[bolger] Re: Xynole
I'd be concerned that the xynole would not follow the inside or outside corners
at the edges of the planks. Id' try laying up a small area and see if it
followed the corners. Pull it off and wipe off the resin before it cures. If
there's a problem, you might need to round the edges of the planks or apply a
small fillet before laying on the xynole.
> Since there is so much knowledge about this material in the group, I will
> pose the following question:
> Would xynole be suitable for covering the outside of a lapstrake ply canoe?
> Chuck
> Duckworks Magazine
>http://www.hilconet.com/~dworksmg
> 250 FREE HOURS are waiting for you on AOL!
> Try AOL *risk free* for 250 HOURS!
> CLICK HEREhttp://clickhere.egroups.com/click/915
Xynole is itself lightweight stuff, by which I mean it's not very
dense. (Supposed to be a breaze to work with and very tough standing up
to rocks and stuff.) Hence, you should compare the 4 ounce stuff
Defender sells (at least I recall the only weight they sell is 4 oz) to
8 ounce fiberglass. Both are supposed to be equally durable, but both
take the similar ammounts of epoxy to fill.
Warren:
Thanks for the info. It sounds good enough to try. We have very shallow
water, and equally hard rocks, so if the boat is a little heavy, I won't be
overly concerned. I'm going for it.
> Chuck,the
> I do know a little about Xynole, it's the canoe I don't know anything
> about (no sail). I am told that Xynole takes "much more" resin to fill
> weave, so for me this would raise the question of weight. How heavy istoo
> heavy for a canoe?? What is the weight of resin you would use for aregular
> glass canoe? The catalog says that Xynole is available in 4 oz only andusual
> Defender gives the following info:
> Glass Xynole
> 24000 15000 Flexural strength PSI
> 79000 61000 Tensile strength
> 322 88 Stiffness
> fair good Abrasion resistance
> fair good resin impregnation
> I am told that the Xynole is much nicer to sand, with none of the
> FG itch afterwards.
> Regards, Warren
> 250 FREE HOURS on America Online! America's most popular online
> service! Try AOL *risk free* for 250 HOURS!
> CLICK HEREhttp://clickhere.egroups.com/click/912
Chuck,
about (no sail). I am told that Xynole takes "much more" resin to fill the
weave, so for me this would raise the question of weight. How heavy is too
heavy for a canoe?? What is the weight of resin you would use for a regular
Glass Xynole
322 88 Stiffness
I am told that the Xynole is much nicer to sand, with none of the usual
FG itch afterwards.
Regards, Warren
Glass Xynole
322 88 Stiffness
FG itch afterwards.
Regards, Warren
