Re: [bolger] Safe working loads
I don't think your 5/16" line is on the light side. Modern ropes are VERY strong.
I would have went with something cheaper, like those 100ft bundles of 3/8" rope you can get at Home Despot and other places for $9.
Halyards need to be low stretch, but sheets can survive with a little stretch.
Sent: Friday, January 16, 2004 7:04 AM
Subject: Re: [bolger] Safe working loads
> The boat is a very light 19' sailboat with a very large, 145 sqft., genoa.
> I don't imagine I'd try and fly that sail in high winds. The foot of the
> genoa is almost 2/3 the length of the boat (that may be a slight
> exageration, but not much).
> I bought the rope already using the West Marine Advisor on running
> rigging. With that I selected 5/16" Sta-Set X+ (New England Ropes).
> In hindsight I'm thinking that might be a little on the light side. What
> I'm really having trouble with is trying to find the correct matching
> sheet block. I'll probably just go for overkill and look for something
> rated with a work load of close to 1000lb.
> Michael
> From: Richard Spelling
> To:bolger@yahoogroups.com
> Sent: Thursday, January 15, 2004 2:21 PM
> If you tell us the size of the boat, we can probably give you a rope size, then you can get your block and cleat sizes to fit
that
> rope.
> From: "Derek Waters" <dgw@...>
> Sent: Thursday, January 15, 2004 3:40 PM
> > "...it's four times [the force] when wind speed doubles..."
> > Yup. Bearing in mind that the loads seen by a block are related to the
> > amount by which the line is turned. A block which turns a load back on
> > itself sees the load doubled. 90 degree deflection equates to 141% load.
> > The Harken catalogue used to have a bunch of loading formulae printed at the
> > back. Mainsheet vs Genoa (boomed vs boomless) etc etc. The same information
> > may be on their website somewhere.
> > cheers
> > Derek
> > - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349
> > Yahoo! Groups Links
> > To visit your group on the web, go to:
> >http://groups.yahoo.com/group/bolger/
> > To unsubscribe from this group, send an email to:
> > Your use of Yahoo! Groups is subject to:
> >http://docs.yahoo.com/info/terms/
> a.. To visit your group on the web, go to:
> b.. To unsubscribe from this group, send an email to:
> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Michael
Michael
If you tell us the size of the boat, we can probably give you a rope size, then you can get your block and cleat sizes to fit that
rope.
> cheers
> Derek
I'm trying to install sheets, sheet blocks, winches, etc. for a
brand new genoa I just purchased for my boat. There is no
existing deck hardware on the boat. All the hardware and
lines I'm looking at have "safe working load" ratings. Is there
anyway to ballpark the load on a given sheet and/or block
based on the size of the sail and wind conditions?
I know this is a little off topic but any help would be
greatly appreciated!
Thanks!
Michael Matthews
Partner, Software Services
Nymbil Solutions, LLC
mike@...
(925) 216-4911
Thanks!
Michael Matthews
mike@...
(925) 216-4911
Gerr's chart says that's fine for the halyard, but pretty light for the
sheet. He'd go for 7/16" or 1/2" for the sheet (and not have to wear gloves
to tend it.)
http://derbyrm.mystarband.net
to tend it.)
Sent: Friday, January 16, 2004 8:04 AM
> Michael
> rope.
load.
at the
information
> > cheers
> > Derek
posts
Fax: (978) 282-1349
> > Yahoo! Groups Links
Fax: (978) 282-1349
Service.
(978) 282-1349
rope.
rope.
> cheers
> Derek
yes
Sent: Thursday, January 15, 2004 12:06 PM
> --- Richard Spelling wrote:
> > Ballpark one pound thrust per
> > square foot of sail @
> > wind speed of 14mph.
> And does the trust increase/decrease
> exponentially with change in windspeed?
> 28mph = ? lbs thrust
> 7mph = ? lbs thrust
cheers
Derek
cheers
Derek
In "The Nature of Boats" Dave Gerr spends four or five pages on sizing the
rigging. Unfortunately, most of the calculations address the standing
rigging. For the running rigging, he offers a chart which seems to me to be
quite conservative. For small boats, one consideration is the toughness of
your hands. Small Spectra lines may carry the load easily but slice great
grooves in your palms. I like at least 3/8" for sheets.
For the 34' sloop rigged version of Badger, Jay Benford sized the genoa
sheet and halyard as 1/2" Dacron and called for Barient 23 winches. That's
for an 11,000 boat with a 400 sq-ft genoa. Gerr would have 0.55" sheets and
a 0.43" jib halyard.
Gerr suggests at least 8:1 for sheeves (minimum), so figure 4" or larger
blocks. He also says 12:1 for cleats ==> 6" minimum.
Sent: Thursday, January 15, 2004 10:53 PM
Subject: [bolger] Safe working loads
> Thanks!
> Michael Matthews
>mike@...
> (925) 216-4911
I believe it's exponential of 2, meaning it's four times when wind speed doubles.
So, 28 MPH wind would be 4lbs / sq. foot. 7 MPH should be 1/4 lb. /sq foot.
If memory serves anyway.
Sent: Thursday, January 15, 2004 11:06 AM
7mph = ? lbs thrust
7mph = ? lbs thrust
> Ballpark one pound thrust perAnd does the trust increase/decrease
7mph = ? lbs thrust
Ballpark one pound thrust per square foot of sail @ wind speed of 14mph.
Sent: Thursday, January 15, 2004 9:53 PM
> Thanks!
> Michael Matthews
>mike@...
> (925) 216-4911
