Re: [bolger] Re: H&HS update
I think it has to do with our basic optimism. Boats that are 1/2 way
done are 90% completed (it looks 90% done). The final cost will be
approximately twice our realistic analyses at the beginning of the
project. Guess how much time it is going to take compared to the
original estimate?? I am sure this group can find the appropriate name
for this condition.
Silverliningitus?
for this condition.
Silverliningitus?
Bruce Hector wrote:
>--- Inbolger@yahoogroups.com, Harry James <welshman@p...> wrote: I
>can see you acquired this project 90% completed.
>Why is it that these 90% completed projects seem to require another
>90% of the labour to complete.
>Bruce Hector
>Back from ripping up some rotted ply of of his "90%" complleted Micro
>he bought this summer.
Bruce Hector
Bruce Hector
I can see you acquired this project 90% completed. To bad your not
closer, the JNB (Juneau Non-organized Boatbuilders) would love to share
the fun.
the fun.
Susan Davis wrote:
>I'm starting to worry about whether _Shrike_ is going to be ready for
>the Provincetown race, let alone Kingston next weekend. Today, I
> * rebuilt bulkhead "D" to give compartment D-E a larger access
>hatch,
> * discovered that I installed bulkhead "C" on the wrong side of
>the frame (d'oh!), and will need to adjust the main mast step to
>compensate,
> * finished assembling the daggerboard, except for pouring the
>requisite 50 kilos of lead,
> * primed the headblocks for the keel and rudder trunks so that I
>can assemble them tomorrow, and
> * barrier coated the interior with epoxy.
>Tomorrow's plan, before departing for Toronto:
> * cut out the daggerboard slot,
> * install the daggerboard trunk,
> * install the rudder trunk,
> * finish paying the starboard chine with epoxy putty, and
> * finish assembling the sheer clamps.
>After that, I'll still need to
> * prime and paint the interior,
> * install foam and Reflectix,
> * install hatch hardware for hatch "D",
> * turn her over, and mow down the "flash" around the chines,
> * Cuprinol the bottom,
> * barrier coat the hull with epoxy,
> * sand off the epoxy drips,
> * cover the hull in Xynole and wet it out,
> * add two more coats of epoxy over that,
> * sand and fair,
> * prime the hull and sheer clamps,
> * strike the waterline on the hull,
> * coat the bottom and trunk interiors with VC-17,
> * paint the topsides and sheer clamps,
> * deliver _Y-1320_ to Palenville for my friend Cathy to restore
>(and to get her off _Shrike_'s trailer),
> * rebuild the trailer bunks,
> * flip the hull over again, possibly putting her on the trailer,
> * install the sheer clamps,
> * run out to the Orange Box for two more sheets of plywood,
> * trace and cut out the deck pieces,
> * make and install the deck carlins,
> * make and install the coamings for the cockpits,
> * install the knees for the forward cockpit,
> * cut out the slots in the deck for the rudder cartridge and
>daggerboard,
> * barrier coat both sides of the deck with epoxy,
> * install foam underneath the deck,
> * install the deck,
> * prime and paint the deck (with non-skid compound mixed in to the
>paint),
> * pour the lead for the bottom of the daggerboard keel,
> * bend the attachment straps for the rudder,
> * get Jase to do the spot-welding to fasten the rudder to the
>rudder post,
> * make the tiller and comb plate,
> * perform final assembly of the rudder cartridge,
> * make provisions for fids and retaining cords for the daggerboard
>and rudder cartridge,
> * cut the tiller comb slots in the aft coaming of the aft cockpit,
> * varnish the masts,
> * test fit the masts, and add fittings for the running rigging,
> * obtain a 360 degree white LED array for the main mast and
>install it,
> * make the stemhead fitting,
> * obtain cordage and run the sails up as a test,
> * install the rowlocks,
> * make a rowing seat slash bailing bucket slash expedient head,
> * install the lettering for her name and hailing port, and finally
> * conduct sea trials.
>That's rather a lot to accomplish. Yipes.
>Susan Davis <futabachan@...>
hatch,
compensate,
* sand and fair,
daggerboard,
* install the deck,
paint),
rudder post,
install it,
hatch,
compensate,
* sand and fair,
daggerboard,
* install the deck,
paint),
rudder post,
install it,
