Re: [bolger] Re: Preglassing and polyester film
Or you can spend $3 or $4 at your local hardware store, or Lee Valley or
Wood Craft or ... Put scraper cabinet wood into Google and jump back.
It's a MUST tool!
Shave Hooks are also cheap and very useful for getting in the corners and
knocking down the bad spots.
http://derbyrm.mystarband.net
It's a MUST tool!
> Another way to clean up the surface is with a scraper.
> You can make one by cutting index card sized pieces out of an old
> handsaw. Don't get it hot while cutting; this will ruin the temper
> of the steel.
> Place the pieces in a vise and file the edge perpendicular with the
> sides. Take a piece of hardened steel (an old router bit shaft works
> well here) and burnish the sides about a dozen times on each side.
> This will cause the top edge to cup. Then do the same to the top
> edge with a slight angle towards the side. This will cause the cupped
> edge to curl over.
> Be careful as a well honed card/cabinet scraper is razor sharp. This
> is what they used prior to sand paper to get a good finish on
> furniture.
> I have posted a pic in the photo section named "Scraper" to give you
> an idea. Watch the line wrap in the link...it gets me all the time.
>http://photos.groups.yahoo.com/group/bolger/vwp?.dir=/&.src=gr&.dnm=Sc
> raper.jpg&.view=t&.done=http%
> 3a//photos.groups.yahoo.com/group/bolger/lst%3f%26.dir=/%26.src=gr%
> 26.view=t
> It works, I didn't invent it, but forgot who wrote it to give them
> credit. I saw it in an article somewhere and a pro boat builder
> swore by this method to avoid epoxy dust. The surface comes off in
> real thin curls about half as thick as tissue paper and it also will
> cut down pinpoint bubbles and small lumps.
of the steel.
edge to curl over.
furniture.
26.view=t
of the steel.
edge to curl over.
furniture.
26.view=t
Just as Sam Devlin does it.
JohnE.
Sent: September 12, 2003 5:28 AM
Subject: RE: [bolger] Preglassing and polyester film
Hi Peter. Peel ply used as a smoothing method? I hear if in
conjunction with vacuum bagging, but are you saying to use without the
vacuum? In other words: wet surface, lay on glass, wet out glass with
roller etc., apply peel ply, squeegee/roll smooth or??, allow to cure,
then peel off? -Bill
[mailto:seabirdaust@...]
Sent: Thursday, September 11, 2003 5:51 PM
To: bolger
Subject: [bolger] Preglassing and polyester film
Rather than a plastic film why not use peel ply -a type of dacron cloth
material. You can peel small bits off at a time and bond straight on to
the area without any prep work, then use it over the joins and edges of
glass tapes to fair the edges.
Minimal fairing, sanding, dust, effort, clean up time and a smooth
finish.
A similar material can be had from dress material shops. Best to get
the coloured stuff so you don't forget to remove it.
Peter Adams
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=251812.3856299.5103760.1261774/D=egroupweb/S=1705
065791:HM/A=1754451/R=0/SIG=11tkldm5d/*http:/www.netflix.com/Default?mqs
o=60178323&partid=3856299> click here
<http://us.adserver.yahoo.com/l?M=251812.3856299.5103760.1261774/D=egrou
pmail/S=:HM/A=1754451/rand=104734901>
- Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930,
Fax: (978) 282-1349
<http://rd.yahoo.com/M=244522.3707890.4968055.1261774/D=egroupweb/S=1705
065791:HM/A=1595055/R=0/SIG=124j83ehr/*http:/ashnin.com/clk/muryutaitake
nattogyo?YH=3707890&yhad=1595055> Click Here!
<http://us.adserver.yahoo.com/l?M=244522.3707890.4968055.1261774/D=egrou
pmail/S=:HM/A=1595055/rand=319190967>
Fax: (978) 282-1349
<http://docs.yahoo.com/info/terms/> Terms of Service.
JohnE.
To: bolger
finish.
Peter Adams
Fax: (978) 282-1349
Fax: (978) 282-1349
To: bolger
finish.
Peter Adams
Fax: (978) 282-1349
To: bolger
finish.
Peter Adams
Fax: (978) 282-1349
Rather than a plastic film why not use peel ply -a type of dacron cloth material. You can peel small bits off at a time and bond straight on to the area without any prep work, then use it over the joins and edges of glass tapes to fair the edges.
Minimal fairing, sanding, dust, effort, clean up time and a smooth finish.
A similar material can be had from dress material shops. Best to get the coloured stuff so you don't forget to remove it.
Peter Adams
Peter Adams
