Re: shoal draft cruising-Yadda Yadda Yadda
In fact, Deutz offers an "cabin heater" option.
Deutz engines are not like diesel truck engines. There is no
glycol-water coolant. Instead, oil circulates through the engine
block and around the cylinders. Each cylinder is individually
replaceable and the heat is transferred directly to the oil. The oil
is pumped to a radiator. The engines are much more reliable than
normal diesel engines.
I believe the heater unit is simply another radiator that you blow
cabin air through. Deutz engines are used on heavy construction and
industrial applications where you need to heat the cab of the dump
truck etc.
Don't know about water heat, but I imagine you could do something with
all of that hot oil.
Frank San Miguel
-- maybe one day I will get a Deutze inside of a big Bolger Boat.
since there isn't a water filled heat exchanger. Something to think
about even with the Deutz.
truck etc.
Frank San Miguel
> >Don Tyson wrote:would not be a cheap source of cabin heat or hot water for showers
> >At least there would be no carb icing on marinized aircraft engines.
> >Also, using any type of air cooled engine, that I'm aware of, there
I think you may have mixed it up here. HP goes up with increasing rpm if
the torque doesn't drop. So it has to be:
HP=(torqueXrpm)/C or HP=torque X rpm X C where C is a constant
(maybe 5252, I haven't figured it out)
>Michael Surface wrote:
>The equation for HP is
>HP = 5252xTorque/RPM
>were Torque is in Foot-lbs
>Using algebra you will find that Torque = HPXRPM/5252
>If you know the HP at a given RPM you can calculate Torque using he equation
>above.
>Michael Surface
I wonder if the moderator might put some of these equations in our database or files
section. It is wonderful for laymen like me to have someone express in not so technical terms (but rather mathmatical) how to to quantify and/or qualify otherwise complex systems. Charles and Michael, thankyou.
above.
Michael Surface
Add MSN 8 Internet Software to your existing Internet access and enjoy
patented spam protection and more. Sign up now!
http://join.msn.com/?page=dept/byoa
above.
Michael Surface
>From: Don Tyson_________________________________________________________________
>Subject: Re: [bolger] Re: shoal draft cruising-Yadda Yadda Yadda
>Date: Thu, 25 Sep 2003 06:44:43 -0700 (PDT)
> If this is the case, hP =rpm x torq., where do you get torq.? is that
>given by the manufacturer or is it arrived at another way?
> >The torque
>decreases maybe <20% over that range so the horsepower (rpm x torq.)
>goes up over the range because rpm increases more than torque
>decreases.
>Why? I think I agree for cruising...but why?
> gearbox and prop combo for a big
>slow
>Generally though if your working with the best amaount of torq. for your
>speed wouldn't that usually be the most efficient ?
>>in terms of hp.hrs./gal. - just the quietest. 1600 -1800 is probably
>close to the minimum recommended rpm for operating at a full load
>for this engine.
>10/4
> >1500 hrs is the overhaul time for some airplane engines but is
>mighty short for a boat or industrial engine.
>don
>(978) 282-1349
>(978) 282-1349
--- Inbolger@yahoogroups.com, "Michael Surface" <msurface@h...>
5252 is a constant to get all the different units (feet, pounds,
minutes, etc,) to match up.
http://www.pesquality.com/formulas.html
http://www.pistonpower.com/about_math.htm
> The equation for HP isHp = Torque x rpm / 5252
cylinder. Less air burns less fuel so you get less power.
That is why engines develop more power on cold days. An airplane has
a triple-whammy at high teperatures. Less engine power and less prop
thrust and less wing lift. If you are in Denver too(altitude) on a
hot day you may not be able to get off the ground without unloading
some weight.
Charles
> Actually, they make better power with the carb heat offCorrect. The heated air is less dense so you get less in the
some weight.
Charles
It's still true that the small ones develp their hp at
hp. compared to an auto engine a derated to an efficient propeller
rpm.
I have a Piper Cub with a Contenintal 65hp. engine. No electrical
system - Arm strong starter (hand propping). The TBO ( time before
overhaul) is 2000 hrs. But an airplane is not like a boat. Lets say
I fly it for an hour on Saturday afternoon. Remember- no potty
breaks, no standing up and stretching, cramped little seat, lots of
noise - an hour is a good average flight and covers about 65 miles.
I can fly half the Saturdays - more in the summer, less in the
winter ( no heater), good weather required. My brothers fly too. So
maybe 50 hours a year. That is 40 years between overhauls. The plane
is a 1946 model. It is on more than its second engine. Disuse is
more of a problem with recreational craft (boats and planes) than
rated engine life. Boats run alot more hours per trip but with a
10,000 hr. engine, you could run it 10 hours !every! Saturday for 20
years. Most of us do not recreate that hard.
Charles
> relatively low rpms.I agree with you about small plane engines. They are large for their
rpm.
Charles
Actually, they make better power with the carb heat off, I'm told. I
think the plane that crashed near our house when I was a teenager might
have succumbed to carb icing.
Just like the old Beetle, you can get heat from an exhaust cuff, if
you're religious about maintaining the health of the exhaust pipe.
Airplanes in tenperate climates without cabin heat would be very cold
most of the year and at high altitudes. Also, I bet it wouldn't be hard
to run an oil cooler water heater.
>Also, using any type of air cooled engine, that I'm aware of, there would not be a cheap source of cabin heat or hot water for showers since there isn't a water filled heat exchanger. Something to think about even with the Deutz.
I guess I don't think of anything with 2000hp as small, whether aircraft
or boat. It's still true that the small ones develp their hp at
>Charles wrote:
>>> I'm afraid you're wrong about the airplane engines, at least for
>most piston engines for small planes.
>For comparable horsepower of a tugboat (2000 hp range) and similar
>style ( V or inline water-cooled) the Allisons and Rolls Royce
>Merlins were high speed geared engines. They were also supercharged
>and water-injected for max power with 130 octane gasoline. I realize
>that diesels are inherently heavier by design but there were some
>old low rpm gasoline marine engines too.
>Charles
above.
Michael Surface
above.
Michael Surface
>From: Don Tyson <tysond99@...>_________________________________________________________________
> >The torque
>decreases.
>slow
><Remember 1800 rpm may not be the most efficient speed for the engine
>for this engine.
>10/4
>don
>(978) 282-1349
>(978) 282-1349
Why not? The temperature drop at the venturi is 40 or 50 degrees F and the
humidity is high. (Carb icing is very hard to detect, because after the
crash, the evidence evaporates.) I suspect that most marine and auto
installations have continuous "carb heat" and just accept the power loss.
http://www1.faa.gov/fsdo/hln/carb_ice.htm
The whole carb ice phenomenon is spooky. Continental engines do. Lycomings
(usually) don't. I use my "carb heat" control mostly to bypass the water
soaked paper air filter when flying in heavy rain. (Lean to restore the
RPMs lost to the warmer inlet air.)
I don't actually like the scheme, but there is plenty of heat available in
the exhaust plumbing and engine cooling air. The gotcha is that if
maintenance isn't rigorous on an aircraft type warm air heating system, the
possibility of carbon monoxide poisoning is high. (Use of stainless for
exhaust system components has been of marginal success due to the difficulty
of producing gas tight welds and due to its propensity to crack.)
Getting hot water should be easy with a copper coil or small radiator in the
cooling air outlet duct. It would be even easier to wrap copper tubing
around the exhaust pipes, but the temperature extremes and corrosion
possibilities might make this tricky.
Roger (who thinks sails are the only really civilized approach to maritime
motion)
http://derbyrm.mystarband.net
> From: "Lincoln Ross"
> > at least for most piston engines for small planes.
> Amen!
> The Thorp T-18 (homebuilt) aircraft was originally designed for the
Lycoming
> O290-G where the G stood for "Ground Power Unit." They were cheap and
> plentiful "war surplus" some forty years ago. Horsepower for current, type
> certificated engines, is typically about 0.5 hp per cubic inch due to
> derating. (During WWII they got over 1 hp per cubic inch from the big
> Wrights and Allisons, but the engines were worn out after 1000 hrs or
less.)
> The O290 has 290 cu-in displacement and is rated 140 hp for take-off and
135
> continuous. The O320 (320 in-cu.) is rated 160 hp in the newer versions.
> Mandatory TBO (for paying customer operations) is 1700 to 2000 hours
> depending on the model. TBO and hp "rating" are tied together. A friend
> was fined by the FAA for upping his O320 from 150 to 160 without doing the
> proper paperwork.
> A VW engine might work since it includes a blower for cooling. A lot of
> them have been successfully converted for use in homebuilt aircraft. Make
> sure you put in guages for exhaust gas, cylinder head and oil
temperatures.
> Water cooled is MUCH more reliable since the thermal cycling of the parts
is
> reduced.
> An aircraft engine (horizontally opposed four cylinder) can be thought of
as
> four separate single cylinder engines sharing a crankshaft and camshaft
> held together by a flimsy cast aluminum crankcase. There is perceptible
> movement between cylinders.
