Re: Red Meranti Ply
Sounds good Bob.
I will take your advice and give it one coat of epoxy. I am also
building this dinghy 'light', and the one coat will probably stiffen
her a little.
DonB
--- Inbolger@yahoogroups.com, "Bob Chamberland" <cha62759@t...>
her a little.
DonB
> -Hi Donof
> I used 1088 Meranti to build my Bobcat and also used it for parts
> my Hawkeye. Frankly I wish I had used it for the entire Hawkeyeraising
> project. I concur with all of the fader"s comments. For finishing
> bright it is not as pretty as Occume but very nice anyway. If it is
> exposed to the weather it will check some but it is the grain
> a little. A coat of epoxy or sealer seems to take care of things. Irolled
> have just finished building a new motor box for my Hawkeye using
> Meranti, some with a coating of epoxy some bare wood. One coat of
> epoxy sure makes a difference with the finish. The epoxy surfaces
> finish absolutely smooth whereas the bare wood surfaces show some
> slight grain. I used Sears housepaint and a good latex primer
> and tipped out with a brush. Use tape to prevent splintering. Eventhan
> coated with epoxy it will splinter some.
> Bob Chamberland
> -- Inbolger@yahoogroups.com, WeBookPeople@a... wrote:
> > Don,
> > I have not, but I've talked to those who have... actually, we've
> discussed
> > the BS6566 version, which is just a matter of better face plies
> w/BS1088. I'm
> > told that it is excellent for stability and resistance; heavier
> occume, butcircular
> > not as heavy as pine (maybe around the weight of fir), and a good
> bit more
> > brittle than occume. The only negative is this brittleness of the
> face plies.
> > Users say to score your pencil lines before cutting with a
> saw, and iffinish,light
> > using a sabre saw, then lay down masking tape and draw lines on
> that. You'll
> > still have splintering, but not so bad.
> > I plan to use it if I build a Sneakeasy.
> > Cheers/The Fader
> > In a message dated 7/23/03 8:46:09 AM Eastern Daylight Time,
> >bolger@yahoogroups.comwrites:
> > > Red Meranti Ply
> > > Has anyone used this stuff?
> > > I am building a dinghy, and this seemed to be the best value.
> > > 6mm (1/4"), marine ply to BS1088, 5 ply, beautiful
> > > weight, for equivalent of US$28-50 a sheet, good value Ithought.
> > > Beats buying crap ply and trying to turn it into marine plywith
> > > epoxy.
-Hi Don
I used 1088 Meranti to build my Bobcat and also used it for parts of
exposed to the weather it will check some but it is the grain raising
slight grain. I used Sears housepaint and a good latex primer rolled
Bob Chamberland
Bob Chamberland
> Don,discussed
> the BS6566 version, which is just a matter of better face pliesw/BS1088. I'm
> told that it is excellent for stability and resistance; heavier thanoccume, but
> not as heavy as pine (maybe around the weight of fir), and a goodbit more
> brittle than occume. The only negative is this brittleness of theface plies.
> Users say to score your pencil lines before cutting with a circularsaw, and if
> using a sabre saw, then lay down masking tape and draw lines onthat. You'll
> Cheers/The Fader
> > Red Meranti Ply
> > 6mm (1/4"), marine ply to BS1088, 5 ply, beautiful finish,light
> > weight, for equivalent of US$28-50 a sheet, good value I thought.
> > Beats buying crap ply and trying to turn it into marine ply with
> > epoxy.
Don,
I have not, but I've talked to those who have... actually, we've discussed
the BS6566 version, which is just a matter of better face plies w/BS1088. I'm
told that it is excellent for stability and resistance; heavier than occume, but
not as heavy as pine (maybe around the weight of fir), and a good bit more
brittle than occume. The only negative is this brittleness of the face plies.
Users say to score your pencil lines before cutting with a circular saw, and if
using a sabre saw, then lay down masking tape and draw lines on that. You'll
Cheers/The Fader
Cheers/The Fader
> Red Meranti Ply[Non-text portions of this message have been removed]
> epoxy.
