Re: Tennessee et al
--- Inbolger@yahoogroups.com, "Frank Bales" <fbales@l...> wrote:
under "Big Bolger Boats"
Ralph
> Are any of these power sharpies capable of long offshore cruising?Tahiti is designed for crossing oceans. Information is in Bolger2
Ralph
Is there a single place to view all these designs and their specs? It would
really be convenient.
Don't forget Champlain, Windemere and the mighty Illinois.
--- Inbolger@yahoogroups.com, "chodges31711" <chodges@a...> wrote:
> What I cannot get a handle on are the others in that size range
i.e. the Dakota, Wyoming,
And Minnessota, 31'0" by 6'6", my favorite.
Scans and article are in the Bolger2 group files section in the file
named "Bolger Scans" at
http://groups.yahoo.com/group/Bolger2/files
The only thing that stands between most of us and an Illinois is 450
sheets of plywood and a little time.
Bruce
What MAIB was the Minnesota in.
>Bruce Hector
> With the Tennessee and Idaho so similar in size, why so many moreI think the 5' width is too limiting for the Idaho. Imagine living
> Tennessees bing built? Is the rockered bottom a big advantage?
in a long Ford Ranger pickup bed. It would be hard to get past a bed
or table without stowing it. In the Tennessee I've seen pictures of
a group down both sides of a table enjoying a picnic and
conversation. On the Idaho, one side of the table would have to be
against the wall. Even two chairs side by side facing forward would
almost block access to the rear.
I guess in a day boat with camp furniture all this would not matter
and the narrow boat would trailer great.
Charles
Bruce Hector wrote:
line.....
> suggesting step hull power sharpies, the Microtrawler at 15'6"Hmmm, Reddy is only 14' 6" I guess my sawcut wandered a bit over the
line.....
And if we're suggesting step hull power sharpies, the Microtrawler at
15'6" and its bigger brother the Retriever at , I think, 22 feet.
HI ALL -
I THINK SOME MIGHT BE INTERESTED IN INCLUDING "TOPAZ" WITH THIS GROUP
CHECK THIS PAGE OUT ----http://jboats.weblogger.com/
ALOHA - JACK
ALOHA - JACK
> With the Tennessee and Idaho so similar in size,The big advantage is that the Tennessee will perform with a 10-15 Hp motor. It glides along with hardly any wake at any speed up to about 15 or 16 mph. If you put a bigger motor on her, she would just squat and not really go much faster even though you are burning a lot more gas. A planing boat like Idaho has a higher top speed, but needs a bigger motor to do it, and does not do nearly as well below about 10 or 12 mph. It will wallow and produce a big wake at slow speeds. With motor boats, it's fish or fowl, but there is not much compromise.
> why so many more Tennessees being built?
> What I
> > cannot get a handle
> > > on are the others in that size range i.e. the Dakota, Wyoming,
> > Idaho and maybe
> > > others.
> Sneakeasy 26' x 4' flat bottom
> Tennessee 29'x 6' rockered bottom
> Idaho 31' x 5' flat bottom
> Wyoming 51' x 8' Sneakeasy x2
> More Tennessee's ( and modified Tennessee's) have been built than
> the others.
Wyoming is 51'6" X 8'3". The aft cabin version draws 7 inches while the
original design is at 6 inches draft. Displacement is up to 10,000 lbs. on
the origianl, 11,500 on the aft cabin. The aft cabin is the design Mr.
Bolger created for the Wyoming in full crusing trim.
Sent: Wednesday, August 13, 2003 8:35 PM
Subject: [bolger] Tennessee et al
> Hey Guys,
> I found a write up on the Tennessee in an old old Common Sense
Boat
> Designs pamphlet that I got from Bernie Wolfard so I know the length beam
> layout and Chuck told me it weighs about 1000 lbs. What I cannot get a
handle
> on are the others in that size range i.e. the Dakota, Wyoming, Idaho and
maybe
> others. Anyone know the specifics of them. Tom on Sandpiper
Bruce:
The Minnesota looks a lot like some of the Australian versions of the Tennessee. Was one ever built?
Bruce Hector
Bruce Hector
Bruce Hector
> What I cannot get a handle on are the others in that size rangei.e. the Dakota, Wyoming,
Bruce Hector
What I
the others.
> cannot get a handleSneakeasy 26' x 4' flat bottom
> Idaho and maybe
> > others.
the others.
--- Inbolger@yahoogroups.com, TOMCBRADY@C... wrote:
window cruiser version I am building should end up, with
batteries, motor, full fuel, water tanks filled, anchor and chain,
cruising provisions, etc. at just under 7000 lbs.
I started installing the plexiglas windows today. Hope to post
updated pics soon. I have some older pics in the photos and
files sections.
Vince Chew
> Hey Guys,Common Sense Boat
> Designs pamphlet that I got from Bernie Wolfard so I know thelength beam and
> layout and Chuck told me it weighs about 1000 lbs. What Icannot get a handle
> on are the others in that size range i.e. the Dakota, Wyoming,Idaho and maybe
> others. Anyone know the specifics of them. Tom on SandpiperI can give you Dakota specs. 37.5ft X 8ft. X 11"(draft). The
files sections.
Vince Chew
Hey Guys,
I found a write up on the Tennessee in an old old Common Sense Boat
Designs pamphlet that I got from Bernie Wolfard so I know the length beam and
layout and Chuck told me it weighs about 1000 lbs. What I cannot get a handle
on are the others in that size range i.e. the Dakota, Wyoming, Idaho and maybe
