/BC is supposedly the guaranteed absence of voids
(potential law suits from spike heels breaking through floor layers).
Several windsprints and possibly LS's that compete in the Mahone Bay WB
Festival are made of lauan. As far as I know they've been around for years.
They do appear to be somewhat prone to surface checking and I've heard some
concerns re. delamination.
jeb
jeb
>I checked the archives on this, there isn't much about lauan.
>It seems to be much lighter than the BC pine that I've seen- what are the
>compromises? I'd like to build a cartoppable boat, and the lauan seems to
>help in the weight arena. I just don't want this thing to come apart after
>six months.
>Anyone out there built a boat from 1/4" lauan? What were your experiences?
>TIA,
>Blake
>Knoxville, TN
>GET A NEXTCARD VISA, in 30 seconds! Get rates as low as 0.0%
>Intro or 9.9% Fixed APR and no hidden fees. Apply NOW!
>http://click.egroups.com/1/933/5/_/3457/_/950883101/
>eGroups.com Home:http://www.egroups.com/group/bolger/
ok, if you are going to hang onto your boat and make it into a
strawberry planter when you are done with it, AC will do. If you think
someone else is going to buy it, then be carefull and don't expect too
much. You will lose money on the deal, I promise.
I have built the following with the following results:
Cape Cod Frosty - luan/bondo : boat sank at finish line
Cape Cod Frosty #2 - luan / WEST : boat rotted after 4 years of
storage on bare ground
Diablo - 1/2 in luan, 1/2" transom rotted, 1/2" floor rotted, 1/4" AC
Exterior sides ok
Diablo (rebuild) - all AC, coated with epoxy and glass, fine after 6
years.
Pointy Skiff - 1/4 luan is delaminating after 12 years of hard work.
Will rebuild with ac/glass/frozen snot. Great Boat!
Nymph - 1/4" AC exterior. wonderful, still going!
"james fuller" <jama-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=2984
Exterior sides ok
years.
> Hi,makes
> Payson reccommends AC plywood in his book The New Instant Boats. He
> the argument that the minimum standards for manufacturing marineplywood are
> now about the same as the specs for AC, and that they use the sameglue to
> make both.wood, but
> (He is talking about the allowable void content)
> I am building a Carnell sailboat using AC. I did not candle the
> hardly any voids show up when I cut the pieces out. It cost me$14.50 per
> sheet here in landlocked New Mexico. The nearest source for marinewood Is
> Houston, Tx. They want $46.00 a sheet. The freight would probablyadd
> $100. to that. My boat will not live in the water, and will be storedboat!
> inside when not in use. I don't anticipate any problems with the AC.
> Lets see... $58.00 for AC, $284.00 for marine.
> Carnell is going to have to change that from a $200. boat to a $500.
>dry
> James
> (flame suit on)
> From: "Blake Sartin" <bsartin@...>
> To: <bolger@egroups.com>
> Sent: Friday, February 18, 2000 11:04 AM
> Subject: [bolger] Re: Lauan vs. AC vs. BC
> > >If you plan on leaving your boat in the water, or not keeping it
> > >between uses, you should probably use marine grade plywood.chop
> > OK, no Lauan. I get the picture.
> > >If you are concerned with resale value, you should probably not be
> > >building a plywood boat...
> > !!WHOA!! I never said anything about resale value. I will proably
> > this boat up and use it for shelving in the basement when itsusefulness
> hasdown
> > expired.
> > I just wanted to stay cheap, but durable. I guess I'll just hunt
> someboat.
> > good AC or BC pine and an old Jonboat trailer. Or build a smaller
> > Blake
> > Knoxville, TN
Hi,
Payson reccommends AC plywood in his book The New Instant Boats. He makes
the argument that the minimum standards for manufacturing marine plywood are
now about the same as the specs for AC, and that they use the same glue to
make both.
I am building a Carnell sailboat using AC. I did not candle the wood, but
hardly any voids show up when I cut the pieces out. It cost me $14.50 per
sheet here in landlocked New Mexico. The nearest source for marine wood Is
Houston, Tx. They want $46.00 a sheet. The freight would probably add
Carnell is going to have to change that from a $200. boat to a $500. boat!
James
(flame suit on)
make both.
James
(flame suit on)
> >If you plan on leaving your boat in the water, or not keeping it dry
> !!WHOA!! I never said anything about resale value. I will proably chop
> this boat up and use it for shelving in the basement when its usefulness
has
> expired.
