Re: [bolger] Re: Expanding panels, lofting.
On Saturday, August 23, 2003, at 02:46 PM, Harry James wrote:
> Ok, I have looked around and this is the only mention I have found of
> this book, is it for sale anywhere?
I bought the book (The Secret Guide To Plywood Boat Design)
Directly from Jim Michalak about two years ago. The book was
very rough and very informative. Actually it looked like copies
of his design notes and rules of thumb spiral bound. Lots of
good stuff, I highly recommend it. I don't know if it is still
available
or not but Jim does.
http://homepages.apci.net/~michalak/
hal
Have you asked... Jim Michalak?
Harry,
We MUST be a serious body of boat savants; just LOOK at our 'sent from'
names! In other groups you see names like 'oogabooga9834' or
'sqeamishninny'. We're so sober about boats that we actually use our own
names!
Woodrow Wilson
Sent: Saturday, August 23, 2003 5:50 PM
Subject: Re: [bolger] Re: Expanding panels, lofting.
Oh no! Could it be I have fallen victim to a spoof? How am I supposed to
know if I should engage my sense of humor in this ever so serious group
if somebody doesn't put in the appropriate emoticon?
David Romasco wrote:
>Well now, daggonit Harry!
>If'n you could find that there book easy-like, Jim wouldn't of gone and
>named it 'The Secret Guide', now would he?
>DR
>HJ
>>I have written a program in Perl which divides a 3D panel
>>into triangles, solves for the length of the sides of each
>>triangle and outputs the panel in 2D. If you are interested
>>I would be happy to e-mail it to you. To give credit where
>>credit is due I stole the formuli from a spread sheet I found
>>in Jim Michalak's book "The Secret Guide To Plywood
>>boat design".
>>hal
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=259538.3760361.5018013.1261774/D=egroupweb/S=17050657
91:HM/A=1712983/R=0/SIG=11u38u3s2/*http:/hits.411web.com/cgi-bin/hit?page=13
74-105951838331032> click here
<http://us.adserver.yahoo.com/l?M=259538.3760361.5018013.1261774/D=egroupmai
l/S=:HM/A=1712983/rand=944528124>
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
>DR
>HJ
>>boat design".
>>hal
DR
Sent: Saturday, August 23, 2003 4:47 PM
>boat design".
>hal
l/S=:HM/A=1712983/rand=526408190>
>boat design".
>hal
John Bell mentioned spiling to determine the panel
shapes. I spiled the strakes of Spur II, and found it
to be a little easier said than done! I just finished
calculating the expanded dimensions of Crystals panels
using a spreadsheet and the connected triangle method.
Is was much easier than I expected. The side panels
work out to be exactly 16 feet long, within a 16th of
an inch. PCB is such a genius!
---smallboatdesigner@...
<smallboatdesigner@...> wrote:
> The trick to determine the shape of the panels is to
> 'spile' them off of the mold. Essentially, spiling
> means you pick the shape of the panel off of the
> framed up hull. For a one-off, I don't see where
> expanding the panels saves you anything on building
> Crystal as designed.
> Be warned using Hulls on this boat. Crystal's bottom
> panels are somewhat tortured, so Hulls won't give
you
> the exact expansions. Hulls assumes only two
> dimensional curvature.
> --- Bruce Hallman <brucehallman@...> wrote:
> > > Crystal is kind of unique, in that
> > you build a sort of 'half mold' on
> > a strongback frame, then put the
> > deck on upside down, to which you
> > mount the framing of the side
> > floatation chambers and the foot
> > well bulkheads, stem, keel and
> > transom. To this assemblie you
> > attach the side and bilge panels...
> > but how would you determine their
> > shapes to cut from a flat piece of
> > plywood?
> > What is the trick in determining
> > the 'flat expansion' of curved
> > panels [and strakes]???
> > ------------------------ Yahoo! Groups Sponsor
'Ed,
> > thanks, Fred' posts
> > and <snip> away
> > 1209, Gloucester, MA, 01930, Fax: (978) 282-1349
> > - Open discussion:
> __________________________________
> Do you Yahoo!?
> Yahoo! SiteBuilder - Free, easy-to-use web site
design software
>http://sitebuilder.yahoo.com
thanks, Fred' posts
and <snip> away
> - Open discussion:
On Tuesday, August 19, 2003, at 12:43 PM, David Romasco wrote:
> Might as well post it on the file page; you'll go nuts emailing copies
> otherwise... ;-)
Done. Look in:
Bolger3 group
Files
"Panel Expansion" folder.
panels are somewhat tortured, so Hulls won't give you
> plywood?
