Re: Follow up on sanding etc....
Thanks Peter!
--- Inbolger@yahoogroups.com, "Peter Lenihan" <ellengaest@b...> wrote:
> Bolgerados,
> Naw......I am not going to harp on this point but instead
> will direct you to have a read through of Frank San Miguels' page on
> his work with his AS-29.
> The very last paragraph"filling the weave" is revealing:
>http://www.geocities.com/sanmi/alisa/refit-report-2002/refit-report-
> 2002.html
> This,of course,is not intended to be critical of Herb Taylor(the
> builder) or his methods but rather to illuminate some pitfalls which
> one may encounter later down the road if care is not taken in the
> early stages of construction.Besides, it will never be easier to get
> things right then right now,while your up to your ankles in dust-n-
> tools.
> What makes Franks' observations invaluable is that his repair work
> is taking place on a bigger and "older" Bolger boat.Frank points
> out "problem" areas which a future builder would do well to take his
> time with to get it just right.A bit of hollow on some of those
> joints would have saved a lot of grief for Frank ;-)
> Anyhow, Frank does a great job of explaining his repairs and builders
> should check it out.
> Sincerely,
> Peter Lenihan, hoping to not rattle anyones patience with all this
> talk of sanding......I just happen to be doing some now :-)
Bolgerados,
2002.html
tools.