> I don't know where the horsepower peak is. They're typically red-lined at
> 2700 rpm. If I remember correctly from reading the hot rod magazines fifty
> years ago, the horsepower peak is a function of carburation, exhaust and
> intake manifolding, valve timing, etc. They do not fail instantly if
> operated over red-line for a moment or two.
> There are also aircraft engine/prop combinations which have zones where
you
> can't operate continuously. The combo sets up harmonics that causes the
> propellor to come apart. The resulting unbalance causes the engine to tear
> out of its mountings and the plane becomes very tail heavy. Good failure
> mode is when you lose 4" from one blade since you might be fast enough to
> close the throttle. Bad failure mode is where the blade breaks 18" from
> tip. Bye. (The pylon racers add a loop of steel cable around a cylinder to
> the engine mount so the CG stays close to the correct place and gives them
> chance to crash land.)
> > For light weight, reliability, and long life, a turbine is
> > probably best, but now you're talking big bucks, and
> > maybe more fuel usage for the horsepower. Still, the
> > navy uses them. Must require quite a gearbox.
> From what I've read, the gearbox costs more than the engines. The Navy
> often has both turbine and reciprocating engines on the same ship -- the
> turbine for sprints and the diesel for cruising -- fuel economy.
> Roger
>derbyrm@...
> > I'm afraid you're wrong about the airplane engines, at least for most
> > piston engines for small planes. Compared to car engines they are high
> > torque/low RPM, meant for high power levels for long periods of time.
> > They are low RPM so they can spin a large propellor without making the
> > airflow over the tips go supersonic, which would be loud and
> > inefficient. I've been corresponding with someone whose buddy has an
> > airboat with a Caddy engine and a 6 foot prop on direct drive. The boat
> > is hardly ever used because of noise complaints. Anyway, airplane
> > engines can be a bit lighter in some ways because some of the forces at
> > low RPM are much less. As I recall, they may also be lighter because
> > they have a relatively low compression ratio. The displacement tends to
> > be more than that of an automotive engine of the same power though,
> > partly because of the low rpm and maybe partly because of the much older
> > design. Typically, as I recall, peak HP is at something like 2600 rpm,
> > or maybe half what you'd see in a car. In fact, I think an airplane
> > engine would probably make a good boat engine if you could get enough
> > cooling air past it. But due to certification for aeronautical use it
> > would be expensive. However, I hear there are used drone and maybe even
> > stationary engines out there which are uncertified versions.
Frank, I'm new to Bolger so thanks for introducing me to tahitti which I had ignored thinking it was a sail vessel.
Don Tyson
Frank Bales <fbales@...> wrote:
Bolger wrote on these two points in the MAIB articles on the Tahiti. You
can find the articles here:
http://groups.yahoo.com/group/Bolger2/files/BIG%20BOLGER%20BOATS/Tahiti%20De
sign%20%23653%20/
Here's a link to the stern drive Bolger proposes using on the Tahiti with a
42hp Deutz and a small 14" prop:
http://members.ozemail.com.au/~minards/sonic2.html
I've been following this thread with interest, and look forward to your
comments on the MAIB articles about Tahiti
FrankB
Well, this conversation confirms some of my prefferences that I would
rather run one yanmar or perkins for 6 or 8 thousand than two 9.9s at 3000
a peice to power a Wyoming. Problem is that the diesel inboard can't do much
to asist steering or reduce draft ( unless there are actually stern drives
for small diesels).
Props have efficiency ranges. If water were solid (no slippage) the
only thing that would matter about a prop would be pitch because
rpm x pitch would = hull speed.
But water is liquid so speed is reduced by the % slip. Bigger props
have less slip ( are more efficient) at low hull speeds. With low
speeds, big props are run at low rpm so the pitch can be kept in an
efficient range.
Think of paddling a canoe with a paddle (low slip) or a teaspoon
(high slip). You arms will tell you that the paddle is more
efficient and the teaspoon has about 100% slip loss. The teaspoon
would do the job with an engine to move it fast enough to get it in
an efficient range where the slip loss is reasonable(like a trolling
motor). But you can paddle 5 miles on a biscuit - the trolling
motor/prop will take more energy to cover the distance, it is a less
efficient combination than man/paddle. Hp. required to cover the
same distance in the same time is identical for either setup.
Don Tyson
sign%20%23653%20/
FrankB
for small diesels).
efficient range.
sign%20%23653%20/
FrankB
for small diesels).
efficient range.
sign%20%23653%20/
FrankB
for small diesels).
efficient range.
Well, this conversation confirms some of my prefferences that I would rather run one yanmar or perkins for 6 or 8 thousand than two 9.9s at 3000 a peice to power a Wyoming. Problem is that the diesel inboard can't do much to asist steering or reduce draft ( unless there are actually stern drives for small diesels).
chodges31711 <chodges@...> wrote:> If this is the case, hP =rpm x torq., where do you get torq.?
is that given by the manufacturer or is it arrived at another way?
The mfg's chart usually has two curves on it- Torque vs rpm and
hp.vs rpm.
efficient range.
I don't think you can make that general statement - too many
variables.
Horsepower transmitted to the water = speed. Hp. is stored in fuel.
Engines can be selected and torque and rpm can be adjusted with
throttle, gear boxes and props to get as much of the hp. from the
fuel to the water as possible (ie. maximize efficiency, minimize
losses).
It is a package. You try to optimize the engine, the prop and the
hull shape to get the best efficiency at the desired speed. Overall
eff.= eng.eff.x prop. eff.x hull eff. If any one is low, the overall
is low.
Charles
hp.vs rpm.
> Why? I think I agree for cruising...but why?Props have efficiency ranges. If water were solid (no slippage) the
> gearbox and prop combo for a big slow
efficient range.
> Generally though if your working with the best amaount of torq.for your speed wouldn't that usually be the most efficient ?
variables.
losses).
is low.
Charles
Amen!
The Thorp T-18 (homebuilt) aircraft was originally designed for the Lycoming
Wrights and Allisons, but the engines were worn out after 1000 hrs or less.)
The O290 has 290 cu-in displacement and is rated 140 hp for take-off and 135
proper paperwork.
sure you put in guages for exhaust gas, cylinder head and oil temperatures.
Water cooled is MUCH more reliable since the thermal cycling of the parts is
reduced.
An aircraft engine (horizontally opposed four cylinder) can be thought of as
four separate single cylinder engines sharing a crankshaft and camshaft and
There are also aircraft engine/prop combinations which have zones where you
close the throttle. Bad failure mode is where the blade breaks 18" from the
the engine mount so the CG stays close to the correct place and gives them a
> I'm afraid you're wrong about the airplane engines, at least formost piston engines for small planes.
Charles
> If this is the case, hP =rpm x torq., where do you get torq.?is that given by the manufacturer or is it arrived at another way?
hp.vs rpm.
efficient range.
variables.
losses).
is low.
Charles
Well, I agree with most of the post but I'd be very surprised if any
gearbox anywhere didn't have a little bit of loss. Maybe not enough to
worry about in first order approximations, but some. Of course if you're
comparing a big prop with a gearbox to a small prop and no gearbox with
the same engine in a low speed/high thrust application, then you might
get more efficiency out of the big prop than you lose with the gearbox.
All the currently used small plane engines I'm aware of are gasoline,
with a much lower compression ratio than diesel. Another difference is
that the airplane engines are supposed to be overhauled at maybe 2000
hours instead of something like 10,000, as I recall, for the Deutz.
For trains, I suspect the engines are heavy because weight is an
advantage: it gives more traction. For tugboats, I suspect the penalty
for more weight is pretty low, and maybe they need ballast so the tug on
the bollard doesn't roll them over. All this weight probably makes it
easier to design a long lasting engine.
For light weight, reliability, and long life, a turbine is probably
best, but now you're talking big bucks, and maybe more fuel usage for
the horsepower. Still, the navy uses them. Must require quite a gearbox.
>Charles wrote:snip
>snip
>With the 4000 rpm engine the gearbox divides the rpm and multiplies
>the torque by the same number(roughly) so the hp. after the gearbox
>stays the same as the input.
>You check the hp. vs rpm curve for a particular engine to find its
>hp. output at a given rpm.
>Engines that get hp. from high speed/ low torque are small and light.
>( airplanes )
>Low speed/ high torque - big and heavy for the same horsepower.
>(tugboats, trains)
>Charles
Amen!
proper paperwork.
reduced.
<snip>
If this is the case, hP =rpm x torq., where do you get torq.? is that given by the manufacturer or is it arrived at another way?
decreases.
slow
Generally though if your working with the best amaount of torq. for your speed wouldn't that usually be the most efficient ?
for this engine.
10/4
don
>The torquedecreases maybe <20% over that range so the horsepower (rpm x torq.)
decreases.
slow
for this engine.