> thanks, Fred' posts
> and <snip> away
> - Open discussion:
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
That is what I have
started to do. Using
x, y, z coordinates
from the table of offsets.
[heights, halfbreaths, and stations]
I will 'low tech' pencil
draw the triangles to
scale, and that should
approximate the expanded
shape. [I hope.]
Well, heck, Hal,
otherwise... ;-)
David Romasco
Sent: Tuesday, August 19, 2003 2:34 PM
On Tuesday, August 19, 2003, at 09:26 AM, Bruce Hallman wrote:
> Q: How to determine the 'bend axis'
> of a plank from the lofting???
Back in BC (before cad) when I was a mechanical draftsman I
knew how to do that. I suggest you find an OLD drafting text
that has to do with sheet metal. If I could remember I would
tell you how?!
boat design".
hal
<http://rd.yahoo.com/M=244522.3707890.4968055.1261774/D=egroupweb/S=17050657
91:HM/A=1595053/R=0/SIG=124gf29oe/*http:/ashnin.com/clk/muryutaitakenattogyo
?YH=3707890&yhad=1595053> Click Here!
<http://us.adserver.yahoo.com/l?M=244522.3707890.4968055.1261774/D=egroupmai
l/S=:HM/A=1595053/rand=488642947>
tell you how?!
boat design".
hal
What if it's a conical projection rather than a cylindrical one?
No doubt yes!
Still, PCB designs his boats,
[and builders for centuries
have built boats] by lofting
without software.
Thinking more about this,
the challenge is to predict
the direction of curvature
of the plywood...which I
figure will be along the
surface of a cylinder.
[A simple curve, not a
tortured curve.]
I am guessing that somehow
you can draw the 'bend axis'
of the cylinder on the lofting
diagram, and then draw a line
perpendicular to the axis, and
measure the distance to each
edge of the plank from that line.
Then layout this on plywood for the
cut. I will have to try this
out and see.
Plywood, and other stiff sheet materials, will bend into a cone shape.
(A cylinder is a special case of a cone.) If you're wanting to do it
without modeling, you have to find both the axis and the taper.
http://derbyrm.mystarband.net
> --- "ghartc" <gcarlson@c...> wrote:
> > One way to expand panels is
> > by using a program like "hulls".
> No doubt yes!
> without software.
> tortured curve.]
> out and see.
No doubt yes!
without software.
tortured curve.]
out and see.
Howdy
> Subject: [bolger] Re: Expanding panels, lofting.
> > One way to expand panels is by using a program like "hulls".
I started from scratch, all I had was a sheet of plywood and some extra
epoxy. Using Greg Carlson's HULLS program I am building this.
http://myweb.cableone.net/bcanderson/Boatz/OSKayak/OSKayak.html
Using the offsets generated in the HULLS program, it came out of one
sheet of plywood perfectly.
See Ya
Have Fun
Bruce
If you give me money, I'll try to spend it.
Click here to Donate
With luck, the Duckman will soon be posting a series on Duckworks
that explains (among other things) how this can be done with a
reasonable degree of accuracy.
I might be tempted to use the Hulls suggestion or some other quick
but approximate method to cut out planks in masonite or similar
inexpensive panel material. Put them on the boat (don't you love that
British expression, "offer them up..."), and mark any minor changes.
Then you have a full size pattern.
On the discussion board at MacNaughton.com, there was some talk about
last November about some advanced mathematics for this. I'm not sure
that there was complete follow-through.
Bruce,
One way to expand panels is by using a program like "hulls". You can
get a copy from www.carlsondesign.com. (Cost is to send me a pic of
your boat.)
Gregg Carlson
--- Inbolger@yahoogroups.com, "Bruce Hallman" <brucehallman@y...>
> for Crystal, PCB writes:
> 'not recommended for novice
> builders'.
> I can imagine building the
> frames, and the mold, but
> I cannot imagine expanding
> the shapes of the side, and
> mid panels from the table
> of offsets or by lofting.
> [except by trial and error and
> trial again.]
>...To this assemblie you
> plywood?
Once again, I am dream
building Bolger boats
in my head. On the plans
builders'.
Crystal, a very beautiful
surf rowboat, good enough for
PCB to own personally.
trial again.]
plywood?
