RE: [bolger] bed liner for canoe
just a thought here but the spray on undercoating that is used to rust proof
and help as a noise barrier on the underside or fenders of a car,is it the
same stuff as a bed liner with out the grit ? i've used some on the under
side of the fenders of my travel trailer for water proofing. it sticks well
to most anything and looks kinda like bed liner. i don't have a can around
now, is it polyurethane? robby
>From: "Frank Bales" <fbales@...>
>To: <bolger@yahoogroups.com>
>Subject: RE: [bolger] bed liner for canoe
>Date: Fri, 28 Nov 2003 02:36:15 -0500
>Robby, this stuff was discussed at the Trawler World List for covering
>steel
>decks. Here is a link to the archives; look for the subject "Steel Deck
>Coating." There are about 7 posts and some of them even offer an alternate
>material. I think it would work fine for your needs.
>http://lists.samurai.com/pipermail/trawler-world-list/2003-November/subject.
>html
>FrankB
> -----Original Message-----
> From: boatbuilderman [mailto:robbylplunkett@...]
> i checked thread in archieves about pickup bed liner use on boats,no
> info about use on bottom of polyurethane canoe hull. i was wondering
> if it could be use to repair cut in hull and add strength to bottom
> as a whole? does it come only with the grit or is there something
> like it without the grit? or will the grit interfer with drag in
> water enough to worry about for casual crusing. please advise. i
> assume it would work well on wood hull. thanks,robby
>[Non-text portions of this message have been removed]
_________________________________________________________________
Set yourself up for fun at home! Get tips on home entertainment equipment,
video game reviews, and more here.
http://special.msn.com/home/homeent.armx
Here's a better link:
http://tinyurl.com/wv39
steel
alternate
html
FrankB
Robby, this stuff was discussed at the Trawler World List for covering steel
html
FrankB