10/4
>1500 hrs is the overhaul time for some airplane engines but ismighty short for a boat or industrial engine.
don
> So in this case the Deutz engine in question is at max power whenit is at max tourque? even though it is capable of 1200 more rpm
(3000)?
Max. power is at the given (rated) rpm - 3000.
From 1800 to 3000 rpm the the rpm increases 66%. The torque
decreases. My guess is that the engine develops about 20 hp. at 1800
rpm. You would have to check the mfg's chart to get the correct
number.
> If you ran all day at 1800 would that be overloading it?You would not be overloading it if the 1800 speed was maintained by
the throttle and not the load. That usually indicates that you are
below the max load. If operating at less than max.load opening the
throttle will give you the reserve torque which will turn the prop
faster. At max. load it is doing all it can do and more throttle
will not help. (in some engines max load may be limited by the
cooling capacity instead of torque and is indicated by overheating)
> When sellecting a prop for the 30hp/3000rpm motor do you just keepincreasing the size until the engine is down around 1800?
You would probably want a prop ( or gearbox and prop combo for a big
slow prop)where the engine could turn 10% -20% more than 1800 rpm
without overheating. Then set the governor at 1800 rpm max. and run
at about an 80%-90%load factor.
Or you can set it up with a high speed prop to get the full hp from
the engine (30hp instead of 20) for when you want speed and throttle
back to 1800 when you don't. The prop would be less efficient (and
transfer less hp. to the water = slower) at 1800 rpm than the other
way but maybe not a lot. Those are the two limits so you could
select any compromise in between.
for this engine.
> Another Engine that would be good for the sharpie series boatswould be the Atomic-4. They are super quiet and dependable. Ijust
don't know if you could put more than about 1500 hrs on one of them
without needing a complete rebuild and 1500 is nothing if you are
going to travel for a year.
> Don1500 hrs is the overhaul time for some airplane engines but is
Charles
Charles,
So in this case the Deutz engine in question is at max power when it is at max tourque? even though it is capable of 1200 more rpm (3000)?
When sellecting a prop for the 30hp/3000rpm motor do you just keep increasing the size until the engine is down around 1800?
I guess I'm confused how full power is the same as top rpm although I have thousands of hours on perkins diesels where that was the case.
Now that I have someone "in the know" I'll blast you with all my long held questions.
Another Engine that would be good for the sharpie series boats would be the Atomic-4. They are super quiet and dependable. Ijust don't know if you could put more than about 1500 hrs on one of them without needing a complete rebuild and 1500 is nothing if you are going to travel for a year.
Don
Horsepower is roughly rpm multiplied by torque. If you need 30 hp to
go 20 mph, you need 30 hp. regardless of how you get it. You can use
an engine that produces 30 hp at 4000 rpm and a gear box to get 1800
rpm or you can use an engine that produces 30 hp at 1800 rpm with no
gear box or an engine that produces 30 hp at 600 rpm and a gearbox
to get 1800.
hp. output at a given rpm. You would look for an engine that
produces more than 30 hp. at 1800 rpm. You don't have to use all the
hp. available and you would not want to operate at 100% capacity
anyway.
( airplanes )
(tugboats, trains)
Charles
horsepower all the time we should worry more about designed torqe
requirements. The problem I had with this is I don't know how to
convert specs.
I guess I would have to know how much torqe the 4000 rpm engine was
producing.
Don
to get 1800.
anyway.
( airplanes )
(tugboats, trains)
Charles
> I guess I'm getting all twisted up in my thinking here but Iremember hearing someone say that instead of thinking about
convert specs.
> Example: If a boat requires a 30hp engine to go 20 mph at 4000 rpmhow much bigger of an engine would I need to go 20 mph at 1800 rpm.
producing.
> As a sailor I'm into quiet. When I become a motor boater i want tobe relatively quiet then too.
to get 1800.
anyway.
( airplanes )
(tugboats, trains)
Charles
convert specs.
producing.
to get 1800.
anyway.
( airplanes )
(tugboats, trains)
Charles
convert specs.
producing.
charles
Thanks for explaining their (engines) operation. I never thought about just how simple the two stroke diesel could be if designed right. I noticed the 1800 rpm torque rating. I was thinking one should be sure to sellect the engine that has enough tourque to move boat at the desired cruising speed at that 1800rpm vs 3000.
I guess I'm getting all twisted up in my thinking here but I remember hearing someone say that instead of thinking about horsepower all the time we should worry more about designed torqe requirements. The problem I had with this is I don't know how to convert specs.
Example: If a boat requires a 30hp engine to go 20 mph at 4000 rpm how much bigger of an engine would I need to go 20 mph at 1800 rpm. I guess I would have to know how much torqe the 4000 rpm engine was producing.
As a sailor I'm into quiet. When I become a motor boater i want to be relatively quiet then too.
Don
Direct (oil) injection outboards are gasoline. When you mix oil and
gas, you have to mix for the highest oil need - full throttle /high
load. At any other slower speed and lighter load there is more oil
going through the engine than it needs or can consume. This excess
goes out the exhaust. With direct injection, only the amount of oil
required by the power setting is injected into the engine. Much lower
oil consumption and pollution.
With a 2-stroke diesel, the crankcase is the same as a 4-stroke. At
the bottom of the power stroke both intake and exhaust valves open.
The blower blows air all the way through the engine, purging the
cylinder of exhaust and filling it with fresh air. All the valves
close and the piston goes back up. Since the intake of a diesel is
only air (and not a fuel/air mix like a gas eng.) there is no problem
with using excess air to get a good purge.
I noticed that the little Deutz engine recommended was rated up
around 3000 rpm but max. torque was at 1800 rpm. In generator
applications it runs at 1800. That is probably where you would gear
it for a boat - much quieter and longer life. It also has a quiet kit
for sound control. All service from one side is nice too.
Charles
Don
Charles
> I seem to recall there is some sort of technology other thanusing the
> supercharging so that fuel injected two strokes can do without
> crankcase for induction, and therefore not need oil in their fuel.Am I
> confused? If not, how does it work? I seem to recall that directsomehow. Or
> injected 2 stroke outboards are supposed to be low pollution
> is this too far OT, though I'll bet more and more of us who usemotors
> (not me yet) will be using these.Bolger rules!!!
supercharging so that fuel injected two strokes can do without using the
crankcase for induction, and therefore not need oil in their fuel. Am I
injected 2 stroke outboards are supposed to be low pollution somehow. Or
is this too far OT, though I'll bet more and more of us who use motors
>Don Tyson wrote:
>Hugo , Harry,
>I did not realize that Deutz were 2 stroke. If this is the case then they may operate a higher RPMs thereby making it easier to switch drive components with those intended for gas engines. Their are also some drawbacks with 2 stroke the biggest 2 are 1)oil in the exhaust and 2) very low torque ratings at low rpms ( not a problem for boating). snip
There not 2 strokes their 4 strokes. Check the spec sheet for the air
oil cooled they use.
http://www.staufferdiesel.com/s109v03%20fl2011%20spec%20sheet.pdf
--- Inbolger@yahoogroups.com, Don Tyson <tysond99@y...> wrote:
> Hugo , Harry,
for boating). When I was a nurseryman I had a Canadian tractor called
a Holder and it was two stroke (12 hp). It woked like a champ at high
rpm and was worthless at low rpm.
> Hugo, what part of Australia are you from? I got relatives in
Tasmania.
> Hugo Tyson <hhetyson@y...> wrote:
> The pun is a very archaic form of humour these days and appeals to
an 'old time' folksy society!!!!!!!!!!!!
> Don Tyson wrote:
> Hey everyone! nobody got my joke! - referring to
> Deutz Diesels-
> > "raw air cooling"
> Yes we did but its not a matter to joke about!!!!
RRRRRRGRRRRRRRRRRRRRDRRRRRRRRRRRRRRRRRR, I'm deaf and have a foul
headache and I've just burned myself on that ....ing dry exhaust
stack,but at least the fumes aren't blowing back in my face with all
their carcigens.. yadda yadda yadda!!!!!?
> I'm not totally serious.
> Harry, what else are you smoking besides salmon if your
Contemplating taking that trip in a wyo? I'll view your pics though
I'm too chicken for such a trip.
> Don
> Yahoo! Groups SponsorADVERTISEMENT
posts
Service.
> Yahoo! Search
> - Looking for more? Try the new Yahoo! Search
posts
Charles
Charles
using the
Am I
somehow. Or
motors
Yikes! She'd go a kit'en ey? Thanks fo explaining the two stroke function. I assume cylinder wall lubrication comes solely from the crankcase? Do you Know of a site for their marine div?
>A 4830hp. V-16 should push a Wyo. at a pretty good clip.[Non-text portions of this message have been removed]
It isn't that difficult of a trip, it just looks that way from a
distance. The Arctic isn't that hard if you pick the season, and working
in pack ice is no big deal in the summer. I used to spend a couple of
weeks every spring on the roe herring fishery working in ice a lot with
a boat that had 3/8" in plywood sides. Like a lot of things, its the
unknown that is scary and once you get to know something you can deal
with the hazards and they don't scare you anymore. I have looked at this
for a long time and the hardest part is building the boat.
