[bolger] Re: #1 southern yellow pine (shortleaf pine)
To Phillip Lea
The stuff is loblolly pine, or a few related species. Like any other
wood species, you want slow growth stuff, very narrow rings, and
sometimes picking through the pile will produce that. It has about the
same resistance to rot as fir, that is, not much. It holds paint quite
well. Internal moisture blows paint off house siding. Probably every
house in Dixie had pine siding down to the fifties. Old pines have a
resinous heart that has very high rot resistance because it is moisture
proof. That makes it epoxy proof too. Some varieties, such as in my
area Virginia pine will be superior spar material if you obtain young
sapwood, but it is very hard to find clear and long. You just have to
know what you are looking for. Books are no help.
All in all the Southern pines are very individualistic wood, and are
something of a connoisseur's material. In salt-treatment yards I have
seen trash and perfect planks on the same stack for the same price. I
have seen some pine plywood that looked to me very high-grade stuff,
but that's another subject.
from Ed Haile
in Champlain, Virginia
edwardwrighthaile.com
"phillip lea" <paka-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=3141
from Ed Haile
> Lumber yards sell it as #1 southern yellow pine -- the specie aroundcan
> here is acutally shortleaf pine - plentiful in my area, therefore I
> afford it, and there's plenty to pick through too. At least asstrong,
> denser, and a better grade, albeit heavier, than the almostDoes
> non-existent douglas fir. Local builders state and observation
> confirms that it doesn't hold paint well on home exteriors. But Reuel
> B. Parker and others use it in boats - and it has been mentioned
> recently in this group. What is the broader experience? Does epoxy
> work well with it? Are there certain paints that work better than
> others? What boat parts are most suited to southern yellow pine?
> pressure treating affect epoxy or paint holding ability?
> Phil Lea
> Russellville, Arkansas
Phillip,
I have used some southern yellow pine for framing on a couple of boats. I
find it heavy, splintery stuff, almost as bad as oak only uglier, but it
glues well with straight epoxy after some roughing up with coarse sandpaper
or a rasp. I couldn't hazard a guess as to species of the stuff I used.
Based on a few years of continuous exposure, the glued joints haven't failed
and the wood hasn't rotted. I've painted it with alkyd enamel after a couple
of coats of epoxy, and the paint holds up well for me,
david
david
> here is acutally shortleaf pine - plentiful in my area, therefore I can
> afford it, and there's plenty to pick through too. At least as strong,
> others? What boat parts are most suited to southern yellow pine? Does
> Phil Lea
> Get what you deserve with NextCard Visa! Rates as low as 2.9%
> Intro or 9.9% Fixed APR, online balance transfers, Rewards Points,
> no hidden fees, and much more! Get NextCard today and get the
> credit you deserve! Apply now! Get your NextCard Visa at:
>http://click.egroups.com/1/930/5/_/3457/_/951466106/
Phil Lea
Phil Lea
