[bolger] Re: MDO?
wschroe-@...wrote:
I am the owner of a 28' Trojan built in 1965 with MDO. Structurally it
has held up wonderfully. The only complaint I have about the MDO is
that it has made my work this last month to get a smooth hull while
painting close to impossible. Some previous materials clung to the
paper with the grip of death, others sloughed off snow from a stove. I
didn't have time to take the topsides down to the first wood laminate,
so conseqently I have a bit of a screwy looking boat. Oh well, it is
solid as a rock structurally so what if a little ugly.....??
original article:http://www.egroups.com/group/bolger/?start=302
> Leander,
> There has been a lot of discussion about this on the boatbuilding
> newsgroups - you might check dejanews.
> Gregg Carlson
> At 08:00 AM 9/14/1999 -0500, you wrote:
> >Hi Leander,
> >I am currently converting Glen-l's Sweet Caroline to stitch and glue
and am
> >using 1/2" MDO ( Duraply)
> >for all the planking. It seems better than A/C fir plywood and I
have
> >placed the MDO face on the inside of the boat, fir side out. The fir
will
> >be fiberglass sheathed and the interior epoxy sealed and painted. I
am
> >hoping the MDO will prevent checking of the fir where it is not
sheathed.
> >I'll let you know how it does.
> >Richard
> >> From:harding2@...
> >> To:bolger@...
> >> Subject: [bolger] MDO?
> >> Date: Monday, September 13, 1999 9:59 PM
> >> Has anyone on the list had any experience with a material called
Medium
> >> Density Overlay. It is available in this area in 3/8 and 1/2 inch.
It
> >> is a very high quality ply with a resin saturated paper coating on
both
> >> faces. It is designed for outdoor signs and is reputed to be as
water
> >> resistant as Marine Ply. I have come by a couple of sheets of the
3/8
> >> and it seems very good material but it is very wavy and doesn't
want to
> >> lay flat. It is also very heavy, similar to BC Yellow Pine. I am
> >> thinking of using it for the bottom of the Folding Schooner. Then
again
> >> it might make a nice work bench top.
> >> Best Regards
> >> Leander
> >> MyPoints-Free Rewards When You're Online.
> >> Start with up to 150 Points for joining!
> >>http://clickhere.egroups.com/click/805
> >> eGroups.com home:http://www.egroups.com/group/bolger
> >>http://www.egroups.com- Simplifying group communications
sailormo-@...wrote:
original article:http://www.egroups.com/group/bolger/?start=296
Medium
> Density Overlay. It is available in this area in 3/8 and 1/2 inch. It
both
> faces. It is designed for outdoor signs and is reputed to be as water
> resistant as Marine Ply. I have come by a couple of sheets of the 3/8
> and it seems very good material but it is very wavy and doesn't want
again
> Best Regards
> Leander
> A little late in my reply, but have been busy. Yes, I used MDO many
years ago in the building of a north sea 27', this from a glass hull.
I laminated all the bulkheads etc. up with it. I had no failures of
the glass tape from the mdo to the hull. I can assure you this boat
was really tested in lake MI. on several occasions. The last trip
down, I was trashed and the boat was fine, including the ply. I
sold her many years ago and all was fine. Brad Raby
Leander,
Gregg Carlson
>Hi Leander,
>I am currently converting Glen-l's Sweet Caroline to stitch and glue and am
>for all the planking. It seems better than A/C fir plywood and I have
>placed the MDO face on the inside of the boat, fir side out. The fir will
>be fiberglass sheathed and the interior epoxy sealed and painted. I am
>hoping the MDO will prevent checking of the fir where it is not sheathed.
>Richard
>> From:harding2@...
>> To:bolger@...
>> Has anyone on the list had any experience with a material called Medium
>> is a very high quality ply with a resin saturated paper coating on both
>> and it seems very good material but it is very wavy and doesn't want to
>> thinking of using it for the bottom of the Folding Schooner. Then again
>> Best Regards
>> Leander
Hi Leander,
Richard
> From:harding2@...
> To:bolger@...
> Best Regards
> Leander
Best Regards
Leander