> I just wanted to stay cheap, but durable. I guess I'll just hunt down
some
> good AC or BC pine and an old Jonboat trailer. Or build a smaller boat.
> Blake
> Knoxville, TN
> GET A NEXTCARD VISA, in 30 seconds! Get rates as low as 2.9%
>http://click.egroups.com/1/932/5/_/3457/_/950897407/
> -- Create a poll/survey for your group!
> --http://www.egroups.com/vote?listname=bolger&m=1
>If you plan on leaving your boat in the water, or not keeping it dryOK, no Lauan. I get the picture.
>If you are concerned with resale value, you should probably not be!!WHOA!! I never said anything about resale value. I will proably chop
this boat up and use it for shelving in the basement when its usefulness has
expired.
I just wanted to stay cheap, but durable. I guess I'll just hunt down some
Blake
Knoxville, TN
Good exterior grade lauan is fine for small, trailed, car topped or
pickup trucked boats that are taken care of. Store the boat upside down
outside, or better yet, inside.
David Jost wrote:
Richard
Spelling|richard@...|http://www.spellingbusiness.com
Don't have a webpage yet? Your competition does! See us for custom web
design.
Boat building projects:http://www.spellingbusiness.com/boats/
David Jost wrote:
> Wow! slow down. I have had some nasty experiences with exterior grade
> Luan. If the interior core gets wet, then it is almost impossible to
> hold it together regardless of what glue has been used. I have used AC
> with good success, but the time spent in finish work loses whatever
> money you saved. there is also a problem at resale time. You will be
> hard pressed to find a buyer (who knows ply) that will buy a boat of
> non-marine grade plywood. Marine grade plywood is for boats! The
> other stuff is for subflooring and such which is not constantly damp.
> David Jost
> "hoping he can get home through the snowstorm"
> > So, be very picky, and you should be fine.
> > Be sure it is "exterior glue" lauan, do a boil test on a sample.
> > It will have some voids, you can candle them if that will be a
> problem.
> > Bet sure it's good quality and has good faces, before you buy it.
> are the
> seems to
> apart after
> > > six months.
> experiences?
> > > TIA,
> > > Blake
> > > Knoxville, TN
>http://click.egroups.com/1/933/5/_/3457/_/950894292/
> -- Talk to your group with your own voice!
> --http://www.egroups.com/VoiceChatPage?listName=bolger&m=1
Richard
design.
>problem.
> Bet sure it's good quality and has good faces, before you buy it.are the
> > compromises? I'd like to build a cartoppable boat, and the lauanseems to
> > help in the weight arena. I just don't want this thing to comeapart after
> > six months.experiences?
> > TIA,
> > Blake
> > Knoxville, TN
Yes. Have built three out of it.
Other than the very thin surface veneer, the major drawback is quality.
One HD in Tulsa had nice exterior glue lauan that worked very good. They
ran out, so I went to the other HD to get some. This batch started
delaminating before I could even get it in the boat!
It will have some voids, you can candle them if that will be a problem.
Blake Sartin wrote:
Richard
design.
> six months.
> TIA,
> Blake
> Knoxville, TN
Richard
design.
"blake sartin" <bsarti-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=2958
snip
Luan can last a long time, just don't let it get wet.
snip
>experiences?
>snip
Built my Gypsy out of quarter inch luan with a 6oz. fiberglass covering.
Only one year of use but so far no problems at all
> -----Original Message-----
> From: Blake Sartin [SMTP:bsartin@...]
> Sent: Friday, February 18, 2000 9:06 AM
> To:bolger@egroups.com
> Subject: [bolger] Lauan vs. AC vs. BC
> after
> six months.
> experiences?
> TIA,
> Blake
> Knoxville, TN
Luan is OK if it passes visual inspection for voids, knots, etc., is
labelled "Exterior", and cheap enough to buy a sheet and boil/freeze a
sample. I'd say at least six years for semi-careful storage.
Don Hodges
dhodges@...
http://www.ecoastlife.com
Don Hodges
dhodges@...
Sent: Friday, February 18, 2000 8:05 AM
after
> six months.
experiences?
> TIA,
> Blake
> Knoxville, TN
six months.
TIA,
Blake
Knoxville, TN
six months.
TIA,
Blake
Knoxville, TN
