[bolger] Re: [boatdesign] question on LWL
my Micro hit 8 knots once - that was measured by "knot stick" a contraption
that looks like a test tube has has spring and plunger inside attached to
small elastic that you throw overboard and has a disk on the end. We were
really bookin it. Trees on shore were bending. We were 3 in the boat under
full sail, white caps everywhere, on a reach. I don't know how accurate the
knot stick is. I figure hull speed is about 4 knots as measured by that
thing.
george full
To:boatdesign@onelist.com<boatdesign@onelist.com>; bolger group
<bolger@egroups.com>; Bolgerlist <cnoto@...>
Date: Saturday, September 18, 1999 10:31 AM
Subject: Re: [boatdesign] question on LWL
>Pippo,
> its going to depend on the load. In "Boats with an Open Mind" Bolger,
>talking of a Micro undertaking a long cruise 2-up, says that "while the
>boat is nominally all of 4.67m long, each end is a free-flooding well, more
>of cutwater & stern platform than boat proper; the actual watertight
>envelope is barely 3m long." There is a fair old range there, but this
>comes down to surprisingly little when you apply the formula I've often
>seen, viz Hull Speed in Knots (Max) for a very efficient displacement boat
>(Lets give Bolger that!) = 1.33 X sq rt (WLL imperial). (Wharrams go to 2.2
>X)
>This gives 4.2-5.2 knots, which obviously is a far narrower range than
>3-4.67 meters.
> Your best bet for performance is probably to use the conventional tandem
>of SA/D (sail area/displacement) for power available (good cruiser=15;
25
>gets powerful & quick) & Disp:WLL for ability to haul ass(Cruisers 300,
>150 gets light & quick.). These are not straight ratios - formulae are in
>every Yachting World boat test. If you can achieve a good trade-off of
these
>two, you could get good speed out of a tea chest with a mast. The beauty of
>it I think is it solves your dillemma...because in both formulae the gains
>of the extra waterline are nullified by the extra weight required to
achieve
>this increase. All you need is to know what weight of micro gives what
>waterline!!
> Alternately ring some one who has one, & ask em how fast they go!!. (If
>its for sale , divide by 1.5)
>Cheers
>Jeff Gilbert
>Down Under in the land of Vegemite & sunburn.
>----- Dear all,
>I'm facing some ambiguity in defining Phil Bolger's Micro's LWL. Most
>sources report a value of 12'2" (3.71 m), while Hullform 6S finds a
>value of 14' (4.3 m). This is clearly due to the fact that the Micro
>keel cuts the water before the canoe body. Now, which one is the correct
>value to use for speed computation and other strange stuff? I'm limiting
>myself now to the dead upright position (0 degrees of heel). Thanks, and
>best regards
>Pippo
>--------------------------- ONElist Sponsor ----------------------------
>Share your special moments with family and friends- send PHOTO Greetings
>at Zing.com! Use your own photos or choose from a variety of funny,
> cute, cool and animated cards.
> <a href="http://clickme.onelist.com/ad/zing7">Click Here</a>
Pippo,
X)
3-4.67 meters.
of SA/D (sail area/displacement) for power available (good cruiser=15; 25
every Yachting World boat test. If you can achieve a good trade-off of these
of the extra waterline are nullified by the extra weight required to achieve
waterline!!
Cheers
Jeff Gilbert
----- Dear all,
best regards
Pippo