That being said, I have spent many hours searching for people who didn't
do a good job of assessing and dealing with hazards.
Harry, what else are you smoking besides salmon if your Contemplating
taking that trip in a wyo? I'll view your pics though I'm too chicken
for such a trip.
for such a trip.
>Don
I believe that it can turn in either direction, but you have to switch
hemisphere's to get it to turn the other way.
>Due to problems with the prototype 'Dorothy,"
>development of the Kansas design has been dicontinued.
> It proved a good heavy-weather boat, and quite fast,
>but could only turn in one direction.
>--- David Romasco <dromasco@...> wrote:
>>As opposed to Bolger's Kansas, another of the States
>>series, which is
>>propelled by the use of directed high-velocity air.
>>The prototype,
>>'Dorothy', is under construction.... I hear it's a
>>wizard design.
>>David Romasco
>>From: pvanderwaart [mailto:pvanderw@...]
>>Sent: Tuesday, September 23, 2003 10:39 AM
>>Subject: [bolger] Re: shoal draft cruising
>>>By the way when converting these over to boat
>>engines should we go
>>>with fresh air or raw air cooling?
>>It's an automatic feature. When it's cold and windy
>>and rainy, it
>>uses raw air, but when it's warm and sunny, it uses
>>fresh air.
--- chodges31711
is the 2 cylinder 1011F.
http://www.deutzcanada.com/Products/E1011f.htm
A very common, almost famous motor,
used extensively in construction
equipment, like Miller welders, Bobcats,
Ditchwitch trenchers, water pumps, and more.
> DeutzThe Deutz that PB&F specify
Deutz is not 2- stroke. Old Detroits are 2-stroke. With 2-stroke
diesels you don't mix oil with diesel fuel - they just use a roots
type blower (like a super charger on a gas eng.)to eliminate the
intake stroke. The blower pushes in the air rather than the cylinder
sucking. Fuel comes in later from the injector.
Deutz makes more water-cooled engines than air-cooled.
Deutz has a marine division - 19 to 4830 hp.
Charles
Charles
> Hugo , Harry,
for boating).
Hugo , Harry,
I did not realize that Deutz were 2 stroke. If this is the case then they may operate a higher RPMs thereby making it easier to switch drive components with those intended for gas engines. Their are also some drawbacks with 2 stroke the biggest 2 are 1)oil in the exhaust and 2) very low torque ratings at low rpms ( not a problem for boating). When I was a nurseryman I had a Canadian tractor called a Holder and it was two stroke (12 hp). It woked like a champ at high rpm and was worthless at low rpm.
Hugo, what part of Australia are you from? I got relatives in Tasmania.
Hugo Tyson <hhetyson@...> wrote:
The pun is a very archaic form of humour these days and appeals to an 'old time' folksy society!!!!!!!!!!!!
Deutz Diesels-
Harry, what else are you smoking besides salmon if your Contemplating taking that trip in a wyo? I'll view your pics though I'm too chicken for such a trip.
Don
Yahoo! Search
Deutz Diesels-
> "raw air cooling"Yes we did but its not a matter to joke about!!!!RRRRRRGRRRRRRRRRRRRRDRRRRRRRRRRRRRRRRRR, I'm deaf and have a foul headache and I've just burned myself on that ....ing dry exhaust stack,but at least the fumes aren't blowing back in my face with all their carcigens.. yadda yadda yadda!!!!!?
Don
Yahoo! Search
Ouch!
Hugo Tyson <hhetyson@...> wrote:The pun is a very archaic form of humour these days and appeals to an 'old time' folksy society!!!!!!!!!!!!
Deutz Diesels-
Don
Yahoo! Search
Deutz Diesels-
Don
Yahoo! Search
High-velocity directed air ... Sounds like a sail boat in a brisk breeze.
We were racing on the Halifax River in Daytona Beach, north of City Island,
when a squall line came thru. Being only a few hundred yards from the
finish line, I was determined to cross it before heading for shore with the
others. Besides, I was enjoying pulling a rooster tail on a Sunfish on a
dead run. However, I was on starboard tack and needed to come to port to
clear the committee boat. The boat wasn't about to turn in that direction,
and I wasn't about to try to jibe, so I decided to tack. Bad mistake!
As soon as we came head to wind, the boat reversed direction and threw me
into the water. It then sailed off without me for several miles (subjective
measurement) before capsizing. After swimming to the boat, getting the sail
off, blowing with it down to a safe beaching point, and jogging back across
the bridge, I had hypothermia which took a long time to get over (hours).
The safety boat, an aluminum john boat with an outboard, flipped over
backwards when Larry headed into the wind with the bow too high.
The committee boat (which did not have a functioning engine) broke its
anchor rode and drifted off down the river with several distressed matrons
aboard.
Several other Sunfish capsized.
An exciting time.
My Cures:
* the 15' painter now gets tied between the bow handle and my belt. With
me as a sea anchor, the boat will come head to wind and not be too far away.
* the side decks have bathtub type anti-skid strips to reduce the
slipperiness.
* I've learned to sail backwards (put the rudder, not the tiller, in the
direction you want the stern to go).
aboard.
An exciting time.
My Cures:
slipperiness.
> As opposed to Bolger's Kansas, another of the States series, which is
> propelled by the use of directed high-velocity air. The prototype,
> 'Dorothy', is under construction.... I hear it's a wizard design.
Just as well; suspected she'd be a witch to handle....
Sent: Tuesday, September 23, 2003 11:17 AM
Subject: RE: [bolger] Re: shoal draft cruising
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
<http://rd.yahoo.com/M=194081.3897168.5135684.1261774/D=egroupweb/S=17050657
91:HM/A=1706996/R=0/SIG=11p5b9ris/*http://www.ediets.com/start.cfm?code=3050
9&media=atkins> click here
<http://us.adserver.yahoo.com/l?M=194081.3897168.5135684.1261774/D=egroupmai
l/S=:HM/A=1706996/rand=332273783>
(978) 282-1349
> As opposed to Bolger's Kansas, another of the States<http://rd.yahoo.com/M=194081.3897168.5135684.1261774/D=egroupweb/S=17050657
> series, which is
> The prototype,
> wizard design.
> David Romasco
> and rainy, it
> fresh air.
> ADVERTISEMENT
> 9&media=atkins> click here<http://us.adserver.yahoo.com/l?M=194081.3897168.5135684.1261774/D=egroupmai
> l/S=:HM/A=1706996/rand=204217915>__________________________________
> thanks, Fred' posts
> and snip away
> (978) 282-1349
> - Open discussion:
> Terms of Service
> removed]
Do you Yahoo!?
(978) 282-1349
Do you Yahoo!?
> series, which is
> The prototype,
> wizard design.
> David Romasco
> and rainy, it
> fresh air.
> ADVERTISEMENT
> thanks, Fred' posts
> and snip away
> (978) 282-1349
> - Open discussion:
> Terms of Service
> removed]
Do you Yahoo!?
David Romasco
uses raw air, but when it's warm and sunny, it uses fresh air.
(978) 282-1349
David Romasco
> By the way when converting these over to boat engines should we goIt's an automatic feature. When it's cold and windy and rainy, it
(978) 282-1349
Deutz Diesels-
Don
Yahoo! Search
Deutz Diesels-
Don
Yahoo! Search
Deutz Diesels-
Don
Deutz Diesels-
> By the way when converting these over to boat engines should we gowith fresh air or raw air cooling?
Don
Harry, I finally got quick time to work. The movie does'nt show much but the drawings and concept sure make sense. I don't know how small of a unit they will be making. the Wyo needs very little Hp to kill yourself. the 300 hp engines shown would turn a wyo inside out. I think you on to something big. This is similar to those hong kong engines we were talking about last week with all the objectional aspects cured.
Don
Harry James <welshman@...> wrote:
Its a reputable site, I have been watching them for a few years. I have
used quick time and watched the movie. The drive is more efficient than
an out drive and a lot simpler. Basically a retractable prop and shaft.
The down side is they are not mass manufacturing and even though they
are simpler than an outdrive they are not cheap. I think that they could
put a dent in the Mercruiser market here with a package deal, engine and
drive, but it would have to be cheaper. It would out-perform on the same
horsepower.
One of my (day)dreams is to build a Wyoming, power it with a pair of
Deutz Air-cooled diesels running DBD drives and go out of Juneau, up the
coast by Kodiak and then on the boat lift to Iliamna (50 ft might be to
long for it) cutting off having to go around the AK Peninsula, down
through Bristol Bay, on up the coast pass Nome and Kotzebue, Barrow and
the North East Passage. Down the Canadian East Coast and on
to Gloucester to deliver some smoked salmon to the designer.
The Wyoming would be fast enough to get across the the open areas easily
during weather windows.
