[bolger] Re: question on LWL
All boats have this problem, which probably help to accounts the various
formulas for hull speed. I'm afraid whatever you calculate won't be that
meaningful anyway - with my small reaching pole, I cracked 10 knots more
than once (I used a spring-type "yacht stick" and pulled it out to its 10
knot stop). The Micro is a short, fat little boat - short little waves and
chop will affect it considerably (so will banging that bow transon into
waves). By the way, pressing those bow steps into the water while reaching
off, I managed to flood my flooding bow section all the way up to the
port/window into the cabin.
The Micro also wants a pretty flat mizzen and a fairly powerful main. And,
going high to windward takes some effort. I wouldn't file my float plan
just yet on that imaginary coastal cruise.
But, Pippo, maybe that's why you're a real scientist and I'm an applied
scientist? Order of magnitude sounds fine to me...
Gregg Carlson
Gregg Carlson
>Dear all,
>I'm facing some ambiguity in defining Phil Bolger's Micro's LWL. Most
>sources report a value of 12'2" (3.71 m), while Hullform 6S finds a
>value of 14' (4.3 m). This is clearly due to the fact that the Micro
>keel cuts the water before the canoe body. Now, which one is the correct
>value to use for speed computation and other strange stuff? I'm limiting
>myself now to the dead upright position (0 degrees of heel). Thanks, and
>best regards
>Pippo
>BETTER THAN EVER: 250 HOURS FREE on AOL! Find out why 18 MM
>people have chosen AOL as their ISP! Click here NOW! for
>250 Free HOURShttp://clickhere.egroups.com/click/914
>eGroups.com home:http://www.egroups.com/group/bolger
Dear all,
best regards
Pippo
best regards
Pippo
