Re: stich and glue, strength
The chine log is not necessary in a true stitch and glue design.
However, some still use fiberglass/epoxy to reinforce and provide
abrasion resistance to chine logs. In a stitch and glue design the
fiberglass tape is applied to both sides of the joint. Ideally the
joint has a small gap up to 3/8 inch between the panels. This gap is
filled with a wood flour/epoxy mix. You might want to see the
tutorials at www.bateau.com.
--- Inbolger@yahoogroups.com, Mi'ki <mike78612003@y...> wrote:
> when using this method can the wood strip that is normal to put at
joints be removed all together, does the glass become the joint or
just to prevent it from moving
> Do you Yahoo!?
> The New Yahoo! Shopping - with improved product search
when using this method can the wood strip that is normal to put at joints be removed all together, does the glass become the joint or just to prevent it from moving
Do you Yahoo!?
Do you Yahoo!?