It is pretty easy to work behind the pack ice close to shore with
shallow draft, and what with global warming all sorts of weird craft are
making the passage now.
Don
horsepower.
Don Tyson wrote:
>Harry,Bolger rules!!!
>>From what I could see of it it looks too good to be true however the add was set up around a Player that doesn't work, or at least I never heard of and couldn't get it to work.
>Are you sure this isn't spam to get you to download a player?
>Harry James wrote:Or DBD drive
>http://www.dbdmarine.com/dbdmarine.htm
>HJ
Yes those DBD Marine outdrives would be good but are quite expensive.I got a quote of $7500 (Australian) which is about $5000 (US) for the standard model.How much they would cost in the US or Canada I don't know, what with import duties etc.
Harry James <welshman@...> wrote:Its a reputable site, I have been watching them for a few years. I have
horsepower.
Don Tyson wrote:
Yahoo! Search
horsepower.
Don Tyson wrote:
>Harry,Yahoo! Groups SponsorADVERTISEMENT
>Harry James <welshman@...> wrote:Or DBD drive
>HJ
>Don Tyson wrote:
Yahoo! Search
With Bolger's current thinking I'm sure he'd reccomend a "Dry" exhaust system as in a truck or tractor, as the boat he's currently designing for me is supposed to have an older 6 cyl. Air cooled Porsche motor with a dry exhaust system instead of the usual through hull underwater exhaust as in most inboard boats.He specifies this so as to eliminate as many as possible potential leaks from through-hull fittings.I must admit an air-cooled Porsche motor will sound heaps better than an air cooled diesel though, being a four-stroke motor instead of those vile sounding 2-strokes!!!!,especially the diesels.But I suppose air cooled 2 stroke diesels do have their advantages,more power for weight etc, very simple......................
Hugo Tyson, Tasmania
Charles,
I'm from Nursery / farm background and think Deutz are impressive enough. Can't get used to thier sound although in a boat w/wet exhaust that shouldn't be a problem.
By the way when converting these over to boat engine should we go with fresh air or raw air cooling?
What size engines are you talking? tthey have to be nicer and quieter than Gm671's I see on alot of irrigation
Don
PB&F then couple the Sonic drive
for pumps and generators. The are very fuel efficient and long
lasting. Efficiency is proportional to temperature and they operate
at a higher cylinderhead temperature. Air cools the head and oil
cools the bottom. They are less forgiving of overload or blocked air
than a water-cooled engine but with proper monitoring sensors (Murphy
switches) that should not be a problem. With proper care you should
get 10,000+ hours (12-15 years on a pump, 20-25 years for a tractor,
boat??)
They are lighter and more compact than water-cooled with a radiator.
Charles
Yahoo! Search
Charles,
Don
> with an aircooled Deutz diesel FL1011I have some experience with Deutz engines used in irrigation systems
> motor, with no 'through hull' fittings.
> They argue that their system is dependable
> and safe. [Also, they spec an elaborate
> and redundant diesel fuel filtration system.]
boat??)
Charles
Yahoo! Search
You don't use a wet exhaust just the oil cooler and a dry stack.
> Charles,
> Don
systems
air
(Murphy
tractor,
> boat??)
> Charles
posts
horsepower.
horsepower.
Don Tyson wrote:
>Harry,
>HJ
>Don Tyson wrote:
Charles,
Don
boat??)
Charles
Don
boat??)
Charles
I have had a set of Sneakeasy plans, which I bought
last spring, sitting on my workbench all summer. When
I finally went to lay out the panels tonight, they had
disappeared. Anybody have a set they want to sell or
swap? Used ones are OK, because I have already bought
a set from Payson, including the right to build one
boat. I know darn well as soon as I send Dynamite
another $35, the originals will turn up, and that
would break my poor, penny-pinching heart.
Thanks, Sam
Do you Yahoo!?
Thanks, Sam
Do you Yahoo!?
boat??)
Charles
boat??)
Charles
--- Frank Bales wrote:
British "Sonic" stern drive unit,
which has more 'swing' to it and allows
it to hang higher 'out of the water' when not
in use. PB&F then couple the Sonic drive
The DB drive 'lives' in the water all
the time, and it doesn't have the
lower unit of more conventional stern
drives. I guess the reduction gearing is
in a gear box on the motor, and I recall
that some people have outfitted salvaged
automobile gasoline motors with the DB drive.
> can someone tell me theOf late, PB&F have been specifying the
> advantages of this unit?
I got the video to work. You need QuickTime which is an Apple product.
It's pretty common.
Since I don't know anything about stern drives, can someone tell me the
Harry,
Are you sure this is'nt spam to get you to download a player?
It's pretty common.
Harry,
Harry,
Don Tyson wrote:
>Can we settle the speed question? Can we install a V-drive Deisel? Can we use inboard or outboard Jets (especially outboard)?Bolger rules!!!
>Imagine a Wyo with 1' draft engine down. Or a wyo deisel pushing though a jet outdrive(9" draft).
>Hal Lynch wrote:
>On Monday, September 15, 2003, at 02:22 PM, Jeff wrote:
>>Though I'm not against the skegs on the Wyoming but Mr. Bolger insist
>>they
>>are a hindrance at higher speeds and after all the Wyo is built to go
>>upwards 25 MPH where turning her sharply could cause her to trip. I
>>can't
>>imagine pushing the Wyo that fast, it goes against my idea of
>>cruising, but
>>it's nice to know if you have to run you can.
>Imagine it. There are time in everyones life when they just
>want to be there.
>hal
Anyone own one of these? Or used one? --FrankB
Sent: Sunday, September 21, 2003 3:47 PM
Or DBD drive
Or DBD drive
Or DBD drive
>>they
>>can't
>>cruising, but
>want to be there.
>hal
--- Inbolger@yahoogroups.com, "Peter Lenihan" <lestat@b...> wrote:
As you say length increases stability assuming it's positive in the
first place, and has the same draft.
Relative to the Wyo caught offshore thing, what about a para anchor.
keeps her pointed into the wind, reduces drift to a very low number,
and if eventualy you do back up onto a not too steep shore, hop off.
Also, let's say you have a few kayaks, or Gulls for exploring, why
not have a beam so you can rig them as amas
> --- Inbolger@yahoogroups.com, "Jeff" <boatbuilding@g...> wrote:Bruce's
> > Agreed on the quartering seas but the Wyo's center of gravity is
> fairly low
> > but nothing like a ballasted boat
> An eye opening event regarding sharpie stability had to be Bruce
> Hectors 95 foot long by 4 foot wide TIMS project(yes,that's right,a
> 23 to 1 beam length ratio!).Prior to the sea-trials, I over-heard
> someone say that she" can sit 20 and drown 30!" I think some folks
> saw something akin to a huge log just waiting to roll
> over.Nevertheless,she went out Sunday without incident after
I have no doubt you could get the Wyo fast enough to be totally scared to
turn the steering wheel for fear of tripping and tumbling. For that matter
cause her to break up! She's built well but careening off waves at 50 MPH
would push things past her design strength.
I actually looked into jet drive but all the manufactures told me to not go
there as a true flat bottom boat that doesn't rise enough to lift 2/3 of the
boat length out of the water, tend to starve the intake for the jet drive
causing overheating and impeller damage.
Maybe a beefed up Sneakeasy would work.
Sent: Tuesday, September 16, 2003 10:49 AM
> > they
> > can't
> > cruising, but
> want to be there.
> hal
(978) 282-1349
(978) 282-1349
Was the Wyo or any other of the flat bottom sharpies designed to plane? Does the sneakeasy Plane....on 15, 18, 25 hp?
I'm not so sure I want a Planing boat but it might be nice sometimes to break out.
Don
Don
> they
> can't
> cruising, but
want to be there.
hal
> they
> can't
> cruising, but
want to be there.
hal
want to be there.
hal
> Though I'm not against the skegs on the Wyoming but Mr. Bolger insistImagine it. There are time in everyones life when they just
> they
> can't
> cruising, but
want to be there.
hal
And So, Steve, You might draw the conclusion that a wyo ought to be able to crash through Afternoon Bay Chop without even rolling up its sleaves?
Don
Steve Bosquette <sbosquette@...> wrote:
Hi Don
Just giving my 2 cents worth. I built and own a Sneakeasy which is a
1/2 scale of Wyoming. I have used her mostly in Casco Bay Maine
which is rough most of the time with large ships and many ferries etc
wakes. I had her going down the face of 8 ft swells unexpectedly one
time and the boat handled it very well. She did dig her nose in but
not above the gunwales. I had to be vigilant in steering but never
felt out of control or nervous. She got to the point where she
surfed down the rest of the wave and bobbed her bow up at the bottom
and I continued on my way. Quite exhilerating(sp) but not dangerous.
Jeff rode in her in Kingston and was impressed how stable she was
both in pitch and roll.
