[bolger] Re: Painting a Bolger Sea Hawk
In my experianc epoxy is the best "primer" there is
Just paint on it,it's perfect!
Best,Steve Yahn
Best,Steve Yahn
>I have pulled my plywood 15' Bolger Sea Hawk power dory hull off the molds
>after sheathing the exterior, but now am wondering about paint application.
>Can you simply paint onto the epoxy after sanding and washing with water, or
>does there need to be a primer put on to help the paint adhere?
>Any ideas on this?
>Alex
>Gabriola Island, BC
>GET A NEXTCARD VISA, in 30 seconds! Get rates as low as 0.0%
>Intro or 9.9% Fixed APR and no hidden fees. Apply NOW!
>http://click.egroups.com/1/933/5/_/3457/_/951078681/
>eGroups.com Home:http://www.egroups.com/group/bolger/
Alex,
First you wash it with water (to remove the blush), then you sand it, then wash
with thinners. In general, epoxy makes a good base for paint and I have had
success just using gloss and semigloss alkyd enamel house paint right over the
prepared surfaces. I will use a white primer under a light paint, more for
masking the wood color than for paint adhesion. Rarely, if I want a really
smooth finish, I'll use a sanding primer as a final filler prior to coating. If
you are using latex paints, I think a coat of flat enamel or propriatory primer
might help the longevity of the finish. It seems to on my house, at any rate. If
you choose to use $200 a gallon two part polyurethane, follow the directions
_exactly_ (and consider seeing a psychiatrist). Priming certainly can't hurt, in
any case. Whatever you do, paint a small inconspicuous area first and make sure
the paint is compatable with the epoxy. I once had to strip an entire hull after
using a paint that simply wouldn't set up because of some mysterious interaction
between it and the coating underneath. I used primer on that job, too, so you
never know....
david
never know....
david
> Any ideas on this?
> Alex
> Gabriola Island, BC
Alex,
I have a Diablo that is similarly constructed to your boat. I used
a simple fresh water rinse to get the blush off, let it dry, then
applied two coats of alkyd enamel house paint over the prescribed
primer (see manufacturers recommendation. After 5 years of very hard
and abusive use, the paint on the epoxy is still quite good.
Non-epoxied surfaces showed wear and tear and were subsequently epoxied
and repainted. If you use a gloss enamel, less dirt will adhere to it.
Good Luck
David Jost "lots and lots of snow in 'Vermont."
"alex & kim christie" <bschool-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=3024
Good Luck
> I have pulled my plywood 15' Bolger Sea Hawk power dory hull off themolds
> after sheathing the exterior, but now am wondering about paintapplication.
> Can you simply paint onto the epoxy after sanding and washing withwater, or
> Any ideas on this?
> Alex
> Gabriola Island, BC
In a message dated 2/20/2000 4:16:50 PM Eastern Standard Time,
galvind@...writes:
<< If
primer
might help the longevity of the finish >>
First of all I have to say that I know little about painting boats - but I
used latex on Landroval this past month - and I've had two discoveries -
first I've given up on Kilz2. I used that on the interior and did have some
problems with it not adhereing as well as I expected - and when I called the
kilz people they were horrified that I was using it on a boat and over epoxy.
They claimed that they tested it over epoxy and were not pleased with the
results - that was their response. West System sent me a copy of a test they
did on latex primers - there were a number that did well and some that didn'
t - so all primers are not alike. One of the ones that did the best was
Sherwin Williams Pro Block. I used that on the outside of the boat and it has
adhered just fine. The second discovery is that it's very true that latex is
a soft finish and mars easily - very easily - but I've also found that after
my bow kissed the dock on our maiden voyage that I could take a foam brush
and the leftover paint and in 30 seconds the "kiss" was gone. So easy to fix.
Steve Anderson ( Landroval)
galvind@...writes:
<< If
primer
Any ideas on this?
Alex
Gabriola Island, BC
Any ideas on this?
Alex
Gabriola Island, BC
