More about Sea Angel.
Hi again,
Well I got the brailing system up and working. Looks pretty good
too. If I do say so myself. I'm having a ball working on the boat
and hope to have the rudder fixed in a day or two so I can go out
and see how the brailing system works under real conditions. Sure
makes the boat seem less crowded with the sail up against the mast
and no spars in the bottom of the boat.
If youre intersted in seeing it I have some pictures posted. You
can get to them from:
http://www.angelfire.com/ex/ti/FWmain.html
Prating made me a couple of paddles but I need to make oars or use a
skulling oar. I think the paddles will work if I have a crew member
so we can paddle on both sides at the same time. The boat is a bit
too wide to swing a paddle back and forth from side to side. I'll
let you know how it goes once the rudder is fixed and I can take her
out again.
Smooth sailing to all,
Steve.