Steve Bosquette
Don
Hi Don
Steve Bosquette
> I think any of the Bolger state series except maybe Idaho would makefor some
> acceptable ICW boats. You may just have a smaller weather window
> areas but at the same time, you can explore places the most otherboats
> would not dare to enter.they
> No boat is perfect in all weather and sea conditions, just the ones
> where designed to handle, the rest of the time we just needpatience.
> Jeff
Steve, I think sometimes I forget just how light these vessels are. Are you the owner of Katie?
Don
Hi Don
Steve Bosquette
Don
Hi Don
Steve Bosquette
> Jeff
Hi Don
Steve Bosquette
Steve Bosquette
> Jeff
Roger , Most of my caulking is gone too. Seakindly it is!
Roger Derby <derbyrm@...> wrote:Following this thread, I can't help but think of Howard Chapelle's comment
in "Wooden Boatbuilding;" to wit:
"The sharpie type, in lengths between 28 and 60 feet, has gone to sea and,
in proper hands, will stand a good deal of punishment; but her crew will
receive as much as the boat. The large sharpies pound heavily under bad
weather conditions; so severe is this pounding that there is danger that the
calking may be knocked out of the seams in the bottom. Large flat-bottom
craft are inclined to be unmanageable in a heavy-breaking sea."
Then there's John Vigor's "The Seaworthy Offshore Sailboat" in which he
repeatedly admonishes the designer/builder to "Think Inverted." John
provides a numerical rating system for measuring seaworthiness.
Maybe the term you're looking for is "sea-kindly?"
> Bolger also has some heavy weather sailboats that are pretty shoal
> draft, tho I don't remember names right now. And aren't those two
> power cruisers he designed recently for ocean crossing pretty
> shallow draft?
> Don Tyson wrote:
> interest lies in the along-shore or shallow estuaries that I
> currently can't reach in my 4' draft sailboat. If the Sharpies are
> as shallow as stated I could conceivably go right into many of the
> back creek and swampy areas that I currently have to paddle or
> wade to.
> So my real question is just how seaworthy are the bigger sharpies
> such as Tennesee, Dakota, Wyo ect? How can we measure the term
> seaworthy?
> shallow draft?
> Don Tyson wrote:
> <snip>
> wade to.
> <snip>
> seaworthy?
I believe the Wyoming was originally designed around a fellow who had an
older 2-cycle 150 HP motor and expectations where for near 25 MPH at 10,000
lbs. maximum displacement.
Sent: Monday, September 15, 2003 2:29 PM
> Jeff, what kind of power plant is required to get the
> Wyo up to that speed (25mph)? That is really moving.
> I agree about lower speeds for comfortable cruising,
> but it would be something just to see a boat that size
> charging along like that.
Do you Yahoo!?
> Though I'm not against the skegs on the Wyoming but__________________________________
> Mr. Bolger insist they
> Wyo is built to go
> her to trip. I can't
> my idea of cruising, but
> Jeff
Do you Yahoo!?
> Well...waddya know! Sam Glasscock comes through withYeah, and I've even managed to opine today on stuff I
> all you really
> need to know! No more excuses now Jack!!!
know nothing about (a braod topic) like boating around
Alcatraz in winter, an area I've only visited a couple
of times in the summer via ferry and charter boat.
That was enough to put me off even the idea of a
winter cruise there, however. I don't know how
westerners manage it. Just looking at pictures of the
Columbia River bar or the surf at Big Sur would make
me give up boating and take up something sensible,
like motorcycle jumping or vulcanology, if I live on
the west coast. As a substitute for real seamanship I
always rely on my inner coward. Sam
Do you Yahoo!?
At the messabout, I too heard the 20/30 comment and shamefully was one of
those who had the rolling log vision. The stability that TIMS proved just
goes to show what a flat bottomed, vertical sided boat can demonstrate.
Seeing is believing.
I no longer have much worry on how the Wyo will handle herself in any
weather I'm willing to risk 3 or 4 years of building and a decent nest egg
on. Thank you Bruce Hector for that!
Though I'm not against the skegs on the Wyoming but Mr. Bolger insist they
upwards 25 MPH where turning her sharply could cause her to trip. I can't
imagine pushing the Wyo that fast, it goes against my idea of cruising, but
--- Inbolger@yahoogroups.com, "vance_cowan85719" <vcgraphics@t...>
driving the beast just weren't worthy of the sea :-)
> >Holy Son of Gun!!!! I'll betcha the boat was seaworthy but the dudes
> "A car traveling on Interstate 77 just north of Charlotte N. C. was
> hit by a flying speedboat at 2:20 a.m. on Aug. 21; the boat was
> dashing across adjacent Lake Norman, became airborne,
> clipped the car and landed on the median, but the only
> casualties were the boaters."
> I suspect the helmsman was pushing the envelope a bit. And I'll
> bet the boaters didn't have seat belts.
> Vance
--- Inbolger@yahoogroups.com, "John Spoering" <spoering@e...> wrote:
her up the Intercoastal to Long Island, New York. Since there are
places along the way that are really not in the Big Ditch such as
Chesapeak Bay and NY harbor would it be necessary even in good
weather to skirt the shoreline in these places ?
need to know! No more excuses now Jack!!!Start a buildin' your
CHAMPLAIN and you and the missus can bone up on your coastal
navigation with evening coarses from your local power
squardran.Pretty neat,eh?!
Peter Lenihan,grateful for Sam's quick rescue of a fellow soon to be
Bolgerado!
> Hi All -When our "Champlain" is completed Barbara & I are planning to cruise
> Perhaps Peter Lanihan would be the best to answere this -
>Jack Spoering - Ft Lauderdale, Fl
> Thanks & Aloha -
>Well...waddya know! Sam Glasscock comes through with all you really
Bolgerado!
over.Nevertheless,she went out Sunday without incident after Bruce's
prudent seaman like call to cancel Saturdays outing due to high winds.
Bolgers allure for the slab sided sharpie has a lot going for it in
so much as the square sections prevent weight from going unsupported,
as in over-hangs,where a persons weight is literally hanging out over
the water.With his bigger sharpies,he avoids going high and instead
spreads the accomadations low and along the length of the boat.His
super structures are all relatively low,compared to the freeboard,and
light compared to their bottoms.Significant on board weights are also
kept low.
No doubt there are seas that will overwhelm a WYO or DAKOTA etc...
(jeese,maybe even a WINDERMERE!) but the unique individuals who
undertake these boats tend to be bright folks who,I humbly
believe,prefer to enjoy their time on the water in more soothing
scenarios then battling the perfect storm.:-) Good olde common sense
or at least the survival instinct might also kick in should things
seem too chancy.Afterall,who wants to blow away several years
labour/cash/love for a thrill?
The picture I have of the Wyo being lifted by a
unspoken words in that one alone!
WINDERMEREs box keel/fillet piece bow.After going nearly blind gazing
upside down at all that beautiful bellow the waterline volume,I have
convinced myself that she will rise like the proverbial cork to the
waves and effectively resist initiating that cycle you speak of Jeff.
originally shown on his plans. On WINDERMERE,Bolger calls for both
the dual skegs,"tail feathers", and the centerboard which he claims
will enhance measurably the boats tracking ability.Again, I cannot
wait to experience the works in action!!!! I'd go with the
skegs/centerboard combo Jeff since they are easier to add now then
later :-)
> Agreed on the quartering seas but the Wyo's center of gravity isfairly low
> but nothing like a ballasted boatAn eye opening event regarding sharpie stability had to be Bruce
kept low.
> crane shows two lift points with no problems and it doesn't have theYes sirree!!!That is a very impressive picture too!!Volumes of
> intercoastals built per plans.
>sharpies
> The problem with the Wyo and swells is the inherent problem of
> where the pressure on the sides is stronger than the pressurecoming from
> the hull bottom which makes water force itself down and under thechine
> creating a lot of air bubbles and turbulence making the bow want todive
> down, then as buoyancy takes over it will popup again creating acyclic
> bobbing effect. When it dives down the stern will want to swingaround as
> the boat digs in so the handling becomes erratic though Bolgerclaims the
> Wyo is less prone to it than most because of her 6:1 length to beamratio
> and total length.That's one thing I am looking forward to experiencing with
>Abbema took
> Either way it would be an experience to say the least. Mark Van
> his 39' river sharpie across the Gulf and had a tough time steeringand
> bounced around a fair amount. He added twin skegs which solved alot of the
> problems and he feels much better about taking the boat out in bigswells so
> it can be done. The accepted solution is to add deep skegs tohandle the
> yawing about when the nose is burying itself before it pops backup. The
> center board is supposed to handle that on the Wyo but I may end upadding
> skegs as well, we'll just have to see how it goes once I have heron the
> water.I think Mark Van Abbema also did not install the centerboard that was
later :-)
Hi Jack,
Sorry but I'm in Montreal and have virtually zero knowledge
of the cruising grounds proposed. All I can add is that CHAMPLAIN is
not an off-shore cruiser.She can,however,easily cruise along the
coast and even make "jumps" provided the weather forcast was
favourable.With such a comfortable roomy boat(for her size) and near
360 mile range on full tanks a lot can be said for taking your time
and enjoying the ever changing inshore scenery from your sheltered,
near 300 degree field of vision,floating home.
