Re: [bolger] Re: Chebacco plans
I misspoke when I said my plans included all versions. The motorsailer is
not included.
I wonder if it's a different design number, like the Chebacco 25.
http://derbyrm.mystarband.net
> There is a set of the Chebacco motorsailer plans on ebay right now.
> Mike
> > I just purchased the "Chebacco 20" plans from PCB for $250.
> > He doesn't do credit cards, but seems to have mailed the plans
> > without waiting for my check to clear. Fine service!
> > There are eleven sheets and they present quite a challenge since
> > the several variants are scattered thoughout; e.g. most spars are
> > given on one sheet which shows the gaff main, but for the mizzen
> > mast, one must go to the sheet showing the jib-headed rig. The
> > sheets have no drawing numbers or ref-des's with cross references.
> > The process of pulling together the items of interest has gone a
> > long way towards increasing my understanding of the
> > boat's construction.
> > I'm working on a lap-strake, cruising conversion, version. If
> > you just want the day sailer, sheet plywood version, life is
> > somewhat simpler.
Mike
> I just purchased the "Chebacco 20" plans from PCB for $250. He
doesn't do
> credit cards, but seems to have mailed the plans without waiting for my
> There are eleven sheets and they present quite a challenge since the
several
> variants are scattered thoughout; e.g. most spars are given on one sheet
> which shows the gaff main, but for the mizzen mast, one must go to
the sheet
> showing the jib-headed rig. The sheets have no drawing numbers or
ref-des's
> with cross references. The process of pulling together the items of
> interest has gone a long way towards increasing my understanding of the
> I'm working on a lap-strake, cruising conversion, version. If you
just want
> the day sailer, sheet plywood version, life is somewhat simpler.
> The plans make no mention of rowing or sculling. I'm wondering if this
> isn't an ideal boat on which to try an "yuloh," the Chinese sculling oar
> described in "Junks and Sampans of the Yangtse." It would have to be
> off-center, or one could unstep the mizzen, or use the mizzen as the
shaft
> for the oar. (The main difference between the yuloh and a normal
sculling
> oar is a rope from the inboard end to the sole which supports the
oar and
> controls the blade angle by the rowers pushing and jerking its middle.)
> A separate exchange of FAX messages elicited the suggestion that (I
don't
> have it handy) Richard's 6 hp is just about right.
> Roger
> derbyrm@s...
> From: "Bruce Hallman" <bruce@h...>
> > Just curious, what does PCB say about this,
> > on the plans, or do the plan notes mention rowing,
> > or sculling? And/or what did he write about
> > the motor? [not having ever seen Chebacco plans]
> > BTW, how many sheets in a Chebacco set, and
> > what do they cost?
I just purchased the "Chebacco 20" plans from PCB for $250. He doesn't do
There are eleven sheets and they present quite a challenge since the several
which shows the gaff main, but for the mizzen mast, one must go to the sheet
showing the jib-headed rig. The sheets have no drawing numbers or ref-des's
I'm working on a lap-strake, cruising conversion, version. If you just want
off-center, or one could unstep the mizzen, or use the mizzen as the shaft
for the oar. (The main difference between the yuloh and a normal sculling
oar is a rope from the inboard end to the sole which supports the oar and
A separate exchange of FAX messages elicited the suggestion that (I don't
> what do they cost?
