[bolger] sauna?
What problems might be encountered in installing a sauna in a ply epoxy
boat. I have thought temperature might be a problem as epoxy softens at
a fairly low temperature, anyone know what that temp is? Also is there
offgassing at high temps? The space I could use is already resined with
some glass as I had thought there might be a shower in the space. A
layer of insulation could be installed and some thin cedar applied over
it but there are also two large Lexan windows in the space. A heat
source would be needed perhaps a small solid fuel stove. The space is
approximately 4'X 4'. Any suggestions?
Fritz Koschmann
Building Double Eagle