Further to that,I recall a brief chat with Han Van Pelts of
the CHAMPLAIN "Mudlark" fame and recent Kingston Messabout attendee
who mentioned to having his boat out on the St.Lawrence in less then
perfect conditions and he reported the boat handled very well.
Hopefully a fellow Bolgerado with "local experience" will
chime in to illuminate areas of concern along your route.
Peter Lenihan,who once fell head over heals for the CHAMPLAIN but
soon slipped into over-drive with the WINDERMERE........oh fickle
heart,be still!
> Thanks & Aloha -
Hi Jack,
heart,be still!
it...............yet :-D
>Sorry Don,already ckecked our archives and you aren't in
> Which Asylum. Maybe we've met. Ha!
> Peter Lenihan,enjoying a tranquile night at the asylum despite the
> roundness of the lunar face...........
>posts
> - Pls add your comments at the TOP, SIGN your posts, and snip away01930, Fax: (978) 282-1349
> - Unsubscribe:bolger-unsubscribe@yahoogroups.comhttp://docs.yahoo.com/info/terms/
>With a shallow draft Bolger sharpie, however, afteronce upon a time you could take the Delaware & Raritan Canal across
>cruising the Cheasapeake I would think about running
>up the east side of the Eastern Shore of Virginia and
>Maryland, which (until the Assawoman canal is
>redredged) requires a run of 15 miles outside from
>Ocean City, Maryland to Indian River Inlet, Delaware,
>but allows you to miss the long run down Delaware Bay,
>which is often rough and largely without any
>reasonable harbors (unlike the Chesapeake).
NJ to Perth Amboy from somewhere north of Camden. Not no more though
much of the canal is still there acting as a park and water supply.
Anyone with a Bolger boat who's transiting the Upper Chesapeake and
gets near Rock Hall/Sassafras River is welcome to give a shout to me.
Always enjoy visiting.
unfortunately, in a misguided moment we sold our house in Somerset Co
maryland, just north of Crisfield so we can't play host further
south. I will recommend Goose Creek Marina, off the Manokin River on
the Eastern Shore by Tangier Sound. Very quiet, protected and
suitable for shoal draft boats.
Small, though.
Craig O'Donnell
Sinepuxent Ancestors & Boats
-- Macintosh kinda guy
As you may have seen in a previous post, I ran a
Bolger Topaz across the mouth of Del. Bay, up the
Jersey intercoastal, out Manasquan inlet and up the
Hudson to Champlain last month. As you point out,
Bolger sharpies are not Pearson Tritons. They (or at
least Topaz) are perfectly adequate cruisers for the
waters you have mentioned, however. The Topaz is
light, so even with its shaped deadrise nose section
it will tend to bang into a chop. It does not show
much tendancy to broach in moderate following seas, if
you trim it up. I wuld not want to use one in SF bay
in the winter, although it would be great in the
Sacramento delta. I would avoid putting out of
Annapolis in a blow, but the boat would be up to it.
The Sandy Hook--Manasqaun and the C&D--Cape May runs
have not proven to be a problem, given prudent choice
of weather.
The Topaz draw less than 8" with the motor up,
and is well suited for the Jersey marshes. When I
came through, the great danger in these waters was the
green-head fly. Sam
--- tysond99 <tysond99@...> wrote:
Do you Yahoo!?
of weather.
green-head fly. Sam
> Would the group please consider a new discussion__________________________________
> with a new member?
> I am new to the concept of flat bottom boats. I
> know that when I
> anchor out or cruise around the Jersey/Chesapeake
> area my real
> estuaries that I
> the Sharpies are
> into many of the
> paddle or wade
> to. There is mile upon endless mile of waters in the
> above areas
> which are 1-3' at low tide (Great Bay, Little egg,
> Barnegat, Choptank
> ect.)
> bigger sharpies
> measure the term
> seaworthy?
> I know that in my Pearson Triton the boat can
> litterally take the
> very worst of weather...much more than I could
> survive inside the
> boat.
> I've heard satisfied owners brag about how good
> the boats go and
> how comfy they ride but would they round Alcatraz in
> winter or leave
> Anapolis in a blow? Would the operator of a Mundo
> style Tennesee hop
> from Raritan Bay(Sandy Hook) outside to Manasquan in
> good waether?
> Would a Dakota or Wyoming steam from Fischers Is. or
> New London to
> Block Is, and the Bristol in average summer
> conditions? Cape May to
> C&D...... Well you get the Idea.
> If I lived on the ohio river system I wouldn't
> even question the
> seaworthiness of these boat but you see I cross
> small bodies of open
> water to get to my cruising areas and want to turn
> turtle.
> So help me if you will todetermine just how harsh
> of an environment
> is appropriate for these boats.
> Sincerely,
> Don Tyson
> Easton, PA
> Owner, Triton "Number Twenty"
Do you Yahoo!?
the safety equation. From Chuck Shepherd's "News of the
Weird", it was in my local newspaper this morning with the title
"More things to worry about".
Vance
> A very large component of the seaworthy focus which rarelyThis item bears on Peter's comment that seamanship is part of
> appears to be mentioned is seamanship.
Vance
I've been on deep draft heavy displacement boats in short chop that was
timed just right to the boat length that every third wave would sweep on
deck. At the same time the light 18' trailer sailors were having a great
sail.
acceptable ICW boats. You may just have a smaller weather window for some
areas but at the same time, you can explore places the most other boats
No boat is perfect in all weather and sea conditions, just the ones they
where designed to handle, the rest of the time we just need patience.
sail.
Jeff, I believe that I would never be in swells larger than 3-4' because of my problems w/nausea....I pick my weather carefully. I often am out in late afternoon schmootz
like is found "everybay" USA. On the Chesapeake the means 2-3' Cross-chop and on Barnegat its 1-2' short intervat waves out of the south, and finally in New York Harbor Its eratic cross-chop accompanied by some serious comercial traffic surprises. I would think the lightly loaded Wyo would, for the most part, span these conditions whereas I might expect a shorter Sharpie with the same amount of stores would be much wetter.
don
quartering or beam >seas.
Agreed on the quartering seas but the Wyo's center of gravity is fairly low
but nothing like a ballasted boat. As to the torsional stress, I don't
think that's will be a problem and the Wyo is very strongly built with that
in mind. I think you could lift the Wyo from each end you would not get any
sag, at least short term. The picture I have of the Wyo being lifted by a
The problem with the Wyo and swells is the inherent problem of sharpies
where the pressure on the sides is stronger than the pressure coming from
the hull bottom which makes water force itself down and under the chine
creating a lot of air bubbles and turbulence making the bow want to dive
down, then as buoyancy takes over it will popup again creating a cyclic
bobbing effect. When it dives down the stern will want to swing around as
the boat digs in so the handling becomes erratic though Bolger claims the
Wyo is less prone to it than most because of her 6:1 length to beam ratio
and total length.
Either way it would be an experience to say the least. Mark Van Abbema took
his 39' river sharpie across the Gulf and had a tough time steering and
bounced around a fair amount. He added twin skegs which solved a lot of the
problems and he feels much better about taking the boat out in big swells so
it can be done. The accepted solution is to add deep skegs to handle the
yawing about when the nose is burying itself before it pops back up. The
center board is supposed to handle that on the Wyo but I may end up adding
skegs as well, we'll just have to see how it goes once I have her on the
water.
don
> I would think that even if a wyo could take the torsional stresses relatedto swells >I'm not sure there is enough form stability to keep it upright in
and total length.
water.
Hi Sam -
Thanks for your positive reply to my question re. the possibility of cruising our Champlain - Ft Lauderdale to LI New York. You've really put my wife at ease and your answere was very detailed.
Aloha - Jack Spoering - we'll stop by.
Jack, I'll let Peter answer when he has time but here
are my two cents based on my experience with my Topaz
sharpie Spat over the last year. I have had her out
in some unpleasant weather, on the Chesapeake and
eslewhere. I don't think you will have any trouble on
the Chesapeake if you are sensible about the weather.
reasonable harbors (unlike the Chesapeake). But, once
again, either way you will be fine if you watch the
weather. Ditto the unavoidable stretch of 25 miles or
so from Manasquan Inlet, NJ to Sandy Hook. The areas
I owuld be particularly careful about on the run up in
a Champlain are the Carolina sounds, which are shallow
and exposed and can get misreable pretty fast, and
coming through the Narrows into New York harbor.
Don't do what I did last month, which was go through
the Narrows with a strong following breeze against a
spring ebb tide. This sets up a really nasty chop
that makes control of a flat bottom boat require a lot
of attention, in an area full of comercial vessels.
