Re: 'Saran Wrap' & Polyester Film
Garth & Don,
From the FWIW department . . .
First, I've used the 'Saran Wrap' trick for a small OVERHEAD repair I
had to do in the quarterberth of my Potter19. The smooth finish was just
'icing on the cake' where I wanted to simply keep the mixture in place
and not 'dripping' while it cured. Typically I use it in a different
way; I wrap my tool handles with a couple of layers of the stuff, held
in place with some masking tape. When the epoxy 'drools' onto the
handles, it either doesn't stick to well and 'chips' off, or I simply
tear off the 'bad' layer.
Second, I get a 'roll' of film {6 or 8 mil, I think} from Home Depot.
The 'roll' is actually a HUGH piece that is folded about eight times,
then rolled up like a sail. It is used to make 'seasonal' storm windows;
interior 'shields' that are stapled to window trim. I think the brand
name is "Frost King". It's a BIG roll. Good for a lot of uses around the
house & boat.
DON'T use those plastic '$1.oo Drop Cloth' . . thin as Saran Wrap, but
don't 'stick' and tear if you sneeze.
They make a lot of different products - the gaskets on the forward
hatch, and under the lip of the daggerboard/keel are their 'self-stick'
stuff !!
Regards & Good Luck
Ron Magen
Backyard Boatshop
> Date: Mon, 8 Sep 2003 18:32:44 -0700 (PDT)
> From: Don Tyson <tysond99@...>
> Subject: Re: Polyester film
> Garth,
> I've done this some times on small panels with simple Saran Wrap. It
seems to use less resin than floating it out as mentioned earlier. Do it
late in the day. Not when the wood is heating up.
> Don
> GarthAB <garth@...> wrote:
> Did you all see this excellent article on Duckworks, about using a
> sheet of .030" polyester film over your wet epoxy and glass to create
> a perfectly smooth prefaired surface?
>http://www.duckworksmagazine.com/r/articles/glass/bottom.cfm
> I'd really like to try it -- but have been searching the web without
> finding a good supplier for the polyester film. Anyone have any
> leads? I e-mailed John Blazy, author of the article, to ask where he
> got his, but haven't heard back.
> All best,
> Garth
