Bolger Brick and Duckworks Jointability Article
I put the title in but it never posted.
John
John
--- Inbolger@yahoogroups.com, "John Cupp" <john@k...> wrote:
> Hi to all the group and my update for the group. My wife and I
just
> laid the bottom on our brick using the plastic sheeting and
copper.
> What a bright finish the copper provides but there are things not
> do. After buying the sheeting at my local wall mart I let it sit in
> my metal shop. The first part of the roll developed wrinkles.
Before
> you use it you have to let it set out flat to get the wrinkled part
> out.
> You need to also use a roller to smooth out the air bubbles. I
just
> used regular fiberglass plastic paddles but I have come to the
> conclusion that a roller is a better tool. finally the finish you
> get will be ultra smooth and bright. It fairs out much better than
> the standard method and you get the best finish in the world. I
can
> attest to the fact that a copper bottom beautifies your boat but
how
> often do you look under the boat?
> Now to the JointAbility article at Duckworks. I had the tool for 4
> months and now it seems that making scarph joints has become much
> easier than ever before. If you even think you might build a boat
> longer than eight feet please read the article. You can also get
> information packet fromhttp://www.rbiwoodtools.com/and you'll
find
> this tool indispensable. Just to let you know I have a series of
> before the holidays articles I'm doing that include the new Briggs
> Stratton outboard I've been testing, Japanese saws by Shark Saws, A
> new adjustable slot tool that adjusts from 1/4" to 1/2" by turning
> dial. The new Freud no sand blades that polish the wood as they
cut
> and a comprehensive multiple wood planer article that tests the
most
> popular brands and I'll tell you how they performed in my shop.
Plus
> many others so you can let your significant other know what to put
> under the tree this year to make your boat building more
pleasurable.
> That's all for now, so in a few weeks I'll tell you how my bow roof
> shed is being built and the Bolger Zephyr. I am going to put a
> cutter rig on it instead of the lateen sail that is standard.
> Have fun,
> John Cupp
Hi to all the group and my update for the group. My wife and I just
laid the bottom on our brick using the plastic sheeting and copper.
What a bright finish the copper provides but there are things not to
my metal shop. The first part of the roll developed wrinkles. Before
out.
You need to also use a roller to smooth out the air bubbles. I just
the standard method and you get the best finish in the world. I can
attest to the fact that a copper bottom beautifies your boat but how
longer than eight feet please read the article. You can also get the
information packet fromhttp://www.rbiwoodtools.com/and you'll find
before the holidays articles I'm doing that include the new Briggs &
new adjustable slot tool that adjusts from 1/4" to 1/2" by turning a
dial. The new Freud no sand blades that polish the wood as they cut
and a comprehensive multiple wood planer article that tests the most
popular brands and I'll tell you how they performed in my shop. Plus
under the tree this year to make your boat building more pleasurable.
Have fun,
John Cupp
out.
Have fun,
John Cupp
