Re: stainless steel
--- Inbolger@yahoogroups.com, Natalie Stanson <mike78612003@y...>
stainless together, I tried bending but bending only makes cracks
If these are boat parts like rudder hanging hardware, or chainplates,
etc... there are few parts that can't be more economicaly
manufactured either out of glass, or stuff like bonded in place
swaged wires.
> I don't have a expensive welder available to make some brackets, isthere a way to solder or braze with map gas torch two pieces of
swaged wires.
i have a fiberglass hull wood deck 13 foot sail dingy, the wood of the
deck side rails and support members is rotted and or old and just
falling apart. i think the supports where ripped out of fur before,
but id like to do this correctly and have it look good and last!so im
going to tear out all the wood in the boat. would any one help out
with some ideas for replacing it. i thought about oak, but maybe this
is too heavy? and should i glass over the deck, what kinds of cloths
are there, ive been looking back through old post and there seams to be
alot of new stuff since the last time did some fiber glassing. any help
would be great
would be great
a wire feed welder will do stainless too,
> Plumbing solder does work, especially if you need to repair a crack
> in a tank, but itis really non structural. bronze welding with oxy-
> acetylene also works, but you may wish to add additional gussets, etc.
> yuo dont need a fancy arc welder to weld stainless , even a cheapy
> will do fine,
> cheers paul
> Rent DVDs from home.
> Over 14,500 titles. Free Shipping
> & No Late Fees. Try Netflix for FREE!
>http://us.click.yahoo.com/ArdFIC/hP.FAA/ySSFAA/_0TolB/TM
> Fax: (978) 282-1349
> Your use of Yahoo! Groups is subject to
Perhaps, depending on the strength required, you could anneal and bend?
It will be weaker, but maybe strong enough? I don't know anything about
annealing stainless, tho.
>From: Natalie Stanson <mike78612003@...> wrote:
>I don't have a expensive welder available to make some brackets, is there a way to solder or braze with map gas torch two pieces of stainless together, I tried bending but bending only makes cracks
will do fine,
cheers paul
will do fine,
cheers paul
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
Do you Yahoo!?