If in doubt, you can come into the harbor through the
Kill van Kull and Fresh Kills, around the back of
Staten Island. Be prepared for some chop in the
Harbor itself and up through Hell Gate, too, into L.I.
Sound.
Anyway, I wouldn't hesitate to do the cruise in a
Champlain. I'm sure you will have a wonderful time.
When you get to Lewes, Del. please let me know--I'd
love to see your boat. Sam
--- John Spoering <spoering@...> wrote:
Do you Yahoo!?
Sound.
> Hi All -__________________________________
> answere this - When our "Champlain" is completed
> Barbara & I are planning to cruise her up the
> are places along the way that are really not in the
> Big Ditch such as Chesapeak Bay and NY harbor would
> it be necessary even in good weather to skirt the
> Thanks & Aloha - Jack Spoering - Ft Lauderdale, Fl
> removed]
Do you Yahoo!?
and total length.
water.
Hi All -
Perhaps Peter Lanihan would be the best to answere this - When our "Champlain" is completed Barbara & I are planning to cruise her up the Intercoastal to Long Island, New York. Since there are places along the way that are really not in the Big Ditch such as Chesapeak Bay and NY harbor would it be necessary even in good weather to skirt the shoreline in these places ?
Dorado is versatile looking for sure!
Don
"Mark A." <marka@...> wrote:
Don,
I'm not an expert in any of the boats or locales you mention. According to Philip Bolger,
though, the larger they are, the less fine shape seems to matter. That great box Loose
Moose II has crossed the Atlantic, I believe.
Still, Jim Michalak's multichine hulls with the long, pointed snouts, while still shoal
draft, are earning a pretty good reputation for dealing with rough water. How many 18 foot
boats would you risk this in?
http://tinyurl.com/nduu
Don
Don,
tysond99 wrote:
> Would the group please consider a new discussion with a new member?
> I am new to the concept of flat bottom boats. I know that when I
> anchor out or cruise around the Jersey/Chesapeake area my real
> back creek and swampy areas that I currently have to paddle or wade
> to. There is mile upon endless mile of waters in the above areas
> which are 1-3' at low tide (Great Bay, Little egg, Barnegat, Choptank
> ect.)
> seaworthy?
> I know that in my Pearson Triton the boat can litterally take the
> very worst of weather...much more than I could survive inside the
> boat.
> I've heard satisfied owners brag about how good the boats go and
> how comfy they ride but would they round Alcatraz in winter or leave
> Anapolis in a blow? Would the operator of a Mundo style Tennesee hop
> from Raritan Bay(Sandy Hook) outside to Manasquan in good waether?
> Would a Dakota or Wyoming steam from Fischers Is. or New London to
> Block Is, and the Bristol in average summer conditions? Cape May to
> If I lived on the ohio river system I wouldn't even question the
> seaworthiness of these boat but you see I cross small bodies of open
> water to get to my cruising areas and want to turn turtle.
> So help me if you will todetermine just how harsh of an environment
> Sincerely,
> Don Tyson
> Easton, PA
> I've heard satisfied owners brag about how good the boats go andGiven what builders have said, and prudent operation, and the fact
that many deadrise boats (sail/power) have been used here for
decades... these are perfectly safe for the Chesapeake. I was never
able to find a scientific site which had summaries of average wave
heights but did ask VIMS to which they replied 2-3 ft at most, except
in the worst storms. The "problem" if it is one is that the waves are
steep because the Bay is shallow. There are places where you'll get
beat up a little in the "right" conditions (the mouth of the Potomac
is notorious, the mouth of the Chester R can be rough) but that would
apply to every boat.
Note that the "Seaside Bateau" -- see the genealogy site below for
drawings - was used for running the inlets on the sea side of the
Eastern Shore.
Craig O'Donnell
About that weird craft on the link.
What an odd thing that craft is, it looks like a large mutant kayak gone wrong.
I don't know about the outboard over rev ving though,his assessment seems a bit suspect on that account.His statement that 30HP would be the maximum seems a bit conservative, as Bolger's Diablo Grande 18' can handle 40 HP(Bolger, in my opinion seems to rate maximum power for his craft quite conservatively,probably knowing that people will put larger HP on anyway?!) and the 15' Diablo easily handles 25HP.I've read about the 15' "Diabolico" easily handling older Mk 55 40HP mercury outboards(Which weigh about the same as a 40HP 4-cycle motor) with speeds in excess of 40Mph and getting to that speed in 3 seconds from standstill!!, not to mention making wave jumps of 50+ feet!.
Maybe that odd looking Australian design has a few faults and may behave poorly with greater power, as it states its been derived from a sailing hull, which isn't the way to go for a powerboat hull!
Anyway my own "Diablo" with a 25HP Mercury goes well and handles rough water surprisingly well.
My brother used it to torture some people he didn't like much,by taking them out for a ride in the roughest weather possible and zoomed around the islands near the mouth of the river at full speed over quite a steep chop with some big waves, jumping the boat over them!
It was alright for him sitting in the stern,where the motion is the easiest, but those poor people sitting on the middle and bow seats really knew about it as she leapt off the waves at 30+ Mph.They were quite frightened,even the ones that had some idea about boats!!!.They probably deserved their ride from all accounts of their attitude about a number of things!!!.
Yahoo! Search
Yahoo! Search
Don,
> ect.)
> seaworthy?
> boat.
> Sincerely,
> Don Tyson
> Easton, PA
--- Inbolger@yahoogroups.com, "tysond99" <tysond99@y...> wrote:
You pose an interesting question since there are several
important variables to consider.
All the boats you mention are intended for amateur
construction.Precisely just how sound will any one boat be compared
to another? Will some be built on the quick-n-dirty side of the
tracks while others approach ice-breaker class construction? Who
knows.
appears to be mentioned is seamanship. A competent seaman could
probably take anything across an ocean and survive to tell the
tale.The reason for this,barring any accidents, is that his
experience/training will guide him along a long path of decisions
covering everything from onboard safety equipement,boat construction
and means of propulsion all the way to seasonal weather,sailing
routes and nutrition. He/she will also have the wisdom to know when
NOT to go or if a particular boat isn't fit enough for the job.
Beyond that,good seamanship also implies the knowledge of how to
handle situations that turn bad.
Clearly,the designer of the boats in question had a clue as to
each boats intended/original use scenario from the individual who
commissioned the original design. I think it is only prudent for the
designer to articulate,in general terms,the outer limits of what any
one design can likely handle safely.Otherwise,there may exist the
risk of reckless abandon on the part of some builders who may find
themselves where they wish not to be.
The best all around course of action,may well be to fax the
designer and ellaborate your needs to him directly regarding the
appropiateness of the designs in question vis-à-vis your own use
scenarios.His response may surprise and even delight you :-)
And remember,just because some folks have taken a rowboat across
the Atlantic doesn't make the rowboat seaworthy nor just because the
Titanic sank does it make it passenger ships unseaworthy!
Let us know what you get from the good offices of Phil Bolger
and Friends !
>> So my real question is just how seaworthy are the biggersharpies
> such as Tennesee, Dakota, Wyo ect? How can we measure the termDon,
> seaworthy?
knows.
and Friends !
Jeff ,
I've been to your site, nice! Many of the Sail boats built for rougher water (i.e. Mr Beinke's suggested site, cool by the way) are ballasted and have much form stability to begin with. I would think that even if a wyo could take the torsional stresses related to swells I'm not sure there is enough form stability to keep it upright in quartering or beam seas. I get terribly seasick on the ocean and don't plan to go their very often but occasionally I have to make short hops (i.e. intercoastal waterway). Maybe there are some folks out there with similar boats who will share their experience with us.
Don
Jeff Blunck <boatbuilding@...> wrote:
you what Mr. Bolger has written to me regarding the Wyoming.
"I would no hesitate to cross the gulf stream or one of the Great Lakes in
good weather and small seas."
What that means I have no idea since I've never been on a small craft in
either situations. I'm building a Wyoming so in a few years I will be able
to answer some of those questions. My own thoughts are that a boat like the
Wyoming is not made for anything that can developed big swells. Short chop
would not be a big issue on a long flat bottom sharpie. The Dakota may be
better suited for bigger water in the bays and heavy weather with the rocker
built in but I wouldn't get it to top heavy.
Don
> So my real question is just how seaworthy are the bigger sharpiesSince nobody had actually test this theory to my knowledge I can only tell
> seaworthy?
Here is a URL for a boat not all that different from a Wyo, with one
ama, and dramaticaly improved footpint. Something like this could be
added without a lot of fuss. and removed when operating near shore.
Of course you are talking about inshore anyway.
Similar motor boats have cruised accross the pacific on the gas they
carried, normaly in trimaran configuration, but with narrow small
floats.
http://www.raftvoyagers.com/mirage_guided_kayak_tours.htm
floats.
> seaworthy?
ect.)
seaworthy?
boat.
Don Tyson
Easton, PA
ect.)
seaworthy?
boat.
Don Tyson
Easton, PA
