terminology police was Re: Re: PL Premium failure (don't use over epoxy?)
PL doesn't make Gorilla Glue, to my knowledge. PL is a brand name, isn't
it? Don't you mean PU for polyurethane? I'm only mentioning this because
many times I've seen people become confused about exactly which glue
we're talking about. I imagine sometime someone will be in the middle of
a large lake when their boat starts to fall apart and will have a long,
cold swim! Even within the PL line you could get the wrong variety of
stuff in a tube and have it not work as well. Or at least some people
have reported this. (I've used the Elmer's Probond liquid POLYURETHANE
glue on tight fitting stuff like laminated gunwhales with good results
so far. Note that there are other liquid ProBond products that are
nothing like the polyurethane type. I recall that one of them is like
carpenter's glue and would probably disappear if given a good long
soak.) Then there's the difference between Titebond and Titebond 2....
BTW, in my experience PL Premium Construction Adhesive(one of the kinds
that comes in a caulking gun tube but NOT PL400 or whatever it's called)
does fill gaps, at least to some extent. It even says so on the package.
But that's NOT the liquid stuff. So by my count there are at least 4
kinds of PL to keep track of. (I seem to remember discussions of PL
Premium Concrete Adhesive that also comes in a caulking gun tube)
Lincoln Ross
-temporarily (I hope) obnoxious
>"Jeff Blunck" <boatbuilding@...>
>>> The liquid stuff is easy to apply and has a much longer "pot life"
>>> than epoxy. I sometimes wonder if the foamyness might help fill the
>>> gap when pieces don't mate perfectly.
>I'm a fan obviously of PL glues like Gorilla Glue and I've had to tear apart
>a whole bunch of stuff I've glued with it without a joint failure. But, I
>qualify that by only including the joints that where tight. Any gap at all
>and the joint is literally not holding anything. With a tight fit and boat
>nails. PL so far has proven to me of being an excellent adhesive.
>Jeff
> Worth mentioning, PCB rarely specifies
> which glue to use. [Indeed, I cannot recall
> him *ever* writing about glue preferences.]
He once suggested that a builder who had become sensitive to epoxy
might switch to resorcinol.
> exactly which glue we're talking about.
>... Elmer's Probond liquid POLYURETHANE
That it the glue I have used and like.
