Re: Sneakeasy modification
--- Inbolger@yahoogroups.com, "Tom Rund" <trund1024@y...> wrote:
> Hi Steve,
> Thanks for the reply.
> After further consideration, I decided to stick to the plans for my
> first sneakeasy. Perhaps later, I will try some mods.
> I noticed while laying out frame #6, that the beam radius of 3-3-1
> doen not work. Did you have this problem?
> Tom
Fritz mentions an error in the plans for frame 6.
It is not to scale. I think foredeck height should be 0,8,2
instead of 0,7,6.
You can cross check by scaling the side view at frame 6 or
subtracting the numbers in that view from 2,5,0.
Charles
Hi Steve,
Tom
--- Inbolger@yahoogroups.com, "Steve Bosquette" <sbosquette@c...>
> Hi Tom
> That picture is of a Slipper boat from England I believe. They are
> inboard boats. My 15 hp Merc stuck 12 - 14 inches above the
transom,
> I don't see why it wouldn't work ok as long as the proportions were
> right.
> Steve Bosquette
> > Dear Sneakeasy builders:
> > Has anyone ever toyed with the idea of building a deck over the
> > sponsons. I believe it would involve raising the freeboard a bit
> a
> > height that would allow the outboard motor to be covered by a
deck.
> > It's hard to put in words. See the wooden power boats group. In
> > photos section under Antiques click on the second photo of
Cheetah.
> > I'm referring to the stern area. It has a beautiful deck over it.
> > Tom
Hi Tom
inboard boats. My 15 hp Merc stuck 12 - 14 inches above the transom,
right.
Steve Bosquette
> sponsons. I believe it would involve raising the freeboard a bit to
> height that would allow the outboard motor to be covered by a deck.
> It's hard to put in words. See the wooden power boats group. In the
> photos section under Antiques click on the second photo of Cheetah.
> Tom
sponsons. I believe it would involve raising the freeboard a bit to a
Tom
